3 Battery Generating System
This topic is closed.
  • Heating
    Netica,
    I don't have an answer to that question, but I would assume NOT based another test runs I have done with a pulse motor running the thing.
    Matt designed a circuit to use the coils as both a motor coil and a generator coil, and I built it. At the time, I had not yet discovered the solution to magnetic neutralization, so the motor was drawing a massive amount of amps. Anyway, there were two switches in the design. One to turn the motor off and the other to turn the generator on. They had to be flipped in the correct order, and of course I flipped them in the WRONG order, which blew the transistors. It was shortly after that I figured out the magnetic neutralization, and have just run the whole thing with a small motor. I haven't even bothered to run it on the 3 Battery circuit to recover most of the expended energy because I already know I CAN, and it is easier to just run the motor off a power supply than to mess with rotating batteries and all that switching.
    My research was focused on TWO things when I stopped to remodel two houses. The first was core material, and the second was an entirely NEW configuration of the generator using a PacSci motor that has shafts coming out both ends. The new configuration would have 20 coils on it and at around 200 watts per coil, that would give me something worth keeping. I have the design all done, but didn't build the machine yet, although I bought all the parts.
    The reason I wanted to experiment with that design is because a smaller machine could be built using a razor scooter motor that you knock the shaft out of and replace with (I believe) 7/16 all thread. By drilling a hole in the other end cap of the motor, you can put the rod all the way through and that allows you to build a small six coil machine that you can print all the parts necessary for construction on a 3D printer. I have the design all worked out and If you have a 3D printer, a Dremel tool, a set of dremel drill bits, and a plunge router attachment https://www.walmart.com/ip/Dremel-50...10090302008005
    along with a regular drill, you can build all the parts.
    • Hello again Turion,
      I have noticed a difference between the 6 coil machine and the 5 coil machine that I have been thinking about.
      With the 6 coil machine I can see that all the coils energize at the same time, and with the 5 coil machine the coils energize one at the time.
      Have you noticed any problems or benefits from either set up. More so for the generation of electricity and the way it is saved or used, does the coils interfere with each other, or any other issue you have noticed.
      • 6 vs 5
        Netica,
        You are correct about the two machines. The six machine has six coils on each side of the rotor, so 12 coils interact at once. This was TOO MUCH magnetic drag for the motor to overcome, especially on start up (over 100 amps drawn through the motor) so I had already switched to the 5 machine, which has five coils on each side of the rotor and only a pair interacting at the same time, to reduce that amp draw to something that wouldn’t burn up so many motors before I figured out magnetic neutralization. Now I have applied what I learned to BOTH machines. The other major difference between the two machines is the six machine has two sets of magnets on the rotor. It has the N/S magnets that go past the coils and ANOTHER set of magnets out closer to the rim that are all N on one side and all S on the other. These interact with a set of adjustable magnets on the stator, so there is a north magnet on one side of the rotor that interacts with a north magnet on the stator and the opposite side of that magnet on the rotor is south and interacts with a south magnet on the stator. Because the rotor and coil holder must be bigger to accommodate the extra magnets, and it uses 3 times as many magnets, this machine is MORE expensive to build, and I felt it wasn’t worth talking about. The 5 machine takes advantage of the fact that with five coils evenly spaced, and an even number of magnets on the rotor, when a magnet on the rotor is aligned with a coil, the magnet directly across from it on the rotor is aligned with an empty space BETWEEN coils, so I could put repulsive magnets there. BUT, this required that the rotor have all North magnets on one side and all South on the other in order to make the magnetic neutralization work. My thought was that while this may ultimately not be the BEST of the two designs, it is the CHEAPEST and more likely to get people to actually build it. So it is the one I have done videos of and have been talking about for a while now. When I first brought up the generator on this thread it was the 6 machine because that’s what I built first, and it was fantastic with only four coils in it. Definitely COP>2. The problem was, when I tried to add more coils the motor was damaged. But as I already said, this was BEFORE I figured out the magnetic neutralization.
        For all my power output testing I have hooked a 300 watt light bulb to a pair of coils that are across the rotor from each other. So each pair of coils is independent of all the other pairs and connected to its own individual load. I figured some electrical engineer who knows far more than I do about power conversion could figure out how to wire all those pairs to work together.
        As I have said MANY times. This is a test machine. I built it to test size and thickness of magnets to see what outputs the best with 3/4 diameter coil cores. I built it to test core materials to see which produces the most with the least negative effects. I built it to test wire length, size and winding configurations. My hope was that others would build and I wouldn’t have to do ALL the testing on my own.
        • Thanks Turion,
          The original 6 coil pair machine must have been very large to accommodate the extra set of magnets. How large was the diameter of the rotor?
          Is there much performance loss with all the same pole magnets, Like is it really worth building?
          I know also its also alot more challenging and dangerous to build a large rotor and coil holder.
          • Comparison
            There is NO loss in performance PER COIL between the two machines. One machine has 10 coils and the other has 12, so there is a loss in total output. All magnets do is induce flux in the coil. N/S rotors vs N/N rotors seem to produce the SAME amount of flux. There is a “virtual south” between two N/N magnets. The biggest issue with any of these machines is that the cores can become slowly magnetized when sitting still, so I remove my rotors when they are not going to be running for a while, or disconnect all loads and let my rotor slowly rotate.
            I can’t measure the rotor on the big machine as it is in for testing and some work at the machine shop in conjunction with the tests. , but it was about 12 inches in diameter. From the experimenting I did, I would recommend 1” between any magnet on the rotor and another magnet.
            • Turion,
              That's good that no matter what configuration the power generation is the same for either set up.
              I am wondering if you have ever tried to use 20mm or 3/4 inch diameter magnets in your rotors rather than the 1 inch ones and if so what kind of differences in results you may have found.
              • Magnets
                It isn’t the diameter of the magnet that gives you the generating capacity, it is the MASS If you go to a smaller diameter magnet you can actually get MORE output by increasing its length. This makes a thicker rotor, but a thicker rotor has more stability.
                • Coil Question
                  An open question to the forum...What is the most power in watts you have been able to generate from a coil, and what was the makeup of that coil. In other words, how many strands of what size wire at what length. What size rotor with what size magnets turning at what rpm was used.
                  • My personal experience
                    I have only used 8+1 coils (from TeslaGenX)before the junkyard build.
                    I will have 6 units to replace.
                    Each unit has 2 coils in parallel per circuit board.
                    The units run cold and no trigger resistor.
                    Each board holds 8 transistors.
                    The magnets are 2x1x1/4 inch N52 and two are used per set paralleling the coil middles.
                    I don’t know the watts but the working units charged my 1110 amp hour battery bank in about 12 hours from total discharge of about 9 volts, but I never let it go that low because it ran continuously to power my home.
                    I have 4 inverters that are 30/30 apiece.
                    So what is being used?
                    The coils side by side with a pair of magnets on one 2x4.
                    See the damages inflicted upon the build?
                    The circuit board is on the backside of the coil build.
                    • Pothead, What do you mean by "4 inverters 30/30 apiece". I've got a big inverter (and other small ones ) but can't decipher what 30/30 apiece is about.
                      • Sorry
                        Hello ewizard, sorry about the confusion.
                        • Final Build
                          I am building one final version of this generator.
                          I am ordering parts sometime in the next 30 days as I get my list together of all the parts I need. I will be able to consolidate a lot of things because I will no longer need to leave room for taking coils in and out of the design. Once they are in, they are basically in to stay.
                          It will be the final build of the generator for several reasons. First, the only thing left was to see if a different core material produced equal flux with less heat. I no longer care about that. I have seen that a water jacket will keep the cores cool and the generator can be used to heat water while it is running. Next is that this machine running on a PROPER 3 battery system or even the single battery circuit is everything I wanted to accomplish.
                          Finally, as I have seen what is possible with the 3 battery system this kind of tech has simply become outdated. There are more efficient ways to produce power and I want to spend my time with that.
                          As I add parts, I will update the list below. I just wanted you guys to see that I put my money where my mouth is on this stuff, and I wouldn't put out this kind of money for something that doesn't work. Or would I? Am I really THAT crazy?
                          The new rotor I am building requires 24 of these:
                          Rotor Magnets
                          $527.76 plus shipping
                          Just a moment...
                          A New rotor just over 4” thick from 4.25 stock.
                          Acetal (polyoxymethylene) is a high strength, low friction engineering plastic that has excellent wear properties in both wet and dry environments. Easy to machine, acetal makes an outstanding choice for applications that require complex, tight tolerances.
                          ePlastics is a full-service plastic distributor and fabrication company serving customers throughout the United States and around the world. With over 100 years of experience in the plastics industry, ePlastics is a one-of-a-kind plastic supply store for businesses of any size.
                          $268 plus shipping
                          Five of these
                          Buy 23 AWG Essex Magnet Wire in a 9 LB Spool. High-temperature copper winding wire rated for 200°C, ideal for electrical applications. Explore durable magnet wire at Magnet4Sale. Order now!
                          $595.30 plus shipping (Actually a couple bucks cheaper than the wrong one I posted previously
                          3 of these
                          $33.84 plus shipping
                          keywords=5%2F8+flange+bearing&qid=1561216018&s=gat eway&sr=8-8
                          4 sheets of plastic 14 x 14 x 1
                          $310.88 plus shipping
                          Click now to shop from our selection of CHEMCAST GP acrylic sheets today to find a super thick solution for any application. 48" x 96" available up to 4" thick!
                          Base sheet 14 x 30
                          $166.54
                          same supplier
                          Two Inside 1/4 sheets to retain coil
                          $39.20
                          Same supplier
                          Spacers
                          Stainless steel bolts, washers, nuts
                          bobbins
                          core material
                          epoxy
                          • Thanks Dave, you are making history with this build. The possibilities
                            are greater with a core that can be changed? And the heat issue
                            sounds like you might be able to heat a tiny hot water heater something
                            tank to wash your hands with in the shop. I like water cooling better
                            anyway. All generator have some form of cooling @ 2000watts.
                            Thanks for sharing the price list with the specific parts list. It is an
                            exciting opportunity that I am glad you have chosen not to miss.
                            Sounds like more than a 2000watt machine actually but 28awg?
                            • In tribal and or family issues, to tell the tale to seven witnesses and then they tell seven others, is how early legends and history was established.
                              Since Turion is telling the tale, it will be told to the several others who are of this tribe and or family.
                              This is my way and this post waits for all the details to follow.
                              Please tell more of your tale Turion so even the newest member can bear witness.
                              • Turion wrote:
                                Five of these
                                $598.25 plus shipping
                                https://www.amazon.com/Magnet-Wire-S...y&sr=8-2-fkmr0
                                Is this a typo? Didn't you mean 23awg?
