3 Battery Generating System
This topic is closed.
Good initiative!Originally posted by axxelxavier View Post@All,
Just another quick update on my Battery swapper project, HERE
The wiring & all setup was simplified, a relay initialization bug was solved (all relays was ON at Arduino Boot for about 2 sec!), and a simple stopwatch is showing on the OLED display time passed, for comparing working cycles.
Now it's time to focus on conditional voltage loops...
Best regards.
P.S. Now the link should work
Why don't work on a 3BGS battery swapper in line with Dave and Matt first?
I can sponsor you for any parts you might need for this.
3 Battery problem.
The potential is the voltage differential between the power and destination battery. For example, the power of 12 volts sent to a receiver battery of 6 volts only has a power potential of 6 volts. The charged battery depletes and the receiver battery rises in power, so the potential difference drops at an accelerated rate, faster then the power would dissipate from a positive to negative ground. When the batteries draw close to each other in charge, there's hardly any relative power potential difference to run system.
I'd like to try the 3 battery system with my oscillator, but I can' imagine how I can get it to work for any considerable length of time.
Thank you for your encouragement! Actually, this will be the next step, because I have also 3 batteries, and using of a dc-dc booster in the 2 batts setup involve, inevitably, some loses. I have also, an MY1016 waiting to be winded.Originally posted by Majestic81 View PostGood initiative!
Anyway, the battery swapper for 3BGS setup looks a little more complicated, but I think it can be done.
I send you, also, a PM.
Best regards,
Teodor
No problems whatsoever.
@Allen
I have seen that after having my batteries unused for few days, then the first round I start with the 3BGS setup, only then, the voltage rises relatively quick. But even that time, I get to use it, quite a long time before I have to switch. Every next round can last many hours before switching. So there is no problem of time whatsoever with this setup.
#4168 Randy made a very valid suggestion.
What do you want on the generator? I am very busy but I am also trying to put together a generator that is relatively cheap to build and can easily replicated.Originally posted by Majestic81 View PostHi Turion,
Would you be able to reshare a link to your post of the generator?
Thank you,
Ray
What is it you need?
Matt
My need is to completely replicate your system in a 1KW/2KW range and further learn from it and make it available to a greater public.Originally posted by Matthew Jones View PostWhat do you want on the generator? I am very busy but I am also trying to put together a generator that is relatively cheap to build and can easily replicated.
Matt
I don't have much time myself to build, but I like supporting other builders.
I am a great admirer of your work for the past years.
Diminishing return
The action of the oscillator is very easy to gauge. The basic problem with the 3 battery system is that the voltage closes between the source and receiver batteries, so the power grows steadily weaker.
Let's say we have two 6 volt batteries in series to a third split positive 6 volt battery. Now, after running awhile, we measure the voltage and find 10 volts in the two source batteries and 8 volts in the receiver battery. That leaves a potential difference of only 2 volts. We stared with a potential difference of 6 volts.
This wearing of power strength is very noticeable in the oscillator, but would require torque measurements to factor in to an over all COP.
The 3 battery procedure lengthens run time but only at the expense of steadily decreasing power as the voltages loose their potential difference to each other.
A few options
There are a few ways to deal with this that have been mentionedOriginally posted by Allen Burgess View PostThe action of the oscillator is very easy to gauge. The basic problem with the 3 battery system is that the voltage closes between the source and receiver batteries, so the power grows steadily weaker.
-Use big batteries
-Rotate batteries
-Use a boost convertor to output a steady voltage (see picture)
Alex
