Proof
Both of the videos above have been around for a while showing that what we are saying about the motor and how this system works is true. The video Matt just posted is YEARS old. Because someone hasn’t seen it doesn’t make it any less true. There is plenary of proof out there for those who look.
The line between success and failure on this system is very thin. The right motor, a BIG deep cycle battery, large wires and the right generator. A more efficient boost module really gets you over the line, but the $3.00 one will work to show you what is possible and THEN you can improve your system.
The big enemy in getting this to work perfectly is the impedance in the battery you are trying to charge. Bigger, higher quality batteries have LESS impedance and are more forgiving. I keep saying this over and over, but it is not ONE big thing that makes this work, it is a lot of little things. The wrong motor kills it. The wrong battery kills it. Clip leads instead of large wires kills it. You MIGHT get it to work with one or two of those things wrong, but we make NO promises.
Build it correctly and you will get the correct result. You get out of it what YOU put into it. With everything else correct and in place, when you add the correct generator, which speeds up under load casing a reduced amp draw on the motor, and has NO magnetic cogging to cause any increase in amp draw on the motor, you get the COP numbers you have only dreamed about. It is that simple
We gave you the circuit for free. We gave you Matt’s motor for free. We have given you the generator design for free. And what did we get in return? Researchers eager to explore a new idea, build something new and take a concept as far as they can take it? No. We got people insisting this doesn’t work and we don’t know what we’re doing. People insisting we prove every step over and over. Where is the drive and curiosity that keeps Matt and I looking at this stuff from every possible angle? We’ve got a bunch of people that spend all their time spouting theory and a bunch who have to be spoon fed everything because they are incapable of taking a risk in order to see anything outside the box they live in. There are those who have built this and know it works. Those who haven’t or won’t have exactly what they deserve, and no amount of intimidation or coercion will change my mind about THAT. I’ve spent thousands of dollars on this, and somebody who won’t spend $40 to rewind the motor is not deserving of my respect or consideration. Period. You have no idea how many times I have mailed off stuff to people who were committed to this but just could not afford it. I paid the $30 for the motor and the $20 for shipping. Unless it was to someone in Africa where it cost me almost $150 for shipping. But in that case it was motors and boost modules and wire to rewind. So I PUT my money where my mouth is and have no respect for those who won’t. None. You claim to be researchers. Get off your ass and research. The whole premise behind research is you build something HOPING it will work. Do you think I KNEW my generator would work before I built it? Get real! If you’re not here to do RESEARCH, go join a cooking forum where they give you and exact recipe. Or maybe a knitting circle.
