  • Ufopolitics
    Yeah, it was also what I said to myself...
    Thanks UFO, you once again have posted what my next dumb question would have been, how do you keep doing that?
    Regards Cornboy
    Yes Cornboy,
    I had the Solution...I discovered...that was what brought me to this in the first place...but seems like too much winding...too much amps and RPM's got me distracted from the original issue here.
    Now just replace that FET by Our Commutators...set all Coils independent connections and we have same thing reproduced at each one...
  • Cornboy 555
    Thanks.
    Hello to All,
    @John Stone, Hello John, now related to MOSFET's and Heat sinking...I believe making Four Separated/Isolated Thick Aluminum, with Fins Extrusion Bus Bars, would do excellent here...We will connect our Four Drains through nice bolts and Six Gauge wires there...
    All Four Bars could be bolted on through Mica or a Heavy Insulator to establish a nice Single rigid Structure...Cooling Fan will send air through them.
    I have Factory Controllers that use the small plastic washer insulating FET's Plates to touch aluminum...and the Sink Cream...they do not work as well as strongly attached the whole metal back wall to metal aluminum walls...never as it also serves as the Drain Conductors.
    Now related to the Imperial Heavy Sparking...and so High Amperage...I would like to refresh the "Past" a little bit here on this Thread...so anyone now would be able to discern where I am heading towards...
    Remember this very simple graphic I displayed about the beginning of this thread?
    It was the way we were able to get out of our Pulsed Coils...the Radiant Energy, the Spikes...or the C EMF...whatever you guys decide to call it...
    Now, on the Imperial I have tried to set a couple of NTE 576 at Input...INLINE, in order to rectify the reversed currents...not even as soon as I connect it...they blew out, I mean, cut in half like with a laser knife...
    I tried heavier ones...same thing...
    Now...IF We connect them the way I have displayed so long ago...they will not blow...and they will re route those currents out to a load...like we did before.
    Now at Imperial we are talking about very fast moving coils...however, they always "return" full of that reversed charge back to our Input...
    So, when we set diodes at Input say P1-P15...We are getting through Diodes the reversed currents generated at P8-P22...Capisci?
    And so on my Dear Friends...the reversed flow from P1-P15 would be collected by diodes set at P8-P22...Or if we want we could set them individually at each gate...say P1...and at P15 separated set of diodes...depends how we will be driving them with FET's Channels...
    All this arrangement for testing purposes we are doing it outside...but they could easily go inside the Brushes boards...
    All Reversed Flow could be connected in series to send it to a discharging load...To Charge Batteries or even to run a cooling Fan...automatically regulated by the speed we are feeding in...
    I will make a video on this...as I will also make the diagrams.
    Regards to All
    Regards Cornboy
  • Ufopolitics
    Hello to All,
    Hello to All,
    Regards to All
  • qvision
    Great info John Stone.
    They are very well specced.
    They are also currently in stock with uk Farnell !
    http://uk.farnell.com/jsp/search/productdetail.jsp?sku=1095710&CMP=KNC-GUK-FUK-GEN-SKU-MEDICAL&mckv=sK6PWeeGW|pcrid|13361272629|kword|spw 52n50c3|match|p|plid|
    RS also has them but you have to buy at least 25, so i assume they are ordering from the US :
    Buy MOSFET Transistors MOSFET N-Channel 560V 52A CoolMOS TO247 Infineon SPW52N50C3 online from RS for next day delivery.
    All the best,
  • JohnStone
    Those FETs are not the ultima ratio. My concern is:
    Cool Design:Voltage:
    We want to have about 48V operating voltage (max.) pulsed with high amps. This generates quite high voltage spikes we do not want to kill. It is of less use if we build a serious pulser with i.e. 75V of UGS. They will soon pass away and need replacement. We need to negotiate for voltage as well.
    Unfortunately those spikes produce serious backlash to the gate via internal capacitors. This is on reason again to use strong drivers in order to pertain fast and cool switching.
    There are so many conditions oposing to each other. I struggle to get a well balanced design with less drawbacks.
    Current technology:
    Usually high voltage FETs come along 1...2 OHM RDSon. That is not what we need.
    But fortunately Infineon brought the coolMOS technology to us. This technology brings low RDSon along high voltage and fast switching. So we will not suffer on usual drawbacks.
    Examples: SPW52N50C3 and SPW35N60CFD
    They can be bought i.e. @ Farnell or eBay in US.
    The components are not cheap but we need few of them per switching channel along fewer drivers.
    Nobody is forced to use these comonents. In fact any FET can be used but everybody shall know their drawbacks.
    Idea for heat sink:
    What about using scanvenged CPU coolers out of PCs
    i.e.
    Unfortunately the Drain is contacted internally to the cooling surface. We need the FETs insulated or using 4 different cooling sets for the 4 phase pulser.
    JohnS
  • qvision
  • qvision
  • prochiro
    I like it more
    @JohnStone
    The IRFP4137PbF fets looks closer to what I am seeing in other high output circuits. When looking at other circuits I see that Volts are somewhat less but Amps are as high as 150 with with 50 to 75 amps as an average. It seems to me (and what do I know) that having an overkill on fet amp capacity may be the stabilizing factor of importance. An example would be a BUZ11 fet is a 30A/ 50V/ 0.040 Ohm/ N- channel power mosfet which is for a 30 volt system. We need more but it is maybe an example of a ratio of amps to out needs. Again ( what do I know).
    Dana
  • Ufopolitics
    Great Find!
    This is my enhanced circuit diagram.
    (DRAFT)
    I choose a 9A driver with 20ns transistion time. Alternative: dual 4A. I suggest to drive not more than 2 FETs from one driver. Do not confuse 9A as steady current - it is for 20nS only.
    The driver requires to get at input a transistion time less than 200ns. Optos do not fit to this requirement. Therefore I choose two consecutive 74C14 schmitd triggered buffers inbetween in order to feed a well conditioned signal to the driver.
    Thorough wiring will be necessary. In fact a PCB would be of great advantage.
    Please note: this is no tinkering circuit - it is high speed and will not forgive wrong wiring.
    Not this:
    but this:
    BTW: What about this FET: IRFP4137PbF
    VGS: 300V
    RdsON: 70mOhm
    about 30A continuous / 150A pulsed
    Above 300V the RdsOn will increase considerably.
    Hello John,
    Eventually, even after building it...we will find many new upgrades to be made here...in order to enhance performance...so..it is Ok to change/upgrade and get better as faster stronger components here...
    Now that is a Beast of FET !!...Definitively MUCH better than the IRFB4310!
    Excellent find!
    Regards and many thanks John!
  • JohnStone
    (DRAFT)
    Not this:
    but this:
    VGS: 300V
    RdsON: 70mOhm
  • JohnStone
    Ufo requested for his current setup a four phase oscillator.
    Post
    Post
    I threw some components into the circuit and ask for discussion. It is what I intend to build.
    The reason for using a microprocessor is because the circuit with logic ICs is lots of wires to draw and one use only. A micro is much more precise and versatile to use.
    @Lester: Some suggestions for i.e. snubber circuit? Suggestions for additional protection?
    @Nico: Arduino connected correct? What about modified program? Where did you connect your POT / LCD exactly?
    TBD:
    • 555 NMOS (slow but 200mA source sink at output) or CMOS (fast but 8mA only) - needs to be tested
    • Control for dead time and frequency: Pot, digital pot or by simple terminal program from PC (USB)
    • Display required?
    • Option for current measurements required?
    • Use of reset at pin at 555 in order to prevent unintended firing of FETs while program downloed and aother actions.
    With some additions (voltge feedback) this circuit can peform as SMPSU - not high end precision PSU but suffitient in order to control the voltage for our loads from battery stack or welder. It depens on your requirements and your setup.
    JohnS
    I pondered on this circuit for some days and I confess it was posted too hasty. It is good for low scale FET applicatrions but owns some uncertainities and limits. At serious applications like driving 56 frame any failure sacrifieces not a single FET on desk but might damage the whole circuit or worse. I do not bore you with details - except if requested. Remember UFOs pic from his bike controller burnt in the other thread! We want to prevent this and worse incidents.
    I dare to rise the price of the 4 phase controller by about $30 for ultimate components because it is few money compared to the price for the whole motor/gen setup.
    You will get a driver stage of utmost quality, fast switching and low loss. But please be prepared the backlash of fast switching will be high voltage spikes and thus we can't use FETs being limited to 75 ....150V. They will be killed. And because of aiming to radianat we are not allowed to kill those spikes.
    SHE likes such demanding environments and will be attracted visiting your home . Don't know on how you are going to explain this to your wife!
    First of all I'd like to ask you if you can buy these components in your country. UCC27423 is a fast dual 4A FET driver from Texas Instruments.
    Is there anybody prepared to draw a PCP layout for my circuit I will propse later on? Replication will depend on proper dedicated wiring.
    JohnS
  • JohnStone
    Post
    Post
    TBD:
    • Display required?
    JohnS
    Is there anybody prepared to draw a PCP layout for my circuit I will propse later on? Replication will dipend on prper dediated wiring.
    JohnS
  • qvision
    There are many missing links here, usually your facebook links, UFO, but also some posts where you say "here is a clearer schematic" but there is no picture in the post.
    I see a secondary coil being mentioned a lot but, so far, no pictures.
    I am only on page 22, will i discover all these things as i read on or has anyone put all this information into a single document yet ?
  • qvision
    I've ordered these :
    HFA16PB120 Ultrafast Soft Recovery Diode, 16A IC | eBay
    I will just have to be patient
    All the best,
  • qvision
    Can someone in the US post me a couple of these diodes please ?
    I will pay you via PayPal before you send.
    Having a real hard time finding anything comparable, apart from this :
    DIODE, ULTRAFAST, 16A, 1200V, Part # VS-HFA16PB120PBF | eBay
