  • qvision
    Well, that was easily answered - the neon bulb got hotter and hotter ...
    Anyway, here's a pic :
    So has anyone done power out measurements on a scope ?
    How do we know the difference between plasma and RE ?
    I have ordered a cheap USB scope that only goes up to 8KHZ (it's all i need right now) but surely someone in this thread has a decent scope and can take some power measurements ?
    All the best,
  • qvision
    I decided i couldn't wait for my stuff to arrive from China so i went with what i had.
    1. DC PSU, 18V @ 2A.
    2. A decent PWM (rmcybernetics OCX).
    3. A 4ohm coil of 0.5mm wire.
    4. Two 1N4001 diodes.
    5. A small neon bulb.
    So no need for making a PWM, no need for voltage regulators or transistors.
    And guess what ? Purple-white plasma in the neon bulb !
    I see this occasionally in my SSG cicuit. I know very little about electronics/energy etc ... i've only been experimenting for 2 years or so and last year i was almost completely inactive ...
    How do i know if this is cold electricity ? What tests can i do ?
    Should i put a resistor at the output instead of a neon, or will that turn it into hot electricity ?
    How can i know for sure ?
    All the best,
    nibs.
  • Lester444
    Sorry but I need to correct my diagram. Please add the 1k resistor shown (red arrow). THIS CIRCUIT DIAGRAM IS NOT FINAL.
    Lester
  • Lester444
    Hello Cornboy,
    That's a HUGE motor you're making!!! Lotsa amps so you definitely need some protection for the FETs.
    The last circuit I posted is for sensing an over-current condition, or, some other preset current not necessarily an overload condition. I am thinking this would be good for your application but let's wait for JohnStone's comments.
    I like they way you think BIG!!!
    Lester
  • Cornboy 555
    The Fog will lift.
    Thanks for all your great info on FET's John, i am beginning to see the picture now. It appears that 12V is sufficent as long as there is plenty of current from the driver. Also ultrafast switch off is very important for max Radiant out.
    I can't find the UCC drivers here in OZ but have located some 12A drivers and will post specs for drivers and FET's for your advice and guidance if you would be so kind. Also would the FOD's be good opto's for your latest circuit posted? and how would you connect a vane hall sensor to them?
    I too still have a lag of understanding of your question to UFO.
    I visualise that multiple pulses to a rotating rotor coil, per commutator segment on time, would create a negative force to rotor until rotor came up to speed of pulses, but of course that is from my very limited understanding of what really happens.
    I'm sure UFO will clear the fog on this for us.
    Warm Regards John Stone.
  • Lester444
    @ Lester:
    1. I ask if it would be advisable to introduce a current sensor in order to protect the drivers. At max. current adjusted the driver will switch off up to the next trigger.
    Hello John,
    Looks like we are going into hyper-drive now: High-power / high-energy circuits. We should approach with caution!
    That's a great idea you mentioned above. I'm not sure if the Arduino will be fast enough (SW is slow) so I am suggesting a hardware implementation
    of the current sensor. This is one possible way to do it: (Resistors waste too much power)
    A small toroid is wound with multiple turns for the secondary, and the primary is a single large wire that goes through the center of the toroid.
    This is a current transformer (like a clamp meter ) and it "senses" the current going through the single wire in the center of the toroid. The current (yes current) coming out of the toroid's secondary is fed across a resistor (turns-ratio & resistance determines Vout) and the resulting voltage drop across the resistor is fed to a comparator to compare vs a pre-set voltage. The comparator's output may then be fed to the reset pin of the LM555 so that once the preset current is exceeded the pulse duration is cut short (FET drive is turned off). I have drawn the circuit to show you what I mean.
    2. If we apply higher gate voltage we can switch on faster but NOT OFF. The FET does not care if it dies because of overheating from switch on or off.
    As always there are tradeoffs. A higher gate drive voltage results in lower RDSon (good, cool FET), but then the signal will have to slew through
    a wider voltage (18v for example) and that's additional time required for turn-off (bad?) as compared to 12v. The delta of 6v (18v-12v = 6v) can result in 50% more turn-off time relative to 12v (18v/12v = 150%). That may look bad but it may not necessarily be true, because now the di/dt of the coil is slower also, and that results in a lower spike voltage, perhaps hundreds of volts instead of thousands of volts. No snubbers at all, but provide a path where the stored energy in the coil can go to AT ALL TIMES.
    But if you're trying to make a spark (as in an automotive ignition coil) the fastest turn-off time for the FET is definitely the way to go.
    Lester
  • Cornboy 555
    Cornfused.
    Originally posted by Lester444 View Post
    Hello Cornboy,
    I have no idea what coil you are going to drive with this. If it goes directly to the motor you must consider that a motor's winding consisting of a few turns of wire is actually a DEAD SHORT-CIRCUIT until the rotor spins. Depending on your power supply's or battery's current capability you can easily blow a FET in the split-second after you apply power but before the rotor spins. That's the danger with letting the vane determine the pulse width.
    For the first trial I would go with a fixed-width pulse driver, just a few micro-seconds initially, to allow the rotor to accelerate from standstill. Then increase the pulse width for more rpm or load regulation. Give more details of your setup/motor so we can understand your application better. At this point the Arduino seems to be the best way to go although I'm not sure if there are still un-used ports to get the signal from a hall sensor.
    If I had 18v supply I would drive the FET from that.
    Lester
    Sorry Lester, my application is a scratch build of UFO's Magnificence of 3 6 9 posted on motor thread.
    36 pole, 3 input brushes, 3 output brushes, on both ends, 6 stators.
    Since my main interest is in EV propulsion in am starting with a prototype build of a motor i am hoping will be approx 15 - 30 HP.
    Rotor is 190mm dia and 200mm long, and stators will be wound coils, not PM's,so it can be scalable to larger sizes.
    In order to achieve radiant output from stator coils, they will be pulsed, but at first the pulsing will be shaft timed for the coils ON time. The design i am using for stator coils-cores will also allow for secondary coils at a later stage.
    Also to start with the rotor coils will be commutator driven.
    Later i will take the plunge of pulsing both rotor and stator in parrallel, but for now, eventhough UFO has explained it to me, i am still trying to fully understand how possible multiple pulses per commutator segment on time would effect performance.
    Soooo, the electronics i will need will have to be at least as robust as what JS has posted for Imperial or heavier.
    As i am waiting on laminations to arrive, i can't give you any coil spec's but i will try to stay above 1.5 ohm on rotor coils and probably about a total of 9 ohms on stator coils when series connected.
    Hope this makes my application more clear to you Lester.
    Once again sorry for any confusion.
    Warm Regards Cornboy.
  • qvision
    Didn't get much reading done yesterday, i hope to finish the thread today !
  • qvision
    @ John Stone
    Thanks very much for the info JS
    All the best,
  • JohnStone
  • Lester444
    ..... and if you think there is a way to make it any more bulletproof, as in seperate earth from mosfet's etc, please let me know.
    Hello Cornboy,
    Lester
  • Cornboy 555
    Deeerrrr!
    Thanks Lester, that would be great, i would like to control the time-on to the stators on MAG3-SB (scratch build) by altering the metal vane, something that is completely tangible for me.
    I think the hall sensor will be able to handle the required RPM, they are used in automotive for 6 and 8 cyl up to around 6000 RPM.
    Thanks Mate, Cornboy.
    Sorry Lester, i read your post too quickly, the circuit you show is what i need, red power in, black earth, and green output.
    Thanks, and if you think there is a way to make it any more bulletproof, as in seperate earth from mosfet's etc, please let me know.
    @ John Stone, and all, would it be an advantage to supply gates with 18V instead of 12V, for fast overcoming of capacitance and hard switching?.
    Thanks and regards Cornboy.
  • Cornboy 555
    Great.
    Hello Cornboy,
    Here's JohnStone's circuit, modified for use with a hall-effect sensor. The vane's width dictates the duration of the pulse.
    Alternatively, you can wire the LM555 as a monostable (fixed pulse width) and use the hall to trigger it at pin 2 of the 555. If you intend to go this route I can draw it up for you if needed.
    Have fun!
    Lester
  • Lester444
    The data sheet is on their site and if you happen to be designing a circuit to use them for pulsing mosfets, it would be greatly appreciated if you could share it with me.
    Hello Cornboy,
    Have fun!
    Lester
  • qvision
    Are these parts ok ?
    Would someone to tell me if these parts are considered to be ok.
    The diodes :
    HFA16PB120 pdf, HFA16PB120 description, HFA16PB120 datasheets, HFA16PB120 view ::: ALLDATASHEET :::
    The transistors :
