Lol Fuse
Hi Dog-One
Yes of course well I am using one of my 3 variacs
Also what might interest you is to look at the last post i made of Thanes 169vac primary.
The point it 40 turns of thick wire is not going to cut it. That is for a switch mode design. Like a pass transformer approach.
I am going to try 23awg probably 2" dia coil 1/2" X 5/8" so we are looking at a primary similar to what a standard transformer coil would need.
Just a standard set of coils using ferrite instead of iron to see what Thane saw. Look a few pages back and you will see the video of Thanes experimental setup. It has 3 huge coils so large they are almost touching.
The primary is so thick with windings is reminds me of a normal sized coil for AC, and it is.
Did you see THAT video? Or are you only seeing the THANE stuff in other BiTT setups?
Look close, they are not all the same.
Then I can turn around and pull the primary when I want to run switch designs. I need circuits for that. Pulsed DC will do very little so I need an AC inverter that has a variable frequency.
Most of the VFO circuits around are 400hz. This is unacceptable.
I the mean time pure sine wave does exist coming out of the wall so the bigger coils are required.
I always use either a huge wirewound resistor with multiple taps or a variac to inch up to the voltage watching the amp draw.
Yes good insight for any beginner. Don't wanta smoke all yer goodies in a NEW YORK minute.
What do you think about that Dog-One? Did you see Thanes big windings. I put a large picture of Thanes windings up but sometimes people see these pictures and they are not sure of the purpose.
Let me point out that Thane stated in his video that the experimental data he was exploring centered around using straight AC off the wall. The input coming off his variac straight off the wall was 169volts and if I remember right something like .32 amps? I think that is right.
So looking at the spool tells me he uses a long enough piece of wire to use wall current. Now that is one big roll of wire dudes.
Mike
Hi Dog-One
Mike
Originally posted by Dog-One
pretty awesome I'd say since I will be spending most of my time doing that.
we can't have it smoking now can we?
