  • Count me in for half
    S
    I'm putting quite a bit of stuff up for sale this weekend.
    I should have some scratch by monday.
    I leap of faith...
    Count me in for half if what Tektron posted is correct[seems like it has to be]
    Chet
    BE that change !!
    • Thanks!!
      Thanks Chet!!
      • Did you get the tools?
        They should have been delivered today?
        Chet
        BE that change !!
        • Got Them
          Thanks Chet, they arrived today. We'll put them to good use.
          Chet
          • Oh yes we will
            The more I study The Davey device ,The more I like this whole concept!!
            And I really like Mr.C's rendering ,Well actually I've heard somewhere
            that this is really someone elses work from the last century!!
            A very Big Guy....................
            AnyHoo I think we will be putting the tools to good use!!
            Very good use!!
            Chet
            BE that change !!
            • Your Tools
              They are incredible. They make all the measurements a piece of cake and with a click of a button you either have mm or inches. They are great. My 302 stainless that I cut for my new ring turns out to be .8mm and not .5mm, so that may make a difference. I was using a meter stick for my width measurement and got it a little off too. Hopefully I get the new ring rolled sometime this weekend for testing early next week.
              • These tools make this doable
                The game changer for this particular replication!
                the reason I prefer this replication over the Davey device is the measuring!
                I can't figure how to measure my way thru a Davey replication?
                This device is a whole different story!
                And also this device has history that predates Mr.C !
                He just figured a cool garage mechanic approach to an easy cheap replication
                And perhaps a little reason to empty the beer cans??
                I don't imbibe so I will be a lot more frugal with the cans!!
                Chet
                PS
                They're not my tools they're you tools now!!
                PPS
                the Laser therm is a very useful tool for all kinds of things!!
                BE that change !!
                • Thanks!!
                  Chet,
                  Thanks very much for the tools. I had planned to send them back to you following getting this projects prototype up and running. Thanks very much!!
                  I'm pretty sure Mr. "C" knows how to do a lot of things besides heating water with this tech.
                  Best Regards,
                  Slovenia
                  Chet
                  PS
                  PPS
                  • A few more things
                    Some thoughts and an offer!!
                    1st the thoughts
                    It is obvious that the frequency, the device and the water all play roles in a successful replication .
                    Since you and I are stuck with the mains as our Driver
                    We will be limited to the device and the water for tuning
                    Yes Tuning the water too......
                    I believe we will be playing to some extent with our water ,I have read where a man in serbia is using potassium in his water ?
                    I think we will need a benchmark for our water too... PH ,specific gravity
                    and any other way we can establish "conductivity"[suggestions???]
                    To spend all this time "tuning" then drop it in the water fire it up and Nothing happens...........
                    Well the heck with that
                    play with the water ... then drop it back in!!
                    Or have several drop tanks!!
                    If nothing still ,well time to tune the rig again rinse and repeat!
                    These things will be important for Core also IMO!
                    If we record all data , it will be much easier for this community to
                    get this figured?
                    Plus of course our ace in the hole "Mr.C"??
                    @The offer
                    My friend boguslaw
                    I will also send you the same tools I sent Slovenia ,all you will need is Beer
                    cans and time??
                    You know as well as I do that if we get ANYTHING to happen here that is not just resistive heat
                    It will open many other doors.....
                    [email protected]
                    ps
                    Mr.S
                    Can you measure specific gravity and PH ?
                    if not let me know!!
                    BE that change !!
                    • I'm collecting beer cans Do you know how to easily remove lacquer from outside and some kind of clear dope from inside ? should I do it or it could work without removing paint from can ?
                      Chet
                      Thanks for kind offer, but I think somebody should do it without exact measurement , to validate if that works just by idea or only by strict positioning of elements (I'll make s close as possible to required diameter and gap using only hand tools). I have only simple hand tools sometimes very crude , that means a lot of time to build anything .Anyway if I could make some OU thing that would mean EVERYBODY CAN - that's the concept (because I am also the worst builder I know )
                      What I really need is the insulated stainless steel rods or something like that to electrically disconnect terminals from metalic water container or just an idea how to do that from scrap parts. Something like threaded SS rod sunken into piece of plastic also threaded from one side and which stand for boiling water temperature....
                      • Yes you described it {insulator]
                        Laquer thinner to remove laquer.. fine sand paper and elbow grease if that doesn't work!
                        I believe the idea for using beer cans is so ..."Every body can" Replicate!!
                        Really good source for beer cans!
                        boguslaw
                        I believe you are completely correct we don't have to stick to the PDF for this effect to manifest! That being said ,I cannot take that leap of faith and build something Ground up!!
                        This man has it working ...It is a replication of a very very very prominent
                        mans work from the late 1800's early 1900's
                        And I am sure Mr.C wants to see Slovenia get this working ,and will help in all manner of ways to insure he does!
                        Thats good enough for me!
                        The reason I made the offer to you is I know you have limited tools,
                        I also know how difficult it can be to have to improvise without resources
                        Plus I believe You "get it" about Open Source... and you are a really cool guy.
                        The offer stands................
                        Your Friend
                        Chet
                        BE that change !!
                          You could try baking can in a 450 deg f. oven for an hour. Let it cool, fill with some sand and shake.
                          • Very cool idea ..........{ Heh Heh ]
                            TEKTRON
                            Nice!!
                            To quote Dole [TK thread]
                            "but historically at the end always come very bad music form a one man music show."
                            Thanks for being part of the band, we're gonna make this baby Sing................
                            By the way ,You just added a very good dimension to this device {material density.hardness Tune],In my opinion the only reason Mr.C used a beer can is the Guage is so thin that it reacts with the frequency,like a soft diaphragm!
                            If we annealed [700 f] a larger wall tubing to make it softer it would probably do the same thing.[well of course it would]
                            Just thoughts for the future ........
                            See The other Device "Davey's ,,He started to explore the idea because of his nightime airplane rides, he would
                            play with the throttle and get the cabin to resonate in such a way that it made heat.........
                            I believe once we figure this out... we could also make some heat in the air with resonance [space heaters]
                            We could really use that!!
                            Chet
                            BE that change !!
                            • Remove Paint
                              Boguslaw,
                              I haven't tried it on the beer or pop cans, but brake fluid or carburetor cleaner will remove paint from a car. I've gotten them on my car before. The carburetor cleaner comes in a spray can for cleaning out the carburetor and/or oil and grime from around the carburetor. It is very incredible stuff. I think it contains methylene chloride a carcinogen though.
                              I will try it on the pop can and let you know.
                              Best Regards,
                              Slovenia
                              • Principal
                                Hello all.
                                Can some one please tell me the principal operation of this heater?
                                If mr C could explatn that the bilding of this device would be very easy.
