  • Very important question
    The materials being used in water and the presence of electricity...
    Isn't this Critical? won;t electrolysis destroy the device??
    does anybody here have an understanding of this?
    BE that change !!
    • .2mm Ring Thickness
      The .2mm ring thickness has always bothered me too. I'll go with thicker and see what happens. I have copper too, so I can also experiment with that.
      Very good information!!
      Ring thickness should not be critical. The best imho would be brass ring or copper ring because of low resistance. The water inside gap will be the cause for 5-7 amps flowing.Personally , I believe ring thickness should be higher then 0.2mm which looks even to small for high current and can melt.
      • Ring Measurements
        Hi Chet,
        Thanks again for your offer of the plating material.
        Measuring & Praying
        I wasn't measuring and praying but perhaps I should have been. I figured out the exact length of material I would need for my ring mathematically. Then I added on the amount of material I thought I would need on both ends for my extension to my mounting bracket. I figured out the exact length of material by using the following information. I knew the diameter of my can, so I added onto that twice the gap which was 1.725mm and the thickness of the material twice too. This give you the exact OD of the ring. Now you just half to figure the circumference of the ring and you'll have the exact amount of material you'll need for your ring. Now add onto that length the material you need on both ends of the ring to make your connection point to your bracket. You want extra material on both sides of your ring. So, figure out the exact amount of material you want on each end and mark that measurement with a scribe on your material. Start on one end of your material. Then add the length of the ring and finally the other excess material you'll need for the other end. Scribe both points where you'll need your 90 degree bends. Remember when you make your bend you are going to lose material too. With that information you will have a very precise ring. That's what I did but I did forget to add in the .2mm twice for the thickness of my ring. So, I made a small mistake. But, it's not a gosh and golly sort of thing. I highly recommend this method of measuring out your ring material.
        Tin??
        I just picked tin out of the blue because it is very easy to work with and I had a lot of it handy. Now that I look back, it was a very poor choice. I knew I could bend it easily and also solder it easily. I knew it wouldn't survive under water long but I was looking for a fast and loose method of getting my prototype on line for Mr. "C".
        Ring material by Mr. "C"?
        No, he never mentioned the exact type of material to use other than referring to it as a sheet of steel .2mm thickness and 5mm width.
        You're doing a great job keeping life and interest in this thread!!
        Yes, resist the urge to modify. I've seen modifications get poor results ever time. There's a good reason inventors do things the way they do.
        Best Regards,
        Slovenia
        boguslaw [still getting use to that]
        Well as I start My Build I suppose we will see this in action [adjusting the Tolerance]
        I hope it can be done the way Slovenia is doing it [measuring and praying =.}
        @Slovenia
        Why did you use "Tin" or ferrous metal ?
        Is this critical ?
        Was the Ring material specifically mentioned By Mr.C??
        Mr. C's Format as Perfectly as possible is an absolute necessity!
        One thing I have learned form these forums... As much as you feel you might know a better way ...
        Completely resist the urge to modify anything until you are satisfied you have seen the Affect!!
        What ever he has going on with this device ,we need to see it ourselves and then Move on to .................??
        Chet
        • Critical
          Ring Thickness
          You need to remember to add in the thickness of your material in your calculation of your OD diameter of your ring so you get an accurate circumference figure.
          90 degree bend
          You can make or break your gap with these two bends. If you make your bend wrong, you'll either add or subtract the thickness of your ring material and this will screw up your gap. Remember you have two 90 degree bends to make on both ends of your ring circumference material. The thicker your ring material the larger the margin for error.
          I wanted to make sure everyone understood this. It's very important!!
          The gap is critical and this has the potential of changing that big time.
          The ring is the make or break deal.
          • destroy device
            Mr. "C" never mentioned this aspect. Of course I only asked about how to make the device.
            I've done a lot of hydrogen work with all sorts of different water and the electrodes always suffered over time. I have very hard water where I live, so this will be interesting for me.
            • I'm Impressed
              Very nice solution to the problem! A method still needs to be put in place to Check the Tolerance ,1.725 shim stock and stock both sides of the Gap
              1.700 thru 1.75
              Nice I like your Gap technique!
              You have to get a micrometer for the shims,I'm heading over to look at a job,
              there's a harbor freight nearby ,I'll see what they have [remember seeing them Cheap ].
              If they're cheap enough I'll pick one up for you? [My treat] a laser thermometer too ..
              I have all sizes of shim stock ,but we might have to go with something "Soft"? {plastic Sheet}
              We shall see.........................
              Later
              Chet
              BE that change !!
              • Stainless Steel Ring
                Well, the stainless steel is the way to go but it's no piece of cake. I found some .5mm flat stock 302 stainless in my inventory and have been playing with that. 302 is not my preference, but it was reasonably the right thickness; was stainless; and I had it available. The stainless is very rigid and will make a nice rigid ring if you are handy enough to make it into a ring without warping it. I used my dikes and they did cut it but did warp it a little. I had to go back and true up what I could on my vice and with a hammer. It's a real pain to work with but I will get it done and will have a nice ring to show soon. The wife wants me to paint a side of the house this week, so that is going to jam up my project for several days. I have some other things to do too but was hoping to get it all ready for tests by Wednesday. That probably won't happen now until next weekend. I'm not lazy just very busy with other tasks at home mostly for my better half. I'll keep you posted and get you a pic of my finished product as soon as possible.
                • I picked up some measuring tools
                  I have a package for you
                  E mail Me
                  Chet
                  BE that change !!
                    I've been messing with that ring off and on for several hours now. There's got to be an easier way, but I haven't stumbled on it yet. I know it's going to be a busy week for me this week, so I'm trying to make some headway today since it's Sunday. It would have been nice if I could have had the steel flat cut to my specs but that wasn't possible. They want to much for that and I just had a couple parts to cut. If we get big jobs later it would be well worth it to have it flat cut with a brake. The stainless is rigid and warps easy. Once warped it's almost impossible to repair.
                    I'm planning on riveting the bracket to my surplus ring material. I'm having trouble with the ring and haven't got to the bracket yet.
                    • An ID On the Ring
                      If you have an ID we can get a pipe Sample and Hone to fit ??
                      The tolerance looks to be about .070 [.035 gap] rather large actually!
                      Actually The Gap is 1.725 all the way around??
                      Or do you split the 1.725??
                      I have to check that of course .
                      Chet
                      BE that change !!
                      • Repost of Post #216 (I.D. of Ring Figured)
                        Important Ring Calculations!!!
                        The inside diameter of the ring can be determined easily since we have the required gap for European and US model boilers. We also know the diameter of the can to be 65mm.
                        US Model: 65mm + 1.725mm + 1.725mm = 68.45mm
                        European: 65mm + 2.1mm + 2.1mm = 69.2mm
                        You still need to calculate the circumference so that you'll be able to determine how much metal you'll need for your ring and how much overage you need to add for your attachment point for your stabilizer and electrical connection.
                        Circumference = 3.14 X diameter
                        European Circumference = 3.14 X 69.2mm = 217.288mm (8.6") = Length of Ring (You'll Need To Factor Extra Material In For Connection)
                        American Circumference = 3.14 X 68.45mm = 214.933mm (8.5") = Length of Ring (You'll Need To Factor Extra Material In For Connection)
                        • Thank you
                          Slovenia
                          I am hoping once you get the Tools we can work in Thousanths of an inch!
                          They are digital .......
                          This is gonna be fun!!
                          Chet
                          BE that change !!
                          • Thanks!!
                            Thanks Chet!!
                            Slovenia
                            Chet
                            • Warped Stainless
                              I wasn't counting on the stainless warping. It's been a real pain and slowed the process of making the new ring immensely. We're going to make this thing anyway.
                              My sheet was to short, so I'm going to be making the ring in two separate halves which I'll rivet together. This does make it a little more complex however because I have more holes to drill and more margin for error. Everything has to line up properly!! Oh Well, we're going to overcome the problems anyway.
                              • YES S we Shall overcome!!
                                Heres a movie from Magluvin at OU
                                (Official Trailer) THRIVE: What On Earth Will It Take? - YouTube
                                BE that change !!
