Tesla's Magnifying Transmitter "Replications"
  • Uploaded with ImageShack.us..............greetings
    must first understand the nature .... and then imitate
    • I'm on the final stages of putting the spiral coils together, finally!! I decided last night to upgrade the construction a bit, which then left me 5mm short on the primary connections so had to measure more. I just finished winding a test run on the secondary using 24 SWG wire, and it's come out as 21.5 turns. So I will proceed to weigh the same amount of wire for the other coil, solder the connectors to the ends, and make the final winds ... And then hope it works
      Also looking good there antigraviticsystems
      • Originally posted by antigraviticsystems1 View Post
        Very nice, that fluro is lit up good. And it looks as though it is lit up without a receiver coil, just a plate and virtual ground, Awesome ! I like it. That looks usefull.
        I ended up getting my earth stake stuck in a rock about three feet into the ground. hahaha so I'll have to get some more, I think I found a spot I can get it down.
        Feel free to carry on guys, but I won't make town for a while yet so I'm kinda stalled on this again now till I do get into town.
        • Hi Farmhand. Could you please explain how you've connected this circuit to your coils? I've managed to view the image once a couple of weeks ago, but that SkyDrive thing seems to be completely unreliable so once again I can't view it.
          Anyway, the reason I'm asking is, apart from the fact I can't see your circuit diagram, I made the 555 driver circuit last night and hooked it up directly to the Tesla coil primary, but nothing at all is happening because it's mostly a short. So I'm going to play around with some transformers and flyback transformers etc with the intention of using that as a HV input source to the Tesla coil. We'll see how that goes though
          SOLID STATE TESLA COIL WITH 555 TIMER | Circuit Project Electronic
          I haven't tried any "big" transformers yet, only a 6kV trigger transformer and directly to the TC primary, but the same effect happens in both: Nothing, less than 1v in the secondary
          I'm also going to have to fiddle with that circuit a bit as well though because it's drawing 200mA at 3v so that's no good. He also says on the page if you change the resistances you can get different frequencies which I probably need to be doing and might be why I'm not seeing anything yet, but he hasn't bothered to mention in what way things will change
          An alternative I'm thinking of is if I can get the 555 circuit to work, I'll make a tiny Tesla coil just to get high voltage, then use that as my power source for the bigger coils. I dunno, it always seems easier in my head
          [edit] Update: I'm getting some sparks from a 240 to 2kV transformer at approx 5v input. With this transformer, as I increase the input voltage from 3v to about 5v, the current rises sharply to 200mA, then it reaches a voltage threshold of some sort and it drops back down to about 120mA. A neon bulb glows with one end connected to the positive HV output, and lights up properly when both wires are connected. So from here I'll try to play around and get an idea of what's going on with this circuit and also keep an eye on the input current because I'm a bit afraid of popping things, as the current goes up to 350mA when I short it (make sparks) or put a capacitor across it. So lots to figure out
          • Good job dR, you're a true tinkerer.
            Back on page 6 post #156 is this drawing,
            It still works for me. I'll upload it to imageshack if it won't work for you.
            I think the skydrive is limited traffic I sometimes have trouble seeing the drawings too.
            Basically I switch the negative side of the coil the coil power can be from the same source as the circuit but I went with 24 volts for the drawing.
            So from positive of the battery it goes charging inductor, primary capacitor positive, primary coil switch then battery negative. It's very simple really.
            Acheiving resonance at the same frequency with both primary and secondary is the difficult part. It can only be tuned by the operator for the coils used, there is no other way.
              Thanks That would be excellent if you could. I keep getting this page
              https://skydrive.live.com/servererror.aspx?JSMissing&n=$Network
              We can't show you that page
              Our server is having a problem. We're working to fix it as soon as we can, so try again in a few minutes.
              I'm having limited success anyway. We're back in the land of crazy happenings again that's for sure. Putting the neon bulb next to all kinds of objects such as wood and cardboard causes it to glow It likes being connected to the bottom of a Tesla coil secondary with nothing else connected to the coil, it just happens to be on the desk. Then it glows nicely.
              But I'm getting nowhere near the kind of sparks I've seen in youtube videos etc that people get from flyback transformers. In fact the flyback transformer doesn't produce any sparks at all. I've increased input voltage to about 8v but had to stop there because it's only a 500mA power supply and the circuit was already drawing slightly more than that. So I'll have to step up to a 4A supply next. But I'm thinking something more than I'm seeing should be happening at least
              • Try putting a small capacitor across the primary coil, of a few nF to 1 uf make the negative of the capacitor go to the battery negative, capacitor positve to the primary coil positive.
                Making arcs uses a lot of energy, input increases just before the arc breaks out then drops again while the arc is supported.
                Depending on the frequency will depend on the cap size. The primary cap is important to get more current through the primary.
                Direct link
                The Main coils are almost a copy of Nikola's drawings from his work on alternating currents and the primary circuit is from Nikola's Ignition coil patent.
                Electrical igniter for gas engine's
                NIKOLA TESL-A - Google Patents
                • Thanks, I'll give that a try tomorrow. I've just spent the last couple of hours taking a broken old PC monitor apart and found within it the hugest flyback transformer I've ever seen. It's also got some tuneable looking screw things on it which say Focus and Screen, so that could be interesting. Either way, a sticker on the tube says 26,000V Hoping the thing still works.
                  Bed time now anyway, thanks for the image
                  PS I finished the flat spiral coils. Just need to solder the end of the wires to a point which I can connect things to in the middle, and devise a suitable method for powering it. I'll upload some pics tomorrow
                  • Remember to be careful with the cap size, bigger will mean more current. Once the amount of power that can be delivered from the secondary is enough and the voltage high enough it can give you a nasty shock or burn.
                    If the frequency is high enough you won't feel a shock so much as be burned from the heat of the plasma arc, I think.
                    Anyway have fun.
                    • Ah ha! Success!! Literally a few seconds ago I've replaced the 500mA power supply with a 4A supply, and it's now able to do more with the flyback. I still can't get it to do anything with the 240 to 2kV transformer with a capacitor on its output, but then I haven't tried the other suggestions yet. I've been playing with a spark gap going into the Tesla coil primary and seeing what happens on its output, which brings me to here... The 2kV transformer did nothing. The test was a neon bulb and also putting the scope probe on the topload. No neon glowing, and 30V 50Hz oscillations which have nothing to do with what I'm doing. So on to the flyback.
                      The flyback finally produced some sparks with the 4A supply at 6v and 550-600mA input. Still nothing on the TC output. I connected the capacitor I had previously been using, and suddenly the spark gap got a little louder and brighter The neon is now glowing near the TC output.
                      The capacitor I'm using here is a 20kV 680nF version of these [edit] Or 680pF according to the spec sheet. It says 680n on the case though. Or "20kB680n" to be precise.
                      1000pF 12kV Tesla Doorknob Capacitor KVI-3 Lot of 2 | eBay
                      So, I think I will have some fun tonight
                      Thanks for the advice. I'll see about uploading some pics of the construction of the TC I was talking about earlier in this thread, and also the flat spiral coils. Speaking of which I'll now have to finish them off and put them to the test Anyway I'll look in to signing up on image shack or whatever now to save attachment space on here
                      • This is the pile of junk I'm currently working with
                        The circuit and mid-building spark gap, which will be contained in a box with a protruding pine dowel for screwing to adjust the gap distance
                        And these are the coils I was talking about earlier, still with no primary on the 2nd coil, and a bit of tape to keep the secondary of the 1st coil in place because I haven't got round to finalising it, which is also why one looks taller than the other
                        • And finally, the flat spiral coils Which took many more hours than planned. I might have made more work for myself than I needed to because since the simple SEC experiments I figured things like a wooden base right next to the coil would affect it. So I thought better do it this way in the first place.
                          Made using "Bendy MDF", which was not as easy to work with as I had hoped because if you're not careful the bits between the gaps come popping off...
                          8 long and 8 short sections of Bendy MDF, and 40 support blocks per coil
                          All glued in place
                          Upgraded the construction by adding screws, with 29 grams of copper for both the 17 SWG primary and 24 SWG secondary wires. They are now also adapted to be possible to hang them on a wall, which will be especially useful if they don't work
                          Wound in opposite directions...
                          ... Eric Dollard style: 2 turns on top of each other before going to the next inside gap with a half turn at the end (wire still not attached to anything yet so it's still dangling there with tape to keep it in place)
                          And these toilet cistern floats will transform nicely into a termination
                          Although Eric Dollard or Peter mentions that a neon bulb is better than a sphere in low power systems, so I'll be making the end of the coil winding in the middle connectible rather than fixed to anything.
                          Sorry for taking up loads of screen space btw
                          • Beautiful job on those spiral coils! Very inspiring, thank you!
                            • Originally posted by 7imix View Post
                              Thank you
                              • Hi dR, Very nice coils, good work. Don't get frustrated if you don't get a good output straight away, it took me quite a bit of tinkering to get a resonant condition. There are a few ways to pulse the coils, finding the best way for you and you're coils is the trick.
                                I really like you're coils they are beuties. I've been really busy working lately and conditioning batteries. I hope to be back in the fray maybe next week.
                                I like you're workmanship very craftsmen like.
