  • @ Shadesz
    This is very informative about phase relationships :
    RE-partI.mpg - YouTube
    @Rod, thanks for the info.
    @ Elias, thanks for that, i always assumed the forces were equal !
    What do they say, ASSUME makes an ASS out of U and ME LOL !
    • the easiest way to determine magnet spacing IMO is to take a gauss meter and measure the distance away (at the same angle that your coil will be) that the gauss meter begins to measure some particular force.
      In this way we can determine the reach of the magnetic field and can design our rotors accordingly. In a same pole setup for maximum power production wouldn't we want one magnet field to leave a coil just as the next one begins to influence it?
      • Originally posted by qvision View Post
        Me too! That is why I made that structure in the first place. Actually that was going to be an inertial propulsion device, but I discovered that I wrongly assumed that repulsion and attraction are equal forces. When attraction is present, you don't feel repulsion anymore it is gone! It is obvious to me now that it must be that way to keep creation unified. Everything converges in the end.
        http://blog.hexaheart.org
          Thanks Elias for the info
          You are welcome.
          • Originally posted by hello_all View Post
            ENERGY CAN BE CREATED ~ Theory of Conservation of Energy is False - YouTube
            look at this , he has big rotor and input 200watts+ while he can add 84watts extra thru regenerative coils
            We are doing the same thing.
            he is making great videos and showing some fantastic results I also believe ever word. I have motors doing what he is doing.
            Do any of you guys think you can replicate his work from the information he has presented. ?
              I think this all comes down to the definition of "Energy" and "Work". I don't
              think they are the same thing, and I don't think they can be just "universally"
              exchanged for each other.
              eg. If it takes "x" number of units of energy to move a number of objects from
              point "a" to point "b" with a certain machine lets say 10 units of energy to
              move 5 objects. Then with a different machine or method it takes only 5 units
              of energy to move the same 5 objects, then this does not mean any "Energy"
              was created. All it means is a more efficient way is possible to do the same
              "work" or a way to do more "work" with the same "energy".
              Now in a generator it takes a certain amount of "energy" to do the "work" of
              turning the generator either efficiently or inefficiently regardless of if there is
              a "load" being run from either way. A load can sometimes improve efficiency if
              the generator is built so it is inefficient without load but more efficient with a
              certain load.
              The "work" of turning the generator is different "work" to the "work" of lighting
              the lights. If the work of turning the generator is taking a lot of energy then
              the work of turning the generator is made less or made easier by the load
              removing the ability of the generator to create a potential as large as it did
              before the load was added, then the rotor will speed up and the current input
              will reduce. But the generator is at it's maximum output as well.
              So Thane is saying that Energy = Work. Maybe that is true but - Which or
              what work is he referring to ?
              It is not that simple to say, "look the rotor speeds up and the input goes
              down, I have created energy from nothing". Because even I won't believe
              that.
              It has been shown in Solid State setups that applying a load can sometimes
              reduce the input current. In my opinion it is a bad thing, because it usually
              indicates nearing the output capability of the setup in that particular state of
              tune or configuration.
              I don't see any extra "energy" or any "free" energy. I just see an inefficient
              generator being "freed up" or overloaded for it's generating capability
              compared to input EMF needed to sustain output.. Or something I'm no expert.
              If it is creating energy where are the MIB ?
              I still think many wonderful things are possible with rotating devices and I'm
              100% in favor of all the research. But we need to be objective and ask the
              difficult questions and demand answers where claims are made.
                "Dare to be naive." ~ R. Buckminster Fuller - YouTube
                This is a replicated the Muller motor.
                • Extremely important experiment:
                  Transformer Delayed Lenz Effect - YouTube
                  Fausto.
                  • Originally posted by Shadesz View Post
                    Thanks Rod.
                    Seems I need to get to my general electricity theory classes as soon as possible. I need to better understand how voltage and current can be out of phase. Any simple explanations of this? (I think I need to study better what voltage is)
                    The simplest explanation is.
                    Think of a capacitor with a battery and a switch and keep in mind moments in time.
                    At the very instant you connect the battery to the capacitor and close the switch. What happens? Two currents flow one from the battery to the capacitor and the other from the capacitor to the battery this is capacitive reactance
                    If you had a meter across the capacitor at the moment the switch closed what would you see?
                    The voltage on the meter would read 0 volts and as you know the current flow would be at maximum. There is your voltage and current out of Phase by 90 degrees. See how the voltage across the meter reads 0 and current reads maximum.
                    Now depending on the value of capacitance and the time going by the voltage will rise and current will fall. See how they move around the circuit out of sink.
                    With a coil the moment you close the switch it all works the other way around.
                    Current is at 0 and voltage is at maximum. The only problem is a coil also has resistance
                    Capacitor has not. They will never let the public have super conductors that is so obvious now. Can you see how a total 0 ohms coil would set us free? Thousands of amps with no heat.
                    With a coil the moments you close the switch two currents flow because of the magnetic field. One current flow from the coil to the battery and the other flows from the battery to the coil there are two currents in flux this is know as inductive reactance. Consumption of current with out dissipation of heat.
                    For us the issue is the resistance in the coil. And the current that flows because of it. Then the current that flows because of the coils reactance. Total is impedance. We can calculate them and separate the two value and manage them in different ways. Because they are out off phase.
                    This is why a switching power supply blows the chopper transistor out of the circuit when the oscillator stops working. The faster you switch the coil the less current it consumes. Stop switching the coil and allow just dc voltage to stabilize over time and
                    Current goes to maximum because the only thing left in the circuit is Resistance.
                    The Lenz less generator is no exception. For me until now I never looked at it from the other way around. Inducing the voltage form a magnetic field from a fixed magnet. Then working with the time lag of the current. What brilliant idea.
                      I have never known what type of core material he has been using. That is very important.
                      • Hi folks, Hi rod, thanks for that explanation.
                        You said, "They will never let the public have super conductors that is so obvious now. Can you see how a total 0 ohms coil would set us free? Thousands of amps with no heat."
                        ANYTHING is possible, unless one claims to be all knowing.
                        Send true loving thoughts to any and all that may have in the past, present or future suppressed, oppressed or in any way held back things that would benefit the highest good of one and all.
                        That is the only way any of this will ever change.
                        How do I know this, because I have directly experienced the power of unconditional love and its effects on myself and all that is around me.
                        All discordant energy melts in the presence of this love energy.
                        carry on.
                        peace love light
                        tyson
                          They are too busy nowadays.
                          • Good info On AC circuits
                            AC circuits, alternating current electricity
                            • @Rod
                              Have you tried charging low impedance batteries with your coil? Because batteries have low impedance they should behave like shorting coils. I think that this was the "secret" of the Watson machine, he was charging batteries by pulsing the coils into the battery at the "right" moment, so that the phase delay of the "current" made Lenz go away.
                              If you have achieved no drag by shorting through diode bridges, I suggest give this a try!
                              Elias
                              • Romero confession of his fake Muller Dynamo
                                Hey guys read up...
                                Here is a link...
                                DELAYING LENZ LAW ...
                                And attached is a backup PDF of the page as it sits today.
                                Note: I am not a forum member so I couldn't verify the sign up date for the user RomeroUK, nor have I investigated all his posts on that forum.
