  • @Rod
    Do you mean that your Adams/Bedini Style rotor performs much better and acceleration is present in that style? Does this mean that you have achieved lower input current to your out runner while inserting a shorted coil to your system? Couldn't you achieve the same result using your Muller type generator?
    http://blog.hexaheart.org
    • Originally posted by frenky View Post
      Hi Rod:
      With "No coil installed" you mean:
      a) Core still in place but copper wire removed
      b) Core and wire removed
      Thank you.
      No coil installed. rotor free spinning. only the drive motor. no coil or core
      I will do some Photo's
      I have some more data on magnets and speed and so on. Just writing that up now.
      This is the Muller Motor results.
      My problems are core materials. I was told by a transformer manufacture today to piss off. Because they would not share the core materiel with me. Its a secret
      they said.
      • Originally posted by elias View Post
        @Rod
        all this means is its possible to make the gen coil invisible to the rotor magnets.
        acceleration may not be possible. still to early to tell to be sure but I have never seen anybody say there generator runs on just a load.
        all the things Romero hinted at that where critical seem to be coming true.
        I would like to build a hole new motor based on what we have learned so far.
        just want to test iron powder cores. like Muller used.
          Your results show otherwise? when shorting, you get more speed than no coil config? Even your speed is more when you computer switch the coil. How is that? Is this config the Adams/Bedini Style rotor?
            they said.
            Take it the other way around
            , let's suppose you could make any core you desire, what type of properties would you like it to have...from there you search
            Signs and symbols -Confucius.
            • Hi everyone!
              I have something that should interes all of us
              strange behavior of the coil part 3 - YouTube
                The variation at this speed is such a small percentage it not mensurable
                The variation is negligible.
                I will present more fact and figures very soon. Just give a chance to make the tables and write it up.
                your speed is more when you computer switch the coil. How is that? you will understand when you see the wave form my scope.
                this is about many parameters all being just right. I am very sure there is lots of room for much improvements to come.
                • Originally posted by mariuscivic View Post
                  Hi everyone!
                  info on shorted coil (posted originally by Dave45 )
                  Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation - YouTube
                    I have worked long and hard on this project for a long time. years before Romero ever posted his Muller.
                    the contribution form every person on this forum has be priceless. I have taken the advice form so many. Tried so many ideas. Some with success and some not.
                    The suggestions are to look at core materials Like Metglas
                    Ferrous, Boron, and Silicon (Fe-B-Si) metal alloy. amorphous metal.
                    all these are very much worth a try. As you can see the MU metal is successful
                    I would like to get my hands on Metglass
                    the test today point out the ratio of inductance to resistance is very important.
                    did you notice my coil was 9mH, changed it from 5 to 9 and wound it around a Mu metal core.
                      there is one that corresponds to one of your requirement, and is cheap
                      Tourmaline - Wikipedia, the free encyclopedia
                      Formula: (Al,Fe,Li,Mg,Mn)3(Al,Cr, Fe,V)6
                      (BO3)3(Si,Al,B)6O18(OH,F)4
                      Tourmaline is a crystal boron silicate mineral compounded with elements such as aluminium, iron, magnesium, sodium, lithium, or potassium. Tourmaline is classified as a semi-precious stone and the gem comes in a wide variety of colors.
                      tourmaline powder | eBay
                      as an added bonus, it is piezo
                        Hi everyone!
                        This is why I installed a independent drive motor. The out runner.
                        same thing that i posted above earlier. the drag was increasing the speed by drawing more current. I couldn't see how all my test failed at replicating it.
                        so i moved on.
                          Hi everyone!
                          That is interesting ! Very nice Demo. You covered a lot of good points, that little motor is Radical ! I was going to say could you try a smaller capacitor, but now I'm thinking, throw a saddle on that thing. Would loading the output coil even more, while the setup is accelerating from the the shorted one next to it slow it down much. Doesn't seem like it would. You could even load the other one or short it too.
                          Seems to me with the capacitor in parallel you are building the frequency into a resonant rise when it goes balistic. Because once it gets going it keeps going without the load.
                          That is impressive.
                          I think Slider showed us something like that too a while ago.
                          Just wondering, do pulse motors have a torque curve ?
                          • @toranarod
                            Thanks for posting your results above.
                            On the chart you mention the coil is 9.2H. Or is that mH?
                            The result of 71.6 volts is great and I am very inspired by that with a rolled laminate.
                            The input current of 1531mA indicates to me that the drive motor was under some good stress but managed to keep up the rotation.
                            Thanks for sharing that info.
                            Regarding the FWBR design I put up with diodes in series, I have never tried that or seen that used anywhere but when using a regular or Romero type FWBR, the gen coil gets stuck because the diodes cannot push the energy and keep it on the other side so the coil feels the compression. The idea of having two diodes in series is to push the energy across both diodes and make it impossible for the energy to push back because there is a space between both diodes that has no compression zone. lol
                            Please do not start a new build yet. There is too much new information coming in and may influence your next build accordingly.
                            @all
                            About the rotor diameter and number of magnets, the ultimate count would be regulated by the two main components.
                            1) The hall sensor activation angle and distance.
                            2) The rotor magnet field force and effective angle against the hall sensors and against the gen coils.
                            Well anyone can simply wing it and make any size wheel with magnets and they will ultimately find an area of activation, but it does not mean the design is optimized for such a use. So again this is another part of R&D with drawings trying different magnet/coil counts and having the hall sensor angle to see what diameter/magnet/coil count is the optimal.
                            @mariuscivic
                            You are so close to cascading coils. Please try this.
                            The two coils you use for shorting, put them together in parallel. Try the wheel. Then switch the wires and try again. Then put the orange capacitor in parallel across those two coils. Let us know what happens.
                            Check the power input to see if it reduces while the rpm is the same of higher.
                            It would have been best that the second coil of the two could be removable to try both sides of the coil and different positions around the wheel. I am sure that is where you will find some very interesting effects.
                            wattsup
                            • @ MonsieurM
                              Thanks for the Tourmaline info
                              @ Marius, thanks for the new video
                              @ All, what do people mean when they say 'pulse one side of the coil" ?
                              QV.
                              • Originally posted by qvision View Post
                                @ MonsieurM
                                QV.
                                I believe they are refering to way it is wired to your circuit. You could pulse the coil with pos+ going to the start of the wind or you could pulse it with pos+ going to the end of your winding. Its all in how its wired to the drive circuit. Hope this helps.
