Awesome ROD.
Almost there now. What is the diameter and material of your bobbins?
I have NEARLY finished gathering all materials for this build. Sure is a lot of stuff for such a small little motor. I feel your pain on the coils. Literally. I am using sewing machine bobbins and have 10 of them wound.
ONLY. EIGHT. MORE. TO. GO.
Over at OU Scratchrobos motor self destructed. Admittedly his rotor had a wobble. Does anyone see a problem with using .75in MDF board. Especially if I cut the rotor larger than needed and place the magnets farther from the edge. I see a little more stored energy in flywheel, but also safe since my magnets (which arrived yesterday) wont be as close to the edge of the rotor. If need be I could use that fiberglass packing taper like we used in Bedinis to stop magnets from ejecting.
[/IMG]
). Sharing what happened will help others greatly though and I hope that they do report in.
putting a thin plexiglass disc and screwing it to fix the coils tight, is certainly a very good idea, I even recommend, using a 1mm disc on the rotor to to inhibit the magnets from flying off. I suspect that plexiglass could not withstand the great centrifugal force the magnets put on it. My magnets were round magnets 10mm thick and 40mm diameter. Yes be careful, this machine, is really a monster at high revs, so build everything as tight as possible and do not make incomplete tests, fix everything tight, especially the rotor.
