Jetijs,
It was wmo and a bit of PE/PP. As it is a continuous process I fill the reboiler with plastic at the beginning and continue with adding the wmo.
Regarding the catalyst you are pursuing. Clay is good, but has to be delaminated firstly, otherwise some clays tend to crack pyrolysis gases to heavy oils and others to light gases. Plus it needs to be regenerated all the time as it gets very quickly covered by carbon which prevent it from doing it`s job. You should check the net as there are some references on how to use clays as catalysts.
