figured id post a short update ...i removed the bridge circuit and wound another air core transformer with 550 turns on secondary and 100 turns on primary ( yes step-up) or resonant transformer, the primary came from an old microwave cooling fan motor and the secondary (for now) is a strand of cat5 solid wire) with this setup i found it interesting that it fired up a cfl although my goal is to see how much usable power i can get from this wire antenna setup ...my next step is to raise my antenna to 40 then 50 and stop at 60 ft off the ground if i go too high the wind here is terrible it would just get ripped apart ....
i did however wind a 3' coil with the same wire im using as my antenna strung across my yard to see if erecting a coil 30' in the air at a single location would produce the same results ...the answer is no i only got 60vac with 27ua .
Their must be a reason i get much more covering a larger area than having an antenna just going straight up...
