SR 193 / SR193 - Study of the Device, Theories, Diagrams, Schematics & Experiments
Ferrite Cores
Somewhere in this thread, I posted a link to a document that shows a spreadsheet of the different types of ferrite cores. Here's the link: Ferrites Brands LV & Minorities with Electrical Parameters. Basically, different ferrite cores are composed of different materials with varying amounts of trace metals.
SR probably used Russian cores. His step-down transformer under the clear circular platform is certainly Russian.
In SR's example, he probably went with a lower temperature Curie point ferrite core, but that is only a guess.
From what I have heard, the ferrite core does need to heat up to a certain point. It's not clear if it continues to heat to the point of overheating, but if it does, it wouldn't be that difficult to cool it back down to the optimal temperature.
I have seen several cores on ebay of about the same diameter as the ones used in SR's device. That is where I will start just as soon as I can afford to purchase some cores.Last edited by vidbid; 05-12-2011, 11:38 PM.Regards,
VIDBID
Thanks again Vidbid !
I guess you're right, let's do some test first with the tores we can find and, if one day, we're lucky it's gonna be the time to upgrade the device.
Nethertheless, i've found Russian tores from an Ukraine seller on Ebay for an affordable price... Not those with the very low curie point but except this, same manufacturer and specs.
Cheers !
Note : Did you start building your device and make experiments ?
I still need the tores. Let me know how the ones from your Ukraine seller work out.Originally posted by NOMDI View PostThanks again Vidbid !
Cheers !
You're not going with low curie point torres?Regards,
VIDBID
Tores
@vidbid
Unfortunately I found low curie temperature tores nowhere... (KYOCERA seems to have a good alloy but hard to find a retailer for small quantity)
So I ordered regular tores (Russian ferrite M2000NM no NiZn).
I plan to make my coil asap and will start experiment with a 220-10V transformer (no push pull). But I 'm not sure sine wave is the best way, neither 50 Hz...
I guess I will have to modify the coil a lot of time before getting something regarding how many schematics are available for this crucial part... But that's probably the key of the device, so...
About gas
I dont think SR or Kapanadze have
the industrial technology to make
a reliable ( i mean no leaks ) tank
or pipe with vacuum or any gas...
But why not in an " non hermetic" way
with a permanent gas generator like ceramic or
quartz ozone generator hidden in the
coil... powered with flyback ?
I guess i ve seen something like this
Outside (?) the Turkish device..
Found source of low curie ferrite material
See YouTube Video: Scalar waves / Plasma Driver / Part 6 by selfonlypathRegards,
VIDBID
Kapagens don't belong here.
You are way off topic. This thread is for the SR193, not the Kapagen. There is a big difference. By the way, that thread is at Kapagen Theories, Replications, Winding Diagrams, Circuits & Schematics. KAPAGEN ONLYOriginally posted by dllabarre......
DonLRegards,
VIDBID
Originally posted by vidbid View PostYou are way off topic. This thread is for the SR193, not the Kapagen. There is a big difference. By the way, that thread is at Kapagen Theories, Replications, Winding Diagrams, Circuits & Schematics. KAPAGEN ONLY
I retracted my original post with "......" because there's no way to delete a post.
Sorry if you confused my "signature reference to KAPAGEN" with an actual post from me.
Signatures appear below the "________________" line on the bottom of posts.
Don
Deleting a Posting works over Edit - go advanced, and at the Window look at Top for the Delete Post Checkbox, then it totally disappears.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
