SR 193 / SR193 - Study of the Device, Theories, Diagrams, Schematics & Experiments
  • I found something interesting today that gives the SR device credibility. I went back and played with the modulator circuit today and played with the supply voltage.
    I used a US hex inverter chip NTE40106B. When I increased the supply voltage, the frequency changed and at 13 volts, the gate clocked at ~21 MHZ which is the NMR of Fe56.
    That is well beyond the normal clock rate of that 4000 series chip from what I recall. The measurement is not in error and was measured using the frequency counter on a 100MHZ digital scope.
    Since the voltage is going to fluctuate you would be hitting that NMR frequency as it is modulated at 50-60 HZ.
    That being said the ttransistors are not going to switch that fast but who knows.
    I'll go buy a mixer and build a real modulator and see what happens.
    • Originally posted by Dr Poppy View Post
      Good luck with experiment, the only way to discover anomalies is to build and see.
      I was reading about stubblefield and see similarities, I want to do the motional e-field experiment at the bottom of this document, someone already did this?
      stubblefield - keelytech
        ....the gate clocked at ~21 MHZ which is the NMR of Fe56......
        How do you know that's the NMR frequency of Fe65 when the NMR frequency of an atom is dependent on the magnetic field strength, which seems to be usually given in Teslas. Have you measured your field strength and looked at a chart and decided it's about right? Just curious, as I just started learning a bit about NMR.
        • hi friends
          new forum ruso www.kacher.info • Просмотр форума - КАЧЕР - практика
          chauuu
          • Translation at Babelfish
            Originally posted by ismael_34 View Post
            hi friends
            new forum ruso
            chauuu
            I didn't find anything about the SR193.
            VIDBID
            • free energy from the second field of the ferromagnetic material
              See free energy from the second field of the ferromagnetic material by admin of Next Energy Forum who is believed to be SR (SpaceReason).
              See his forum. There are several comments about Tariel's device.
              VIDBID
              • Curie points, heating, and magnetic fields
                Russian forum talks about Curie points, heating, and magnetic fields with respect to Tariel's device. The person referenced as CrazyAlex in this forum is believed to be SR. However, the admin of the forum is also believed to be SR. Go figure.
                VIDBID
                • Originally posted by SuperCaviTationIstic View Post
                  I don't. I suspect it is lower however if you replicate the original SR circuit you are going to find that it sweeps as the source voltage changes.
                  The bottle neck that sticks out on the SR and Kapanadze device are magnets that have not been baked IMO and are the .5 Tesla.
                  The outline of the rectangle on the wire is most likely a copper strip since you are trying to produce a standing wave (cold electricity) in half the coil.
                  I think I see how these devices work but I am on hold waiting for parts. Time will tell.
                  One thing is for sure, if I am right, there are way better ways to do this that use less energy on the supply side making more energy available.
                  • SR device is based on Meyer iron patent, however Kapanadze is related to other schematic also first published by Meyer, about resonance in copper rod.
                    Do you have that schematic ?
                    • Hi everybody !
                      I'm a rookie on this thread but I'm very interested... and the device is fascinating of course !!
                      I found this on youtube YouTube - Разаблочение Реплики Капанадзе.avi
                      can anyone translate the comments ?
                      Thanks !
                      • hello friend
                        in the video, which is trying to discredit the system 193 sr
                        can translate the comments below the video
                        chauuu
                        • Thanks for your help !
                          I m sure this video has been made
                          To discredit the SR device, that s
                          Disinformation... However maybe we could
                          See some hidden clues ...
                          • 2000nn ?
                            Hi !
                            Everywhere i read the use of 2000NN
                            ferrite tores which Have an exceptional
                            Curie point of 70 degree C !!
                            Anyone do know the manufacturer of these
                            Parts And how i can buy them ?
                            • Russian Cointelpro
                              Originally posted by NOMDI View Post
                              Hi everybody !
                              Thanks !
                              It's just an attempt to discredit the device. It's a form of cointelpro (counter intelligence), directed at suppressing the technology.
                              It's just a long wire. It loops down. Here's a photo of wire.
                              VIDBID
                                Hi !
                                In the Russian forums, they talk a lot about this and the overheating of the ferrite core.
                                Here's my earlier post:
                                I found this Russian paper on properties of ferromagnetics from a Russian forum I was reading.
                                PS: Selected Posts:
                                Why the SR193 device output core gets hot, I think. Source: Post 92
                                VIDBID
