my smith kanapadz replication
  • SR 193 SR193 : Transformer for Rectifier
    See this blog about the Soviet TC-180-2 transformer.
    VIDBID
      Uploaded with ImageShack.us
      Relay - Wikipedia, the free encyclopedia
      EDIT: Concerning the CrazyAlex Generator diagram. How is he supposed to get 220 Volt across L4 with that winding ratio? Well since the diagram is from the first page it might be merely a very conceptional signal flow outline rather than a circuit diagram.
      • SR 193 / SR193 : J. L. Naudin's Kapagen
        Good morning. I just woke up thinking about this SR 193 / SR193 thing (device). I was thinking that I was grateful that SR 193 / SR193 was gracious enough to show us his working replication if it is not a hoax, but in another way, I was thinking that it was somewhat cruel of him not to give us full disclosure as to how his device works. Isn't the purpose of a replication to be replicable? This means the device should be able to be replicated, I believe, easily, but this is not easy. What is easy replication? For example, a virus replicates by make multiple exact copies of itself. That's an easy replication. We live in the digital age. We should be able to do easy replications with respect to device building. How can we replicate his device if we don't know exactly how it works. We're guessing. We're speculating. We are analyzing and over-analyzing his device. That is not replication.
        I think that in order to understand the principles of over-energy with respect to this type of device, I should study a similar working replicable over-energy device; then I can come back to the SR 193 / SR193 device. I believe that J. L. Naudin's Kapagen device is a working over-energy device, so I'm going to start studying it. Once I understand the operating principles behind the Kapagen, then I can come back and make comparisons to what I know about the SR 193 / SR193 device, which I must admit is not as much as I want to know.
        To see full size image of the above image, click on this link.
        Source: Kapagen Replications: Schematic and Project
        In closing, let me just say that there are basically six categories of this type of device.
        1. The Tesla Device
        2. The Czech Device
        3. The Donald L. Smith Device
        4. The Original Kapanadze Device
        5. The SR 193 / SR193 Device
        6. The Kapagen Device
        In addition, I would like to include the slotted-copper tube principle, examples #1 and #2, as seen on YouTube.
        So, I will be studying the Kapagen. To that end, I have created a new thread, entitled, Kapagen Theories, Replications, Winding Diagrams, Circuits & Schematics. KAPAGEN ONLY. This thread is only for high voltage input Kapagen devices, meaning the input and output voltages and currents of these devices that have the potential to kill you.
        If you want to discuss low voltage input Kapagen devices, go to this thread: Kapagen Systems - 12v Input Only That doesn't mean that there is no danger of a potentially lethal electrical shock with respect to these devices. The input voltage might be low, but the output voltage given enough current could still kill you, so be careful. A 12VDC automotive battery can still burn the crap out of you. If you ever shorted a pair of pliers with hot to ground, then you know what I am talking about.
        DISCLAIMER: The authors of these threads assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise arising from the use or misuse of the information contained herein are entirely the responsibility of the user.
        VIDBID
        • For anyone who replicated kapagen :
          Can you try to cut connection as indicated on attached picture and measure effect ? I know that would destroy coil connections but you should immediately grasp the idea here. If that works without extra coil connected directly , then it's possible to divide device into two parts : transmitter and receiver and by carefully adjusting capacitance connected to receiver you can find how things depends on themselves. Receiver of course then could be placed 10 meters far from transmitter.
          • Missing picture.
            • Originally posted by luno
              Hi everyone,
              Here is the translation of the Russian texts on the picture:
              L1-L2 coils have 100 turns of 1 mm wire, wound like in inverter transformer
              L3 coil has 20 turns of 2 mm wire, 4 layers with 5 turns in each layer
              L4 coil has 150 turns of 2 mm wire, 3 layers with 50 turns in each layer
              Transistors are the high power transistors
              Thanks!
              1.To CrazyAlex for his theory...
              2.To Toptamburg for his experience and his remarks that the magnetic field need to be not less than 0.5 Tesla, and that the spark contains the electric field of 21 MHz frequency
              3.Admin of this forum...
              4.To SR for his advices
              5.To one Czechoslovak firm for the patent
              And for others who took place in the experiences
              Thank you for the transcript.
              Don
              • jumbled mess of whatever
                Hi all,
                Is this the signature for these types of devices. When I look at these things, they are an absolute jumble of unorganized wiring. I mean it's a bird's nest. And don't try and tell me that this mess is somehow pivotal to some principle of the gizmo's operation.
                PLEASE ! It seems that anything coming from this part of the world always looks like this. Some loose twisted and splayed cables, uninsulated discombobulation of wires, heat sinks and the ubiquitous light bulb in its wrapper with a burned spot on it. This burned spot must be very important...... yeah, I know it's so you don't get "Blinded By the Light ... Revved Up like a Deuce ... Another Runner In the Night ..." (Bruce Springsteen - The Boss)
                Could it be that their utilities infrastructure is so shoddy that their grounds and neutrals can be interchanged with their hot ?
                Sorry ... it's just ... well ... gosh
                • from that part of the world? can i ask from what part of the world are you?
                  Originally posted by gmeast View Post
                  Hi all,
                  Light, I Am!
                  • can i ask from what part of the world are you?
                    Slovakia ... you have to admit I'm right. Why do the replications look like they do ? What a mess ! They look EXACTLY (mess-wise) like the original.
                      eheh, i dont know why that happens my friend! but you can see the same thing in other "parts" of the world also...
                      Light, I Am!
                      • especially there ... here
                        The replicators unconsciously (I guess) try to make it like the original innovator's gizmo but there's no reason for it. Is it to hide something ? Look at the original video of the Kapanadze device. Wires are barely connected, the ground wire(?) is connected to a 'painted' pipe and there are other inconsistencies as well.
                        I want the science.
                        • Originally posted by Xenomorph View Post
                          Uploaded with ImageShack.usKICK
                          Xeno has a point here.
                          This coil, has a very poor coupling factor (almost non-existent) and cannot affect main coil no matter how muh amperage is flown into it.
                          BUT, if the RF field of the spark is doing something to the ferrites then this coil is suitably placed in a perpedincular plane to main coils axis.
                          I have posted above that NMR is happing when the specimen (ferrites?) are placed in a strong magnetic field and an RF field is applied perpedincular (not in parallel that results if you have both windings -inverter and HV- in same axis that is wound on ferrites)
                          This small coil also, has the same wire gauge as the spark-gap.
                          (noted before)
                          Anyway, have not a clue how an RF field of a spark could affect ferrites and its magnetics properties.
                          • SR 193 SR193 : White HV Flyback Transformer
                            Isn't that a putdown for people in that part of the world? I like the way they put their circuits together, and I've said so before.
                            The key word is functional. True, he slammed it together, but it appears to work, and I have a gut feeling that SR193 didn't build his SR193 device to suit anybody else's notions of how a circuit should be built or look after being completed other than his own idea. If the SR193 device truly works and is not a hoax, then SR193 obviously understands not only the working principles behind the device but also how to construct the device itself. If we suspend our disbelief for a little while, and try to work with what we have, images and video of a slammed-together device, then if we are smart enough, maybe we can figure it out.
                            I understand that it is frustrating. In fact, with respect to the SR193 device, you reach a point when you say that there has got to be an easier way. That's why I went on to study the Kapagen.
                            By the way, I wasn't planning on coming to this thread and posting anything until I understood more about the Kapagen, but I came across a image that looks the the white HV Flyback Transformer on the lower platform of the SR193:
                            If there is a connection, could someone try to figure out how the relays (black object on lower platform with leads attached to it) works in conjunction with the output coil and the rectifying transformer?
                            Notice the black wire attached to the output coil's ground hub going to the lamp and then running back to the approximate location of the relay (black object on lower platform with leads attached to it) or the rectifying transformer.
                            Also, could somebody try to figure out where where the full wave bridge rectifier is on the lower platform?
                            VIDBID
                            • SR 193 SR193 : Lamp Only
                              I found this image of the SR193 device's lamp with the cover removed.
                              Does anybody know the type, manufacturer, model, and voltage of this bulb?
                              VIDBID
                              • vidbid,
                                when you mention "that looks the the white HV Flyback Transformer on the lower platform of the SR193"
                                where do you see that in the SR video? i just see 2 transformers, a small one visible, and a big one down the glass table!
                                Light, I Am!
