my smith kanapadz replication
  • Alternative Circuits to Drive HV Formation Circuit in the SR193 Replication
    I was wondering if you could take something like a Fuji Circuit Joule Thief CFL Light Circuit or a Jeanna's Light Circuit to act as the HV Formation Module to drive the spark gap and L2. They only require a 1.5v battery to run them.
    VIDBID
    • Joule Thief Driving a Flyback with a 1.5V -Constant Arc in Spark Gap
      So what about using a 1.5v joule thief to drive a flyback to ignite a spark gap or gas discharge tube and to be applied to the L(HV) coil?
      YouTube - Joule Thief - Driving a Flyback with a 1.5V (4)
      VIDBID
      • A word about measure input
        I'm confused,
        I like the "Kapagadget" but is true a Check meter convetional can to have seriuos problems to measure the input, maybe is needed put the VARIAC and find the cap to Power Factor Correction = 1. This maybe able to erase the error margin created by the RF noise.
        Or well using a Batt with inverter circuit only hook Amp meter in the battery...
        I don't see really necessary produces HV from Sine wave source this is only usefull to amplify power grid company but this gadget can operate with a normal voltage multiplier to charge that capacitor, the Spark gap is more like a PWM trigger only need 1000 volts per 10 mm and everybody shows somes .5mm
        Steve Jobs. Apple CEO
          Just give it a shot, you will have to modify stuff anyway to at a later point.
          But it gets you started.
            hello dear vidbid
            why a JT if you can drive it directly from 12 volts?
            do you know in what frequency does that timer circuit for CFL bulb (12v 1A input) works? maybe 50 hz?
            i thank that will work with my 220 to 10V 1A step down transformer, reversed!
            hugs and thank you very much
            • Originally posted by juju View Post
              hello dear vidbid
              Juju, you can build that circuit , so that it does produce 50 Hz. Just different resistors and cap needed.
              • Uploaded with ImageShack.us
                • SR193: Blue & White Vertical Coil Under Transparent Platform
                  I notice that the original Kapanadze device also has a vertical coil.
                  VIDBID
                  • Yes but my point is that these coils have an approximate same size, so they could both transmit. But the little coil is much too weak.
                    By the way that whole aquarium device is a more advanced model than the green box thing. It is mind-boggling actually there is all kinds of weird stuff inside there and additional safety spark gaps.
                    • SR193: What is the Medium Sized Black Object on Lower Platform?
                      VIDBID
                      • That object is a so-called relay
                        • SR193: Vertical (blue and white) Coil
                          Maybe the Vertical (blue and white) Coil is sensing the field of the Blue Output Coil so that Vertical (blue and white) Coil can relay the frequency and/or frequency phase information to either/or both HV Driver and LV Frequency Generator. I am wondering if the frequency of all the modules should be in phase. I think they should be. If they are all in phase, then wouldn't the net effect be that the amplitudes of all the coils are additive? I think it would.
                          VIDBID
                          • HV Driver Module
                            I think I found an HV circuit that produces an arc that looks very close to the SR193 Spark Gap. The color of the arc appears to be the same. It can run on 9 volts. I saw it on YT.
                            The fly-back is from a computer monitor, and the transistor is a MJE13009.
                            VIDBID
                              Maybe the Vertical (blue and white) Coil is sensing the field of the Blue Output Coil so that Vertical (blue and white) Coil can relay the frequency and/or frequency phase information to either/or both HV Driver and LV Frequency Generator. I wondering if the frequency of all the modules should be in phase. If they are all in phase, then wouldn't the net effect be that the amplitudes of all the coils are additive.
                              Any HV circuit will produce an arc of that color. I have built all kinds with CRT flybacks TV flybacks etc. You just have to make sure that it only consumes about half an amp or less of power.
                              • that's may be a kick coil
                                i think that's may be a kick coil. i attached a doc about kick coil.
