gravity waves found
  • Hi Loadstone,
    have you tried to lock the pieces using an electric impulse through the coils?
    • hi everyone...
      jet, did your mail come?...jesus at OU was having a hard time seeing the radiation, but he did start to see it, finally!..do not be discouraged if you do not see it right away....remember what bruce said....very very subtle.....this is a little frustrating for me but like i said before, if this were easy to see/detect, it would have been discovered long ago....so far i have not seen any good photos of this effect, only good descriptions,fortunately from Tesla and other researchers, that lends a little credibility to what i am describing and trying to capture with imaging devices....these distorted "fields" around my devices, seem to be present around high energy/high magnetic fields and seem to be variable...i would still like to use some type of FLIR imager, to see if that might capture it better....these effects are real...the visual/gravitational anomalies are not imagined....similar effects have been seen/documented by some of the biggest names in this field...i know we are getting close...elusive? HA! frustrating? double HA!but i know what i have seen/felt...i have shown my devices to over 50 individuals who verify my findings....this is all very new to me...i am trying my best to help others to experience what i have, so that other researchers may find the root of these effects....how does one go about describing something they have never seen before?....if it were easy, i would not talking about it right now, it would already be old news......thanks for your help, even taking the time to read these threads, helps...i am not really that smart, i never went to college, i do not hold any degrees, i got my GED while in prison!....this i do know, i have seen/rediscovered something important....i have created it without the high voltage/magnetism that is normally associated with these distortions/anomalies....these effects are very subtle right now but most of what i am doing is still very crude, but i am moving forward in my progress.....david
      • Hi All
        great work here
        @ Harvey
        please could you repost a better pix of your device once completely iced. The previous pix do not clearly show the depression in the center. I know that it is difficult to show the variation of form on ice, but try, it would be very helpfull.
        and please can you make a new video with the cam fixed above the device without moving. So perhaps we could learn to see the subtility that David try to teach us. Thank's
        @ Jetijs
        Did you already made some test ?
        As for me i go on in icing test. So far it is the only mean i have found to see something in this radiation waves. But there is no doubt that the assymetry is there. This morning i asked my daughter to let her hands on a completely iced pmh. And estonishly she sayd that the "heat spot was where there was less thickness of ice ?? " So a question does the pmh Compress the water icing process on one side and depress on the other ??
        And the question is why ? Any idea ?
        Have some more icing this night. We will see tomorrow
        Good luck at all
        Laurent
        • Ice Complete
          Hi All,
          My previous pics of the icing was in the very first stages of freezing and now it is completely frozen through. Below are all the pictures I have taken thus far and I have returned the ice to the Pyrex container and put it back in the freezer on the PMH to keep.
          The depression developed into a bulge. This is evidently due to humid air inside the freezer blowing on the ice and building up there. This is also undoubtedly the cause for not having a clear block formation. I intend to repeat the test with a shield over the tray to prevent moving air contact with the water.
          However, the radial bubble trails are unmistakable. There is clearly something present to cause these formations.
          <-Zoom<-Zoom<-Zoom
          <-Zoom<-Zoom<-Zoom
          <-Zoom<-Zoom<-Zoom
          <-Zoom<-Zoom<-Zoom
          <-Zoom<-Zoom<-Zoom
          These Posts only allow 15 images including smileys. There is one more image here:http://urad.net/forums/gallery/albums/userpics/M01A0625.JPG
          So that should complete this set =)
            Hi All
            great work here
            @ Harvey
            @ Jetijs
            Good luck at all
            Laurent
            Hi Laurent,
            Here is a video showing the Buildup that occurred in the previous depression:YouTube - Lambright - 016
            I'm not sure I understand your request for a still camera , are you requesting I do another HD sequence using a tripod and no camera motion? Or . . . no PMH motion or . . . ???
            Are there any specific lighting requests or preferred camera angles? Shutter speed or f.stop? ( I think this camera is limited to 1/2000 shutter and f.stop 2.0. But I think my son does have a Macro lens if that will help.
            Did you see all the wavy motion in the 'recharge' sequence I did in Lambright - 012 (starting at 5:50 full screen) ? I don't know why there is so much pixel action in that sequence - the camera was still and so was the PMH and the ambient lighting should have been near constant. It is a strange bit of footage
              If my opinion is needed here, then my answer is orgone.
              good luck all.
                good luck all.
                Thanks Sucayo,
                Did you see YouTube - Lambright - 005 using the Sketch Mode camera setting?
                Is this similar to your technique? I am wondering if there is anything in those videos that can show up in your techniques with them.
                Thanx.
                • dad...
                  he finally saw it!!!...my dad saw it today!!...i am so happy...anyway, it was daylight with the sun a little to the east, he was standing facing south.....having the device back lit may be key in seeing it better......david
                    Different. My video version are showing the difference between image, not to outline the edge.
                    I still wondering how people can see the energy even from picture. That must mean the information is there but the process is still unknown. It seems contrast difference is not the answer.
                    Maybe a color shift? I don't think algorithm to detect color shift exists, so we may have to make it.
                    That is nice .
                    An appropriate background seems very important. My sky is very blue this sunday and I can see tree have an outline. Anyone can take with PMH picture with blue sky background?
                    • sucahyo...
                      i was thinking about some past experiments, with powdered metals suspended in oil, not like ferro fluid, the particles will settle out if undisturbed...a PMH near the oil/metal liquid, you could see the particles "flowing" down...the particles were falling yes, but the wave like effects are interesting...does the orgone radiate energy when near a PMH?....david
                        This is good news
                        Then there may be hope for me yet
                          That is nice .
                          Yes, I see what you mean - your technique gives a pixel when something has changed - the video I did in Sketch Mode is very different. Thanx.
                          We perceive color as a mixture of frequencies centered around 3 specific peaks, Red, Green & Blue. Those are the only sensors we have in our eyes. All other variants of color and hue and tint etc are overlaps and shifts around those 3 peaks. When the receptors are overwhelmed with energy of a given frequency, it takes time for that energy to fully dissipate and be converted to the nerve impulses our brain is able to process. This creates in us the persistence of vision phenomenon which our televisions and movies take advantage of. It is also the cause of "night blindness" where seeing a bright white light in the dark can prevent the eyes from seeing other lights for up to 1/2 hour. This is a serious issue for pilots and is seriously avoided.
                          Also, our eyes function similar to your motion detection technique in that they average out a given energy level and really only transmit the changes to our brain. While this may enhance our ability to detect differentials with great detail, it does allow for our eyes to be fooled. Events can occur that we simply do not detect because the differential was not long enough and got averaged out. And even when it is long enough, often times our brain completely disregards it.
                          It is possible then, that there is a change occurring - not necessarily a color shift, but possibly a phase shift or a void in the light pattern that is occurring much faster than our eyes can pickup. But it could be causing a harmonic interference pattern in the intensity of the POV at a frequency near that of certain colors. These shadows or voids in the photon stream may be interpreted as colors or motion or waves or all three. If the photon stream is being interrupted, then we probably have a situation where mass, space or time is somehow altering the normal function of the photon in its trajectory or energy level.
                          These voids or shadows may be recorded in the videos. A careful analysis of the line by line data stream may expose some repeating patterns. But I would think that only the HD raw files should be used, not those converted for web upload. It does seem reasonable, that if the eyes can develop these interference patterns, then the CMOS or CCD sensors could as well - but maybe not exactly the same way.
                          It sure is interesting to ponder all the possibilities
                          • Hi all
                            @ Harvey
                            Yes what i mean is to install your camera on a tripod and than spin your device and let it winddown until stop.
                            Thank's for the pix. If i see correctly in the middle of your ice bloc you have a part which goes up (expansion)and just near a part which make a hole (contraction) ? is it right ?
                            @Sucahyo
                            How to check if it is orgone . Any idea ?
                            I will try to electrolise the meltdown water to see if it is better as the original tap water. And poor some in a plant. Who knows
                            @David
                            Yes bravo for your dad.
                            Yes good idea to try to put the pmh near a glass of water and freeze it
                            And thank's for your input.
                            And now some very interesting results.
                            pix 1 is the set up with orientation in my freezer. Notice that the pmh is put on a rubber about 12 mm above the bottom of container. The charge input is 12 volts one or 2 touch.
                            pix 2 is the view of the icing from the bottom (for easier representation i have flip the image to have the same view as pictured from above.
                            notice the red arrows show zones where the ice is very clear but not thick.
                            the blue one show zone of expension thickness.
                            very complex flux indeed.
                            pix 3 is the same but more contrasted and i have marked the relevant points.
                            pix 4 is a side view showing clearly the 2 small monts with the small valley.
                            pix 5 shows a top view during the meltingdown, and where you can see the more thick monts upper right
                            Awaiting your comments
                            good luck at all
                            Laurent
                            • Hey Jedi,
                              I haven't used a coil on my NS...NS setup because the magnets stick together pretty well in that order.
                              Ed wrote " If I open my eye a little more and look sharper (at the sky), then I can see round shining things running in every direction in jumpy paths. Some leave shiny wave like a path before they disappear. Each shiny thing is many times smaller than each smallest bead. They are not crowded, they all use the same speed, but the speed is a little too fast for good observation.
                              To see finer things yet, I look in a gray cloud with the eye open until I see a darker spot. When the spot begins to boil in the middle, then I can see tiny multi-colored streaks running out of the middle. The scene lasts about a minute and when it is gone then nobody can know when the next scene will come around." Ed.L, () by LS.
                              The above was said by another member to have something to do with cells in the eye.
                              I can see the shiny things and the boiling fairly easily outside but not inside.
                              If I look out a window I can see the effect, but not inside at night.
                              • electrolis
                                Hi All
                                i just made a small test.
                                I took 2 identical glasses. one with tap water and one with the water of the meltdown pmh deicing.
                                At the same voltage it seems very clear that the meltdown water perform poorly in comparison with the tap water.
                                So my question
                                A- is the icing and meltingdown of water purifying , as in comparison with evaporation and recondensation (alambic to get distilled water) ?
                                B- or is the pmh modifying (purifying ) the water By modifying the state when icing. ? Is it eventually a sign of orgone ?
                                thank's for comments and suggestions
                                Laurent
