Here is the little guy i put together. Its made from a 7inch diameter pipe cut into 24 sections. It locks when i hit it with current but comes apart the second i disconnect the battery. I bought some pipe like Davids today and am going to try that next. Im sanding it down to a 600 grit to try to get the best magnetic connection.
you guys sot skills!!! when you lock your PMH ..do you evwer feel like a coldness a few inches away??even a small one [the first one i made was out of a 16 penny nail bent into a U] felt cold ...ive drove over 10 miles with it..still works any way this coldness is one way to know when you are locked....cody...jetijs...you guys are AWESOME !....good work..cody,..as long you get a lock and it does not come apart, the orbit of force will continue.....now.. i expect you guys in about 2 days to tell me how to make mine better,also new and interesting findings!..you guys ROCK!...i am so excited...wish i could be there when you get effects.....thanks for every thing...and thanks....Ed
Could one of good people try somthing like this to get your sections to lock: (Not David as his seems to be working & locks ok)!
-Apply DC power supply to the coil. If doing so with a battery you'll know doubt pull lots & lots of amps.. (Good if you can measure it). Let say it's only 20amps. (maybe use a high wattage resistor to obtain a steady current).
-Importantly while the DC battery supply is connected. (and you'll want to do this quick.. connect a jumper lead across the coil.. The coil will then be shorted out and therefore cannot collapse. The DC battery supply will also be in a dead short condition, so I would try inserting a fuse (25 - 30amp) between the battery and the jumper lead.
The second the coil is shorted out with the jumper lead, the fuse blows, disconnecting the DC battery power, but the jumper lead shorts out the coil containing the energy in coil & the iron cores. Then the segments should hold together more strongly. (?) Idealy the fuse should not blow when connected to the coil, but should blow when the jumper is connected to cause the short circuit. Without a fuse you'll be dead shorting the battery but (only for a second) if you disconect the battery immidiately once the jumper wire is installed.
These ares my thoughts but will need to try it, only theory so far from me. ...Bring on the weekend.. I will try to replicate this too.
David, do you think the short-the-coil-out thing is worth a try or not nessasary? -Please don't delete any of your youtube videos as I haven't been able to view the new ones yet..!
Good luck everyone!
This is truly a new excitement not seen here in a while!
Cheers...
The coil is setup as 10 turns of 14AWG wire with 750A which is what I calculate as the maximum amperage for that wire resistance and 9.6V applied. Some batteries can deliver this current no problem and the wire can withstand it for a few milliseconds, but in Davids case I would imagine the current only spiked to that level for a very narrow period before the voltage dropped in the battery.
Notice the last image that shows very little magnetic flux 180° from the coil - the magnetic clamping at that point would be very little, hence the need for tape and tie-wraps to keep things together. Four coils, 90° apart would probably provide a much better flux within the ring with more holding power. It is the flux that makes each segment become a magnet. Notice that the flux takes the shortest path for a given permeability - this is why some of the flux exits the material and uses the air to reach its destination.
From a magnetic clamping point of view, the pipes could be truncated right where they touch. But we don't know what is really happening here. It is possible that each element is acting as a T-Wave resonating cavity and that he is witnessing T-Wave radiation interference - but that would not explain the gravitational reactions he feels.
David,
Could you make a balance beam that is level with that counter weight or Quartz Geode hanging on one end and then slide your rig under it to show the change in weight? All it really takes is a board, a bag of sand on one end and your object on the other with something tall enough for the board to balance on. Maybe make an A-frame from some water pipe as a fulcrum for the board to balance on.
come on guys...help me out here..i live in salem oregon...my invitation stands solid ...any one ...get a message to me i will show one person or a group of people what i have found ..ask.any questions ..if anyone does not see this wave form with their own eyes..i will remove all posts and videos and post no more....what have you got to loose???this machine works ...you have got to be curious ..send some you trust or come see for yourself...please ..i have nothing to hide ...think about it...i will be in lincoln city today but home in the evening...you will NOT be disappointed....i know talk is cheap ...come see for yourself...step by step any of the claims i have made ...i will gladly show my work ....has any one ever made a claim like this and was willing to do this???...either i am a crackpot or ....you could be the one to say i exposed the hoax or maybe there is more to this...i will even go as far as letting my machine be borrowed [i just want it back after you are done with it]....where and when will you ever get an offer like this??? come on over, i will show you how it works take my machine with you and experiment yourself.... show it to who ever let someone else borrow it .....i really dont care how long ,just as long as it comes back .....what more can i offer??? and again i promise you will not be [email protected]... thanks
Hi David,
I see your making a plea for someone in "Oregon" well you may be in luck .... living about 50 miles from you at the end of the "Oregon Trail" and went much further for another member ... but ... I'm kinda busy for the next week but drop me a e-mail at [email protected] and we'll see what you have.
I'm sure there are many forum members here whom would trust my findings if your really up to it, I can be very skeptical but open minded.
* Edit post
* Delete post
* Report this post
* Reply with quote
Re: gravity waves found
Postby david lambright » Thu May 13, 2010 2:53 am
Ed learned how to generate what he called magnetic current...he never says any thing about any wavy distortions like a heat wave..he did leave some BW photos..i started making PMHs with a single junction....5/8 steel rod bent into a circle with one coil close to the3/16 gap...like if you cut a solid steel ring in one place ..a junction if you will.....the mating faces were not perfect,but it would lockup easily..tried different coils,more junctions,magnets at the junction etc....then i thought i saw the wires moving...i soon realized that it was this energy wave...looks like heat..more powerful than a speeding bullet....then i saw it in Eds photos....the heatwave ..his pictures are a bit grainy but i see it...look at the photo at the quarry....the stone behind the tripod..it looks funny,like it is floating...look under and to the left of the stone at the way the image smears but only there,the rest of the photo is in focus...i knew that what i saw on my steel circle,was the same thing i saw in Eds photos,but i didnt know how to make this wave stronger...i got stuck for a minute,then it dawned on me ..Eds machine is a 24 section PMH!!.. ive tried less but 24 worked good.... from the beginning, i knew that metals had acted strangely near the ring,copper ,mercury, aluminum,...all metals act magnetic near ring ...once i made a 24 sec. PMH, i tried metals near the ring with good results...crystals work good too..i started seeing the wave easier ....then i showed my family and friends...every one sees the wave now...its time the world sees it too...there are people working on their own generators,as we speak ..it wont be long now...they will see this wave and do what we have always done with waves...harness, manipulate.utilize.......david
glen..i am busy as well but cant wait for you to expirence this ...prepare to be de-skeptcized ...if there are others car pool...save gas! invent stuff ....be ever curious.....david
@Jetijs is your steel magnet? ie does a magnet stick to it. The best pmh I've seen are NOT magnet including david's setup.
@David, have you tested this at different places, does the effect remain? Can you be really specific about the type number or so of the galvanized steel pipes.
I like your openness and impatience it means the truth will unfold fast.
@all, has anyone taken a magnet to coral castle and tested if the wheel was magnetic and/or affected magnets or others pieces of metal strangely. Call it on site experimentation . It may be that the wheel needs a pulse (however that's done) like a pmh to show its true self.
In the above picture, it looks like the 24 parts are seperated from each other by a binder of sorts. Potentially a material to physically keep the plates separated as I above proposed, or otherwise to enhance their attracting, perhaps via a material of lower magnetic resistance?
What's all the white stuff, concrede he poored over it to stabilize the device?
Anyone know what these guys on the video are seeing? Perhaps this is magnetic waves? Bermuda triangle is near where Ed lived. I believe there is some type of vortex in oregon too? If you happen to have a infrared imager, it might show up better.
