gravity waves found
  • jetijs!
    sorry about buggin you....how many hours time difference is there?....i will be looking for your posts!....david...also i was thinking....the FERRO magnetic aluminum you made...could you use some of it for a core to make an electromagnet core?...i bet you already thought about that.....david...also has anyone heard about my devices on other forums/threads?...thanks
    • Hi David,
      our time difference is about 7 hours
      I looked carefully at your ring device and could not see anything you mention, I showed it also to two other people and they didn't see anything also. I will have some sensitives over at weekend and will show the ring to them. Also I will have another look using black background and good lighting, this usually helps me to see my aetheric body around my arms. I can see my etheric body anb hope I will see something around your device. However if it will be much harder to see than the aetheric body around my hands, then I guess you could see something like that looking at about anything if you try really hard. This is also one of the reasons why I will send you one of our orgonite pendants to see what you see around it. Might be that you are simply very sensitive. Or one more time the location plays a role. Will keep you updated about this.
      I have not thought about your aluminum core thing, sounds interesting
      Another update is that I finally bought some of the ford model T V-magnets, hope they will arrive soon, then more experiments will follow. At this time I am busy with other stuff.
      Jetijs
      • No one commented on the surprise ending so I thought perhaps the video link was overlooked in the above post. But I see that at least 28 persons have viewed it on You-Tube.
        For those that missed it, here is the direct link:
        YouTube - Lambright - 014
        (I'm going to start processing my last videos now and hope to get them up today)
        • hi everyone...
          @jet...not to worry, i know its not an easy thing to see!...but you will!...also try testing the inner coil to the tube with a volt meter....on that same device, i was getting a small but constant voltage/current....anyway, if you play with the device, you will see this radiation/glimmer/hazyness/lensing effect i describe!...david
          • Originally posted by Harvey View Post
            Sorry Jetijs, (or was it someone else that asked me to do this - I can't find the post now )
            I said I was going to check the convective outlook before doing the test and I didn't - so the test was a bust - I'll have to do another when the Forecast is "Clear Skies"
            I honestly had no idea that this cloud bank was moving in - it had been hot and clear for days
            At any rate - here is a quick video - check the video information for the forecast data: YouTube - Lambright - 024
            Do you think the fan changes anything? I was thinking a motor might interfere with the Magnetic fields so . . . I used the fan.
            I still have more stuff to process when I get the time things have been busy this week already.
            Have I over looked any requested tests?
            Cheers,
            I think I am losing my memory - I have a photographic memory note of Jetijs asking me to put a small motor on the rig and me responding that it was doable - I searched the whole forum looking for a comment by Jetijs that even remotely resembled what I have in my memory and I could find nothing by him or myself that resembles the image I have in my head of the conversation.
            Right memory image, wrong forum
            YouTube - Broadcast Yourself.
            • PMH In Place - No Magnetic Flux Lock
              Setup Video:
              YouTube - Lambright - 025
              <Zoom <Zoom <Zoom
              Notice the Missing Element ^
              <Zoom <Zoom <Zoom
              <Zoom <Zoom <Zoom
              <Zoom <Zoom <Zoom
              <Zoom <Zoom <Zoom
              One More Picture Left: Picture Sixteen
              • How to make instant hot ice.
                Make an ice cube sink with heavy water.
                Use a vacuum to freeze water in less than 90 seconds.
                Dry ice.
                Let's not limit ourselves to just freezing the water and melting the ice.
                GB
                • jet!
                  jet, try this...try viewing in a dimly lit room!....let me know if that helps!!....david
                  • PMH Locked - Boiled Water
                    Video:
                    YouTube - Lambright - 026
                    <Zoom <Zoom <Zoom
                    <Zoom <Zoom <Zoom
                    <Zoom <Zoom <Zoom
                    <Zoom <Zoom <Zoom
                    <Zoom <Zoom <Zoom
                    Continued . . .
                    • . . . Continued:
                      <Zoom <Zoom <Zoom
                      <Zoom <Zoom
                      So it would seem that there is a specific dissolved gas that reacts well to the PMH lock - Freeze Zone arrangement and produces the multitude of radial bubble lines. Removing the gases by boiling also gives the water an unstructured orientation of formation even in the presence of a PMH Lock.
                      The best results occurred when the center bump was removed from the melt and new water was added to compensate for that loss.
                      The side view of the ice indicates that the freeze zone propagates from the bottom and top surfaces as well as from the outside edge thus pushing the gases toward the center of the melt from all directions. This means that the ratio of thickness to diameter can change those bubble arcs. Where the ratio is very close, the arcs will be relatively smooth and curved. Where the ratio is large (as in my case) the arcs will be shallow giving way to long horizontal striations.
                      It is unclear why the gases tend to follow particular lines even when the line is broken up. I did not observe any lateral shifts where a particular line was offset by less than the angular displacement of a full bubble diameter. It is possible that such occurred in the hub under the bump, but this was not observed do to the plethora of bubbles in this region and the visual obstruction they impose. It is also unclear as to what sets the bubble diameter. In the case of no PMH and the Missing Element (no magnetic flux lock) the bubble track diameters were markedly reduced - some even being microscopic.
                      It should be noted that during the the test with no PMH, the vertical position of the Pyrex was lower by the thickness of the PMH (~1"). Also it should be noted that the rack on which the PMH rested in these tests, and the Pyrex rested in the aforementioned test is made of ferromagnetic wire encased in some vinyl or rubber insulator. What part, if any that these things play in this process is unknown. It should also be noted that the refrigerator itself does in fact constitute a Faraday Cage - thus we can rule out any external EM interference in those frequencies and magnitudes that are unable to penetrate the casing as being an influence in these tests.
                      There have been no requests for the extended meltdown sequence and shots - so I may simply forgo even processing these as it is a rather boring sequence of melting down the prior freeze already documented.
                      I'm going to put my rig outside for a while and see if soaking up some rays has any impact on the 'glow' or 'glimmer' I am hoping to see
                      • Thanks Harvey, great stuff
                        David, your ring device puts out 0.2V at the inside coil terminals. Is that coil made out of enameled wire or a bare copper wire? So far it looks like just ordinary galvanic action between the copper, iron oxide and aluminum. A galvanic battery. Will test more to see the current and overall power output
                        Jetijs
                        • Here are a couple others for your entertainment :
                          YouTube - Lambright - 027
                          YouTube - Lambright - 028
                          Note that these are unlisted videos and you will need these links to watch them
                            Jetijs
                            Let's not overlook the possibility too that it could be a thermoelectric effect. Where dissimilar metals are in contact and that junction has thermal energy applied, an electric current will flow there.
                            Also, the ring itself can be a loop antenna and thus prone to Electro Magnetic fluctuations which in turn can cause an induced current of small magnitudes. And this could be quite interesting where a PMH lock is in place.
                            • The good news is that I did get the HD camera and was able to do a High Definition two stage tripod rundown on a single video showing the PMH Lock and rundown, then breaking the lock and doing another rundown.
                              The bad news is that the file is over 2GB, nearly 14 minutes long and my system cannot handle the editor. Also, there is some very annoying background audio that needs to be dealt with.
                              So it may be a week before I can get this one processed My son has a system that can handle the editing - it is just a matter of getting our schedules aligned.
                              Till then - it there are any low res tests you would like done - let me know.
                              David, I haven't forgotten about your suggestion regarding some quartz rock - I'll have to go rock hunting and find some
                              • Directory:Flynn Parallel Path principle device - PESWikiWesley Gary's Magnetic Motor
