gravity waves found
  • sucahyo...
    i always thought the kirlian method was too cost prohibitive...as far as colors...i dont see them in the dark yet...only with the IR and in light,natural and artificial...
    • Change contrast Hue of film
      Hi
      Maybe by changing the contrast/hue of the film something will show up. I took some screen shots (10) frames and imported into photoshop and changed the Hue / Contrast blue/red then put it into a flash file. Not really conclusive what it shows but seems to show some movement and maybe worth developing. I'll see if I can host the flash file somewhere as the forum will not accept them.
      John
      • Hi all.
        Today I made some new tests. First of all I thought that the battery type that you use to energize the setup could be important. Tried it with a 12v NiCd battery from a portable drill - nothing. Then I tried if the tape around the segments would do something, as David has some tape on the pieces and they are essentially closed on the sides. This also did not give any results. Then I thought that maybe those pieces should indeed have their bottom sides left open and not sit on a plate. So I cut my rotating plate in smaller diameter and drilled a hole in 6 of the segments. Then I put a bolt in that hole and assembled the pieces together. The whole assembly is now attached to the rotating part via those bolts which are fixed with hot glue. This also did not help, I tried two battery types for this. So I am beginning to think that I live in an energetic hole or something
        BTW, this is my huge PMH
          So I am beginning to think that I live in an energetic hole or something[/IMG]
          Jetijs,
          Do you live near a nuclear reactor or near a location that has had a nuclear accident?
          IndianaBoys
          • Not that I know of
              Not that I know of
              Anybody you know have a Geiger counter to check the levels?
              IndianaBoys
              • jet...
                i just dont know...did you get a compass and charge it, making it change poles?.. i do not know what to suggest....your spot is reserved, jet, after matt...cheers
                • So strange, you still can't get a lock or effect, using the same pipe?
                  I looked up (1 minute only) possible climatological differences. Very maybe himidity is a factor here. Don't wish to waste your time, but the proximity of a damping mug of tea might not hurt to try.
                  A more loose thought, inconsistent with David's second device working so well, is that too much symmetry may not always be best. Your work quality may in some experiments seeking to reproduce an anomoly, work against you?
                  How hard to get are Ford T magneto thingies as Ed used? At least they're a standard part to some degree.
                  If only we knew what parameters make a device like David's exhibit the effects, we could make something more luck-proof.
                  Also inconsistent with David's work, but what about shorting the segments with simple steel or copper wire? Ed may have hidden a secret/sacret crossing pattern under his concrete, taking away the need for a lock between the main segments themself. Pardon if that's a stupid idea.
                  • clox
                    all your ideas have value...know that ...david
                    • jet
                      do you have any conductive grease?...like used on aluminum conductors?...i did use a bit of that on #2... ...david
                        Not that I know of
                        • Jetijs,
                          just a gut feeling - those pieces are almost oval shape and I think they should be more "U"-shaped or even "V"-shaped. According to Leedskalnin's theory this will not work (extra pole in the middle).
                          Sorry if I'm way off, but I've been reading and re-reading Leedskalnin's papers...
                          ABC
                          P.S. I think Leedskalnin used just a regular steel wire to transfer this "field".
                            Still got no compass, but the locking is there, it is not strong, but it is there. I can see it when I take off the zip ties.
                            Those magneto pieces cost a fortune
                            Don't have that, will see if I can get some.
                            I am about 30km away from Salaspils, as far as I know that reactor was depleted and all the nuclear waste was removed and shipped to Russia several years ago.
                            Thanks!
                            Jetijs
                            • Magnetic Aluminum
                              Regarding Harvey's...and David's PMH test that induced a residual magnetic charge in Aluminum.
                              If you do the same test using ONLY two Neo magnets and a piece of Aluminum you can get the same effect.
                              I used a small piece of pie tin aluminum. Placed the Aluminum between the Neos for a few seconds to a couple of minutes. Took it apart - then tested the attraction of Aluminum to the Neo. Yes!
                              Seems to be a temporary effect, but none the less... interesting. The charge does not seem to be permanent, almost as if it is a "charge" which depletes over time.
                              Although the Aluminum is attracted to the Neo, it shows no similar effect to other weaker permanent magnets.
                              YouTube - SinkScience #13 - Will It Spin??
                              • hi everyone
                                jet...how much residual magnetism is in your device?....because the segments are steel, could they have been magnetized by too much current?...my device is not magnetic as far as steel sticking to it...iron filings do not stick either...if they have been over magnetized, i am not sure of a way to de-magnetize the steel?....will steel or iron stick to your segments?...just a thought...the reason i say that is i have a toroid single junction PMH and it was left near a neo magnet...after that i had trouble getting it to lock...david
