gravity waves found
  • wit...
    Originally posted by witsend View Post
    YES. Now I see it. Yellows and graduated colours of blue. VERY NICE INDEED. Golly Dave - this is really getting interesting.
    Please tell me. Do you get any subtle sense of repulsion and or attraction if you hold a magnet near your rig. And if so where and what? If there's no magnetism then there should be a sense of attraction no matter where you place the magnet.
    if i hold a 10mm neo magnet about 13cm away at the plane then move slightly up or down, i feel both attraction and repulsion, although it is subtle...hold the magnet pole towards plane...that video was shot using IR and a window screen...i am working on another video...you will like it!...david
    • this may help
      Originally posted by IndianaBoys View Post
      David,
      Can you give us the time frame in the video where you see the color along with the location of the color?
      color with night vision????
      YouTube - color with night vision????
      IndianaBoys
      • hi...
        can any one else see it??http://www.youtube.com/watch?v=KlNhLiuGrzg...a ......
        • Hi
          I have posted up the swf with the hue and contrast changes I mentioned a few posts back. Still not quite sure what it shows, but there appears to be some sort of movement.
          PMH swf - EnergeticTube.com -  Where technology goes LIVE!
          John
          • Hi folks, thanks for the nicer words, whether something works or doesn't work or is a hoax and i was unaware, what really matters is not the technology, it's how we treat each other and create peace and harmony. Notice, it's not how much technology we have, it's the wisdom that goes with it that makes the world worth living in. By the way, i did see in that video david lambright, at 37 seconds a rod or orb move from left to right, to the right of you.
            peace love light
            Tyson
            • Originally posted by john_g View Post
              Hi
              PMH swf - EnergeticTube.com*-* Where technology goes LIVE!
              John
              John,
              I got this message after clicking the link:
              Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
              Not sure if it is from my end?
              IndianaBoys
                Probably an insect, although it appears from nowhere which seems strange. Theres also one at 27 seconds, just to the right of the one you mentioned. This one curls unlike the one at 37 seconds.
                p.s. heya all. my first post and this thread is the reason for my registering. Would love to see something come of this topic. Its very intriguing what dave has found.
                Always thinking outside the box!
                ASUS M4A87TD motherboard
                AMD Phenom II x6 Turbo Core 2.8/3.3 Ghz Overclocked to 3.5 Ghz CPU
                RIPJAW 4GB 1600Mhz DDR3 Memory
                Gforce 9800GT 1GB Graphics
                Windows7 64bit OS
                20" LG LCD 1680x1050 Monitor
                • Originally posted by david lambright View Post
                  Hi David,
                  It is my understanding that the night vision mode of these cameras simply use a different amplification algorithm for the existing sensors which have IR capability, but it is the same photoreceptor used for normal color reception. So it would seem that if there was a fair amount of color energy present, it would bleed into the receptor and be processed.
                  This can be especially true where an IR lamp is used to illuminate the subject and the subject contains IR fluorescent pigment (like some LCD displays do).
                  Here is a company that specializes in IR ink:
                  IR Inks & Powders
                  I hope this helps to clear up why night vision can produce some color in the final image and why the human eye can see color when illuminated by IR light.
                  Cheers,
                  • john
                    Hi
                    John
                    beautiful work...my last video shows a lot more...i hate to ask but could you enhance my last vid ....it shows lots more.....excellent stuff....david
                    • Originally posted by Harvey View Post
                      Hi David,
                      IR Inks & Powders
                      Cheers,
                      are we talking about the same vid?...http://www.youtube.com/watch?v=KlNhLiuGrzg...a
                      • Hoffman Box
                        Hi TP. I actually tested this. I put my cell phone inside a glass - covered it with foil and then dialled the number from the land line. You're absolutely right. No signal. Took it out the glass to check that it was working. It was. Put it back in the glass in case I dialled incorrectly. - NO RING. LOL
                        Something's not quite right with the levitating glass experiment - somewhere. But it looks good.
                        Well done Wit !! you have just proven to yourself the efficacy of a Faraday Cage or Hoffman Box. Fact is, you could have constructed the shield from quite coarse metal flyscreen (with thousands of holes) and it would have just as efficiently blocked the waveform...hence the reason why you are safe when looking through glass door of microwave which is a far more powerful radiation. Manufacturer's use a metal screen sized sufficiently to shield the radiation whilst allowing you 'visual access' to what is cooking inside.
                        Anyhoo...back to Dave's thread and on topic
                        TP
                        • Has anyone been able to replicate Davids observations yet? Or has the person who received Davids device observed anything?
                          • Now that I have uploaded over 75 videos to You-Tube over the years I can see the differences between what I see as reality, what my camera records and the end results that You-Tube gives the public. Unfortunately, You-Tube compression not only reduces the quality even in HD (as 720P is less than 1080P) but it also introduces pixel extrapolation in the compression processing.
                            Here is an example of what I am talking about:
                            YouTube - Optical Compression Evaluation of Light in Magnetic Fields
                            Be forewarned that if you are already familiar with these optical aberrations, watching this video will subtract 9 minutes from your life that you will never get back
                            @David,
                            Yes - I have watched all of your videos, most of which I have watched more than once in an effort to see what you see. With one son in the filming industry I have watch a fair quantity of footage and have seen a lot of different things that look like one thing but turn out to be another. So it certainly adds to my discernment when evaluating various videos.
                            One thing I did pick up very clearly from closely watching this video:
                            YouTube - potatoheadist's Channel
                            is that there is a very clear reflection on the edge of the telescope tube from a green light source - perhaps an LED on the camera. But this reflection has a specific focal length and is blurred and shifted when you zoom in and even takes on a reddish tint.
                            On my monitors here (we have 5 different monitors) I am unable to see the fluid motion you describe and I really want to see it.
                            One of the strongest indicators that you really have something there was the two photos (still and motion) of the Lorentz type contraction but for some reason my request (360° walk around) in that regard were ignored and the evidence was set aside and left alone. While the motion of your device may not be moving at speeds we would expect such contractions to manifest themselves I feel it is necessary to emphasize that motion is relative. The Lorentz contraction occurs at any relative velocity not equal to zero, so even a snail experiences it but it is near impossible to measure. Now, light does travel at relativistic speeds and your cameras are using that light to record the time relative events that we do not see with our naked eyes. So what you are seeing with your eyes may be reflections of the contractions that look to you as heat waves. I'm sure there are some persons out there that understand the importance of what I am saying here - it is not to be dismissed summarily, especially by the very misleading inductive logic I've seen being applied here. Inductive Logic = Jumping to Conclusions without proper evidence. Therefore it would be wrong for any of us to dismiss your claims on the grounds that the evidence is lacking and by the same token it is wrong to dismiss Lorentz contraction on the grounds that relativistic speeds are not present (when in fact they truly are in more ways than one).
                            If your video that irrefutably shows some type of contraction are due to something else, like photographic compression, then I am all for learning what that is because I cannot find anything that even closely resembles it on the web anywhere and in my honest opinion I think that is every bit as important as the discovery of gravity waves. At least it is much more solid evidence than flickering pixels that clearly happen here at my location without the machine nearby. The contraction issue begs an answer.
                              here ia a link to annotate my last video...YouTube - do you see it now? any one wants
                              Hi Dave. INDEED I do see it. BETTER AND BETTER. I also realise now why you were anxious to get comment on this from other witnesses. I get it you see the same colours as the camera is showing us. This rather rules out the argument that the colours are due to camera distortions - unless, of course, our eyes are somehow 'imposing' a colour. Strange then that we 'imagine' the same thing the camera 'sees'. And then - we would be expected to entirely discount the 'evidence' of our eyes in any context at all. Bit harsh. I'm sure you guys see clearly. I think I'm in a minority with my level of myopia. To my way of thinking that's just common sense. I suppose it could be termed inductive reasoning. Not sure.
                              This is really getting interestinger and interestinger. How's that for a new term? Personally I'm not averse to inventing new words. LOL. It's only when one changes the properties of known physic's terms that there's a problem. I\m of the opinion that it would be more respectful to our Giants to acknowledge the sense of their discoveries. And - in terms of light - the ONLY thing that is known to bend light is gravity - thus far. I still say you've got a gravitational effect.
                              Thanks for the explanation re the 'repulsion/attraction' bit. That's also comforting to learn.
                              With very much gratitude for all your very hard work and VERY WELL DONE INDEED DAVID. You have clearly got something here. I would earnestly propose you try and get this to an academic forum. Who knows? There may be someone there with enough curiosity. Try the astrophysicists. They're renowned for using both Classical and Quantum disciplines. And they've got to resolve 'dark energy' somehow. Perhaps this will be the kind of evidence they're looking for.
                              EDIT - May I add - that it is possible to distort the path of light through artificial means. It is NOT the same thing as the light that literally 'bends' around solid objects in space as seen and photographed - often during an eclipse. And I do not think that any of us can accuse David of introducing any artifice to show any light 'distortions'.
                              Second edit. The following an extract explaining a variant of the Bessel Beam effect.
                              As with the Bessel beam's diffraction-free "propagation," light doesn't actually propagate along the curved path. The beam is the pattern created by interference of light from the 500,000 carefully-phased pixels of the SLM. Still, Mordechai Segev of the Israel Institute of Technology in Haifa is impressed. "It's a beautiful piece of work," he says. Segev envisions using similar phasing tricks in situations where multiple light beams are needed to create a specific light effect at a precise distance from the source. "If you engineer the phase the right way, you will only have white light where the pulses meet. Imagine if you did something like that in the atmosphere," where Airy-like beams could improve LIDAR, a type of laser-based radar used to study the atmosphere.
                              --Mike Wofsey
                              Mike Wofsey is a freelance science writer and Ph.D. student in theoretical physics at the University of Alabama in Tuscaloosa.
                              • Light Beam with a Curve | Physical Review Focus
