gravity waves found
  • Originally posted by mrbreau View Post
    Link; YouTube - FUELLESS HEATER NO FUEL NO GAS NO WOOD NO GREEN HOUSE GASES
    Here is a start to a neat search. It is about four or five years old but gaining ground. This guy decided to capitalize on the water hammer and has now produced and sold a few systems. FWIW
    Sorry! I know this is off topic but the answer has to be presented where the question was asked. Right?
    Warren
    Actually, it may be closer to on-topic than we may realize!
    Notice the action occurring in this video:
    YouTube - SPR Cavitation Dye Test
    And the descriptor of what is happening here:
    R&D - Hydro Dynamics, Inc.
    I can't help but see a similarity between the top view profile of David's elements and the cavity used in those SPR rotors.
    Could it be that David is getting a similar cavitation in the elements with air? Perhaps the relative humidity and dew point are critical factors
    Just exploring all the possibilities here
    • and now we return to the "Gravity Waves found" discussion and the Saturday videos....
      • What does the compass say?
        @ David
        Originally posted by david lambright View Post
        you can energize the device after assembly...a compass will tell you when you have lock ...
        What is the procedure to knowing that the wheel is locked? What does the compass do that is different when the wheel is locked? What should I be looking for?
        I was of the opinion that each side of each part would show a different pole but that is now what I got. Instead, I got four poles, two norths and two souths. I assumed the wheel was locked having gotten that far. Thinking that two norths and two souths was a locked wheel isn't so very far fetched since a washer shaped magnet has just that as does the cylinder magnet in the fan motors I've hacked. Now I'm finding other motors with even more poles in them.
        Warren
        Men had been depending for too long on the authority of the great minds of the past and that they should rely more on their own resources in obtaining knowledge.
        Francis Bacon
        • Men had been depending for too long on the authority of the great minds of the past and that they should rely more on their own resources in obtaining knowledge.
          Francis Bacon
          • Fwiw2
            FWIW
            I believe, and have already stated so, that David just might have developed a magnetic gate.
            Link1; YouTube - Discovering Magnetism Magnetic Gates Howard Johnson 2006 part 1
            Link2; Bedini's Magnetic Gate
            Francis Bacon
              @ David
              Warren
              i have had so many different configs of pmh... with a toroid and single junction, i had as many as 6 poles....the config now seems to have 4.....when i say lock, i am not saying a strong lock...just strong enough to get the "flux"path to lock and start an orbit of force inside the metal.....the compass when placed in the center and then energizing, usually the needle will spin first, then stop at a different point than the beginning...i had the rotor on upside down at first but after i switched it i did re energize it..your setup seemed to be doing all the same things as mine, great work... ...the effects i listed are subtle...but they are there! ...sorry about not getting back to every one, please forgive me..saturday market......why do people not like to be filmed....plenty of people saw the wave ....nobody wanted their picture taken...maybe it does steal their spirit!?....any way i hope this helps ...also it seems that to get the best visible effect, after its working again, hold a weight of steel or iron over center axis, around 10 degrees off towards north and spin it ...you should feel a spot where it pulls down the most.....thanks...david
              • David, the pipe has arrived. I can start building. If you have something to add or suggest, please do.
                I will document everything.
                Jetijs
                  Jetijs
                  Let's hear it for international delivery success
                  galvanized pipe is usually a bit bumpy - but David did say "leave the Zinc on" - so... I guess it means just smooth off the bumps where they connect right?
                  BTW - I was looking at Ed's rig and noticed there are 4 coils permanently wired at each indent of the cloverleaf ring. Also, in his writing he mentions using a coil to enhance the magnetism of the 'generator'.
                  Also - I did not know that he moved everything to a new location after he was almost finished at the old place. I've been learning a lot the last couple of days
                  • Thank you for your kind words
                    I've been learning new things here, so this is fresh for me. I would like to hear more about the magnetic Aluminum and its specific interactions. I was thinking how could it be magnetized and yet not effect the compass reading. One way would be if there were U shaped flux channels in the material like so:
                    <<< Needle ^ Here<<<
                    nnnnnnnnnnnnnnnnnnnnn
                    So the upper part is normal Aluminimum, but the bottom layer has those U-turn paths that can be like Ferromagnetic material and even hold a magnetic charge.
                    • #2...
                      hi everyone, i will be posting the video and link in a moment.Yes about the zinc,smooth the bumps down to get good contact, for the most part leave the zinc on. I will be going step by step through all of it.I will try to answer all questions.I know there are easier way's to cut the pipe, but I will show you how I cut it. More soon!.....dave...here is the link....http://www.youtube.com/watch?v=Jjh5OE6yerk...thanks...part 2;YouTube - step by step #2..........part 3;YouTube - step by step #3
                      • hi kubi
                        i am starting the build videos and should be done tomorrow ...i will be free after that ...or if you are in the neighborhood, stop by...and saturday market was educational...i need a cameraperson to capture the moment they see the wave...i will try next week.....thru october!......david
                        • David,
                          I have cut the pipe you sent me in 12 pieces, each 2" long. And all those pieces are cut in half.
                          Tomorrow I will see what HDPE boards I have at my disposal and continue the work. I will go slowly and do everything according to your videos to get everything as close as possible to your setup.
                          Thanks!
                          Jetijs
                          • damn JET.........your attention to detail is more than admirable
                            as we say over here........ you're a good'en
                            • Thanks Rave
                              It also turned out that the laser unit is now repaired and I will have my laser cut Leedskalnin wheel any time soon. I noticed, that Davids pipe material is much softer than anything I used before, this might or might not be important
                              • JET.........go easy with the laser cutting thing.........this might be one of those things......where.........elbow grease pays dividends.......the laser "might".......affect things in a way we cant fathom as yet
