gravity waves found
  • Loadstone
    I think If Ed watched that gravity video he would probably say this.
    " We have North and South pole magnets, positive and negative electricity, protons, and electrons, positrons and mesons and alpha, beta and gamma rays. Now why such a confusion? Does nature really need so many things in the perpetual transformation of things, on building up the matter and again taking it into parts? I think all that nature needs is three things, the North and South pole magnets and the neutral particles. Each kind of those three things can act differently with different speed and different combinations, and so they can accomplish different results. I believe the prospective physicists first should learn what magnets and electricity are, then they will have a sound base for their experiments and their calculations." Ed.L
    Don't forget muons.
    Or maybe he'd say this.
    " Gravitation must be caused by the matter in the middle of the earth, and more concentrated than Uranium. When Uranium atoms burst they release the North and South pole individual magnets that held the atom together, then the magnets scatter all around, but when the atoms burst in the middle of the earth, and many burst at the same time, they can only run from the middle to the outside. When the North and South pole magnets are running alongside each other and in the same direction, they have no attraction for the other kind. They only attract if they are running one kind against the other kind. When the magnets are running out of the middle of the earth, as soon as they meet an object they attract it, on account of the fact that in any object there is both kinds of magnets in it. It can be seen by rubbing hard rubber or glass until they get hot, then they will attract sand, iron filings, salt, and other things. To see how it functions, move a salt crystal a little, if it happens to get on a different magnet pole, then it will jump away."
    "The difference between the rubber magnet and the steel magnet is that the magnet in the rubber comes from the magnets that hold together the rubber, and both North and South poles are in the same side of the rubber and the magnet poles are small and there are many of them close together, but in the steel bar the attracting magnet is not the magnet that holds together the steel, but the surplus magnets the circulating magnet that was put in it."
    Ed.L
    Then he would go away doing this
    Scotty.
  • sucahyo
    Its true that we don't know many thing about the radiation emitted by PMH. But since you never report headache or such, I think it is save.
    Let just compare this with many brave joule thief replicator, they still run their circuit even if it create headache for them and never even bother to know what is going on or wether they can prevent the headache effect. Brave people ...
  • david lambright
    hi everyone...
    just a thanks to all who have been following this thread...plus a warning...smokey2 at OU suggested that the radiation that this device emits has not been evaluated as to what kind and/or strength and it does radiate...i believe.that anyone replicating these devices be mindful of these facts...i will still mail these devices to those people who were interested, just let me know if you still want me to do so......jetijs, your device is ready, i made yours with an internal coil, inside the oxide core, as well as an outside coil for charging...[i will charge it before i mail]...let me know OK......and thanks again....david...also i am posting at OU a new kind of visible radiant energy? ...david
  • sucahyo
    Originally posted by woopy View Post
    It seems there is a vortex ring around each pole. The vortex are mixing in the midlle of the PMH and are pushing the ice higher than it should be normally. The vortex effect is also visible on each side of the PMH. so in pix 2 and4 you see the 3 waves. A big one in the middle and two smaller on each side. On pix 3 you see the vortex from above.
    Interesting .
    Can you do it with higher level? Because I think water show something similar to iron powder on magnet although it work not just on magnetism.
    Can you take the picture of ice in front of ambient light or dark background? the first one show it better.
    See if you can notice air bubble, you may need to increase water level for this. My camera do not have zoom so I can not show it clearly but the bubble is near the top part but bellow many small double helix air column:
    Colloidal Gold Frozen Ice Cube from 2008 project:
    Cool . Is that without anything else that produce energy?
  • rave154
    i watched the emoto video ( strange his name is Emoto......Emote? )...but anyways.,,......i had to laugh at the "mother teresa" one....(Not many people know what a callous, heartless, money grabbing biotch she was )......hence........my laughter at the pretty pattern produced from the "Mother Teresa" pattern
  • rave154
    indiana........FINE work !!!
    can you do a control sample.....the same technique.....but using something innocent.....umm......i dunno what to suggest........a leaf maybe?
  • IndianaBoys
    Picture does not do justice as to how fine a detail there is.
    IndianaBoys
  • Jetijs
    Originally posted by Cherryman View Post
    Briliant! I already had something similar in my mind about how the magnetic currents travel in Leedskalnins wheel. Good to see something that confirms that.
    Thanks!
  • Cherryman
    @ the Icemakers
    It's hard to get a neutral starting point with water.. Don't forget that you're thoughts or surroundings can influence the ice-structure as well, at least.. according to Dr. Emoto.
    YouTube - Water, Consciousness & Intent: Dr. Masaru Emoto
  • IndianaBoys
    Woopy,
    If you have a colloidal silver maker, use distilled water to make the colloidal silver using the hot water method. Boil you water and then put it in a glass container where you produce your colloidal silver. No salt needed. Then freeze it. Should turn out clearer.
    IndianaBoys
  • woopy
    Hi all
    @ Sucayo
    the PMH in ice is a very good idea
    and here the result in pix.
    I placed my PMH charged in a small and long plastic container with some tap water. And put all in the freezer.
    2 hours later very interesting result.
    On pix 1 i have pushed the contrast to better see the cut view of the vortex ring (so far it is vortex ?)
    just my 2 cents
    good luck at all
    Laurent
  • sadang
    @ Cherryman
    Very interesting video. Hope will remain there for a couple of days. Could be a very possible theoretical explanation. David should be the first who can test this, cause he already has the device running.
    sadang
  • Loadstone
    V magnets
    Hey Jedijs, You will have to find people who work on vintage cars.
    The guy I found knew another guy who had a shed on a farm...yada yada....and that's how I got all mine.
    There was some for sale on E-bay last year. Someone was selling the whole replica of Ed's wheel!
    I suppose it's a matter of luck, but they are out there.
    Scotty.
  • Cherryman
    YouTube - Secret to Coral Castle and Pyramids AntiGavrity - SHARE BEFORE REMOVED FROM YOUTUBE!
    informative video about the Leedskalin device.
  • Jetijs
    Can someone point me where to buy those V magnets for fort T model? As far as I know those are ALNICO. Harvey posted a link long time ago, but I am not sure if you can really buy magnets there because they only send you recharged magnets if you send them your used ones back. I don't even have used ones.
    Jetijs
