gravity waves found
  • Harvey
    The Good news is my son not only provided the system to process the video, but he even volunteered to help get rid of the annoying background noise, lay some nice music and convert the AVCHD file (over 2GB) into a You-Tube friendly resolution and format. Many thanks to Phil for that
    The bad news is that the file is still around 1.7GB uploaded in High Definition and You-Tube is still processing it. So . . . no telling if it will succeed or bomb.
    YouTube - Lambright - 029
    Cloxxki requested that we have a dual comparison of charged PMH rundown and uncharged PMH rundown. I figured it would be possible to do the entire sequence in a straight uncut video. The video is all there, but there were some very annoying background audio problems (Fan blowing on the mic, various talking in the back ground, planes overhead, and engineer doing something with a ceramic container and stirring instrument etc.)
    So since the sequence can be a bit boring it was decided to liven it up a bit with some music. I particularly like the lyrics at the end
    There has not been any interest in the ice melting - so I will forgo processing those videos and snapshots.
  • Jetijs
    Duncan
    Thanks for the info - very interesting and valuable indeed
    A quick update, I got my ford model T magnets today, two sets of 16 V shaped magnet cores. Some of them are magnetic, some are not and will need to be magnetized. They are dirty with oil, grease and other stuff from the engine, I will have to clean them before further use. At the moment I have other stuff going on, I hope that in about 2 weeks I will be free to continue to work on Leedskalnin stuff.
    Thank you all!
    Jetijs
  • el-tigre
    Prism Experiment
    Hi David, Interesting field of study you have launched.
    I have a thought for you. If the effect you are observing is based on some sort of frequency manipulation, you may want to try suspending a cheap prism
    Glass Equilateral Prisms: Triangular & Right Angle from $2.95.
    over your apparatus and projecting a bright spotlight through it. If you capture the spectrum on a white sheet of paper fixed in the background, it may help you to film any effects and also identify what frequency they may be occurring at. This may help you or others fine tune the size, shape, strength etc. of their test rigs to demonstrate and then optimize the effects.
    Good luck.
  • Duncan
    Directory:Flynn Parallel Path principle device - PESWikiWesley Gary's Magnetic Motor
  • Harvey
    The good news is that I did get the HD camera and was able to do a High Definition two stage tripod rundown on a single video showing the PMH Lock and rundown, then breaking the lock and doing another rundown.
    The bad news is that the file is over 2GB, nearly 14 minutes long and my system cannot handle the editor. Also, there is some very annoying background audio that needs to be dealt with.
    So it may be a week before I can get this one processed My son has a system that can handle the editing - it is just a matter of getting our schedules aligned.
    Till then - it there are any low res tests you would like done - let me know.
    David, I haven't forgotten about your suggestion regarding some quartz rock - I'll have to go rock hunting and find some
  • Harvey
    Thanks Harvey, great stuff
    David, your ring device puts out 0.2V at the inside coil terminals. Is that coil made out of enameled wire or a bare copper wire? So far it looks like just ordinary galvanic action between the copper, iron oxide and aluminum. A galvanic battery. Will test more to see the current and overall power output
    Jetijs
    Let's not overlook the possibility too that it could be a thermoelectric effect. Where dissimilar metals are in contact and that junction has thermal energy applied, an electric current will flow there.
    Also, the ring itself can be a loop antenna and thus prone to Electro Magnetic fluctuations which in turn can cause an induced current of small magnitudes. And this could be quite interesting where a PMH lock is in place.
  • Harvey
    Here are a couple others for your entertainment :
    YouTube - Lambright - 027
    YouTube - Lambright - 028
    Note that these are unlisted videos and you will need these links to watch them
  • Jetijs
    Jetijs
  • Harvey
    . . . Continued:
    <Zoom <Zoom <Zoom
    <Zoom <Zoom
    So it would seem that there is a specific dissolved gas that reacts well to the PMH lock - Freeze Zone arrangement and produces the multitude of radial bubble lines. Removing the gases by boiling also gives the water an unstructured orientation of formation even in the presence of a PMH Lock.
    The best results occurred when the center bump was removed from the melt and new water was added to compensate for that loss.
    The side view of the ice indicates that the freeze zone propagates from the bottom and top surfaces as well as from the outside edge thus pushing the gases toward the center of the melt from all directions. This means that the ratio of thickness to diameter can change those bubble arcs. Where the ratio is very close, the arcs will be relatively smooth and curved. Where the ratio is large (as in my case) the arcs will be shallow giving way to long horizontal striations.
    It is unclear why the gases tend to follow particular lines even when the line is broken up. I did not observe any lateral shifts where a particular line was offset by less than the angular displacement of a full bubble diameter. It is possible that such occurred in the hub under the bump, but this was not observed do to the plethora of bubbles in this region and the visual obstruction they impose. It is also unclear as to what sets the bubble diameter. In the case of no PMH and the Missing Element (no magnetic flux lock) the bubble track diameters were markedly reduced - some even being microscopic.
    It should be noted that during the the test with no PMH, the vertical position of the Pyrex was lower by the thickness of the PMH (~1"). Also it should be noted that the rack on which the PMH rested in these tests, and the Pyrex rested in the aforementioned test is made of ferromagnetic wire encased in some vinyl or rubber insulator. What part, if any that these things play in this process is unknown. It should also be noted that the refrigerator itself does in fact constitute a Faraday Cage - thus we can rule out any external EM interference in those frequencies and magnitudes that are unable to penetrate the casing as being an influence in these tests.
    There have been no requests for the extended meltdown sequence and shots - so I may simply forgo even processing these as it is a rather boring sequence of melting down the prior freeze already documented.
    I'm going to put my rig outside for a while and see if soaking up some rays has any impact on the 'glow' or 'glimmer' I am hoping to see
  • Harvey
    PMH Locked - Boiled Water
    Video:
    YouTube - Lambright - 026
    <Zoom <Zoom <Zoom
    <Zoom <Zoom <Zoom
    <Zoom <Zoom <Zoom
    <Zoom <Zoom <Zoom
    <Zoom <Zoom <Zoom
    Continued . . .
  • david lambright
    jet!
    Originally posted by david lambright View Post
    @jet...not to worry, i know its not an easy thing to see!...but you will!...also try testing the inner coil to the tube with a volt meter....on that same device, i was getting a small but constant voltage/current....anyway, if you play with the device, you will see this radiation/glimmer/hazyness/lensing effect i describe!...david
    jet, try this...try viewing in a dimly lit room!....let me know if that helps!!....david
  • gravityblock
    How to make instant hot ice.
    Make an ice cube sink with heavy water.
    Use a vacuum to freeze water in less than 90 seconds.
    Dry ice.
    Let's not limit ourselves to just freezing the water and melting the ice.
    GB
  • Harvey
    PMH In Place - No Magnetic Flux Lock
    Setup Video:
    YouTube - Lambright - 025
    <Zoom <Zoom <Zoom
    Notice the Missing Element ^
    <Zoom <Zoom <Zoom
    <Zoom <Zoom <Zoom
    <Zoom <Zoom <Zoom
    <Zoom <Zoom <Zoom
    One More Picture Left: Picture Sixteen
  • Harvey
    Sorry Jetijs, (or was it someone else that asked me to do this - I can't find the post now )
    I said I was going to check the convective outlook before doing the test and I didn't - so the test was a bust - I'll have to do another when the Forecast is "Clear Skies"
    I honestly had no idea that this cloud bank was moving in - it had been hot and clear for days
    At any rate - here is a quick video - check the video information for the forecast data: YouTube - Lambright - 024
    Do you think the fan changes anything? I was thinking a motor might interfere with the Magnetic fields so . . . I used the fan.
    I still have more stuff to process when I get the time things have been busy this week already.
    Have I over looked any requested tests?
    I think I am losing my memory - I have a photographic memory note of Jetijs asking me to put a small motor on the rig and me responding that it was doable - I searched the whole forum looking for a comment by Jetijs that even remotely resembled what I have in my memory and I could find nothing by him or myself that resembles the image I have in my head of the conversation.
    Right memory image, wrong forum
    YouTube - Broadcast Yourself.
  • david lambright
    hi everyone...
