  • Originally posted by xee2 View Post
    @ altrez
    My 390 turn coil inductance = 0.854 mH
    Think that's whats wrong? Why is 1200 turns less mH then yours? I am using the 2n2222 I have switched it out with a few different ones as well. The LED will not light at all. It will is I go from Emitter to Collector but that's it.
    I have no idea why this is not working. Any ideas?
    Thanks!
    -Altrez
    • @ altrez
      Reducing the resistor value may help. I have gone down to 200 ohms on some circuits. Make sure LED is as shown in schematic.
        @ altrez
        I took the resistor down to 100 omh and the transistor gets too hot. I added a pot so I could sweep yet the led never lights up.
        If I pull the transistor the led comes on. I have tried lots of different ones as well.
        I am so lost. I cant see how this is not working can the coil make it not work?
          @ altrez
          Another thing that's odd is if I move the LED to the base and collector it lights up really bright then goes dim and I can turn it off with the pot or back on. If I put it back to the emitter and base it will not light?
          I really want to thank you for all the help!
          -Altrez
          • Originally posted by altrez View Post
            Your LED is backwards. It should go the other way.
            • @ altrez
              Try 6 turns for L2 about 10% of the length of L1 from the powered end.
                Ok I got the LED working an in the correct position. I plug in th power and I get the one wire AV plug thats attached to the end to light up! However the Tran gets so hot it burns even with a 100k omh resistor at 5v. The LED does run while there is power but the tran lasts only a few moments?
                Thank you
                  Your L2 coil needs more turns.
                  • Free PDF Guide For jonnydavros Simple SEC Build
                    I put together a guide for jonnydavros Simple SEC build for a friend and I am sharing it here by permission. It is very detailed.
                    If you are new to this topic, download the PDF guide, and watch the video! It's a great lead in to SEC Exciter projects and very inexpensive. Good fun.
                    PDF Guide
                    Video
                    Thanks jonny!
                    * changed the link to Scribd - you'll need to login for a download, otherwise you can read it online
                    • Originally posted by kcarring View Post
                      PDF Guide
                      Video
                      Thanks jonny!
                      You need to allow people to download it from that link. Add me altrez
                        Humm I have added 6 more to make it 12 I will add another 6 and see what happens.
                        Thank you!
                          It seems that this circuit is really picky about the coils. I have rewound a coil and it will light an LED with one wire it will not however light a tube. It gets really hot with anything less then a 100komh resistor and 18 windings on the secondary.
                          I am close, The circuit LED is a great addition as it allows you to know that the circuit is at least working and then allows you to focus on the coil. I think something is still wrong. It will not light a neon at all. And the LED on the AV plug is dim.
                          What could be the cause of the high current pull from the power source. Even with 1 AA its super hot.
                          Coil Primary is .672mH
                          Coil Secondary is .014mH
                          Resistor is 100komh
                          Transistor is 2n2222
                          Power is 1.2v -> 9v
                          Ideas?
                          Thank you!!!!!
                          -Altrez
                            Yes. Something is wrong. Post a photo of your coil.
                            Have you tried reversing the L2 leads? If you are still using a 2N2222 you should eventually try to get a bigger transistor and use a heat sink. I suggest using a cell phone charger to do your tuning, that will limit the current going into the transistor.
                            EDIT: This is video of a 900 turn coil. You should be about the same.
                            YouTube - Slayer exciter circuit - 1 AA battery
                              Ok here you go.
                                WOW your coil is like 1000 times bigger then my little coil. Thats awesome But my coil is around 1200 wraps? and its small I posted a pic.
                                Thank you xee2!
                                -Altrez
