Originally posted by seth
Power = watts = amps X volts. If you have a very high voltage it does not take much amperage to get watts of power.
Mr.Whip
I started of this morning on a mission to increase plasma output using Slayers exciter without blowing transistors using my existing pop bottle coil though any one starting off should think about replicating Bob's coil as he has great plasma at low volts and current draw, anyway the small signal transistors can't take much stick even though the mpsa06 seems to give great results,it is easy to blow them so i decided on the 3055,sat in a cap of water for cooling and a Lidmotor style L2 and using a wall adapter which outputs 35v I got great plasma at 180mA.So that sorted i decided to try this setup on Dr Stifflers one diode electrolysis and decided on trying to get the gas to burn so i used a syringe that was left over from a printer ink cartridge refill pack and not used to feed my cat when ill like i say in the vid jeeez.I half filled the syringe and dropped two 4148 diodes inside,they fit through the exit hole and attached the steel needle.
Now to figure out why it happened and how to keep it going. I have tried and tried to get a flame out of the diode electrolysis setup and had no luck. You may be just burning up plastic with the help of the HHO but it is FIRE and at this point I'll take it. I'll try to replicate this but without knowing what is going on ---it is a long shot.
