  • Can anyone translate Dyatron schematic please?
      I use translator sorry for quality
      блок управления твс манипуляция 50 гц =manipulation of the control unit assemblies 50 Hz
      трансформатор изолации 15ква = Isolation transformer 15kva
      Leo
      Every problem has always at least two solutions: Find.
      The strength of the strong and able to traverse the ordeal with calm eyes.
      • Originally posted by Itsu View Post
        By the way, did you see the warnings on using Li-Ion batteries in this thread post #18)
        yes, and I dont really care to much as I'm within the bounds of the upper and lower voltage of the 18650 Li-Ion cell.
        But If anyone have concerns then please use NiMh or NiCd instead.
        And a fluorostarter is a GDT and not a timedelay.
        Yes, It has a bimetal pole and If heated it will short until cool again but it never gets hot in this case.
        So it just a sparkgap with a low strike voltage.
        Edit: I think it would work the best with lead-acid battery but they are hard to come by at 1.5 - 3v.
        It also works much better when running on one battery and charging another but the circuit for automatic switching of the batterys would be complicated.
        • Originally posted by leo48 View Post
          Leo
          Thanks Leo
          • I dont want to get off subject but has anyone tried putting their coils in battery acid.
            Will the battery acid conduct ions.
            • This is my super electronpump using an ignitioncoil and relayticker with a timing cap.
              I know the relay will probably break after a couple of hours.
              It is very easy to build using simple parts around a 6v SPDT relay, an ignitioncoil and a 400VA stepdown transformer.
              The output is 400watts and will charge a Lead-Acid battery and will selfrun with a currentdraw of only 20mA.
              • I'm not sure how concentrated battery acid (sulphuric acid) is but if it is strong enough it will eat the copper and many other metals.
                • Originally posted by janost View Post
                  [ATTACH]11848[/ATTACH]
                  Hi janost, Thanks that looks like an even better one. Can you give any info on the SCR type or model? A couple more questions - do you think this would run on 12 volts? I have a lot of 12 volt relays and a 12 volt ignition coil but no 6 volt relays. Do you think one could replace the relay with a fast MosFET? If this works out with a relay it sure would be great to use solid state switching if it is possible as that would likely make it a very useful circuit versus one that eats relays every day. Actually based on the Imhotep work I tried some relays can take a lot of abuse for many hours. I never did destroy any even with that constant fast switching that was involved in that circuit. But solid state would be great to use.
                  • Originally posted by ewizard View Post
                    My SCR is a BTY-79 screwtype that can handle 10amps.
                    It doesnt need to be that heavy so anything that can handle 350v 2A will work.
                    The relay I use is a 6v and it will work with 12v relays but remember that the ignitioncoil generates 20000v on a 12v supply and the diodes have to be able to take the high voltage.
                    Not sure the 1N4007 can handle 20Kv and you may need several diodes in series.
                    I plan to use solid state switching but it was easy to test it with a relay.
                    A mosfet controlled by an Arduino so that the currentdraw can be controlled in a feedbackloop.
                    • Originally posted by David Fine View Post
                      Schematic posted for Ganzha.
                      Hi David, Ganzha
                      Can you tell me what is the source of this pdf? Is there a thread according to that subject? Is it somehow checked?
                      rgds blackrobi
                        Thanks janost! That helps me a lot. One other question since I'm not too familiar with how ratings work on GDT's. I'm looking at some now from a suppler that have a 500 volt breakover voltage and a 10 amp peak current. Would that be a good choice or do I need lower/higher ratings?
                          To get your SG working in this setup you need somewhere 0.7-1.0a input;
                          and output you have 70v 5a, means you have around 60% OU;
                          pls check your meters, it's probably 5ma.
                          Would you show pictures of your setup.
                          Thank you.
                          • Hi Janost
                            thank's for sharing your "Super Electron Pump " shematic.
                            I already began the basic circuit to pulse the primary of the stepup transformer.
                            And by doing this i stumbled upon an experiment that can perhaps interest some of you.
                            hope this helps
                            good luck at all
                            Laurent
                            High voltage properties testing 1 - YouTube
                            • Dyatron= Dynatron?
                              Sorry to asking
                              is Dyatron - Dynatron from Odessa?
                              • Originally posted by blackrobi View Post
                                Hi David, Ganzha
                                rgds blackrobi
                                it is from Ukraniane forum lab 001
                                nobody check this until now
                                I have sent it for informaton purposes
