Gravity Wheel Process Release Date March 8 6 PM Eastern Time
I began in 1996 cutting a figure 8 in plywood. My belief at the time was that a metal ball going through the figure 8 shape while spinning on an offset axis would continue to spin. I worked along with it for a few days til I reached the conclusion I was not up to the task at that time. I set it aside with full intentions of coming back to it.
I've invented several engine systems between 1996 and 2009, systems that do not combust fuel and exhaust no pollution not even a drop of anything; I did not come here to discuss them. Last year I had several unexpected insights into how a Gravity Wheel would work.
I had never studied Johann Bessler's work and still have not, but I have looked at John Collins pictures enough to figure out what Bessler did. I won't spend everybody's valuable time going into Bessler's ideas, how they possibly worked, nor why they failed to join Thomas Newcomen's steam engine enhancement that succeeded in the very same year as Bessler's first engine => 1712, the beginning of the Industrial Age.
Being of restricted funds as I have been on disability since 1989, as well as some other drawbacks, and after writing back and forth with Dr. Lindemann and John Collins and Scott Ellis and a few others versed in this issue, as well as much prayer to heaven, I will on March 8 6 PM Eastern Time open a new thread in this forum and show exactly what tricks are needed to make a Gravity Wheel work.
My solution is different from Johann Bessler's but although not built upon his work there is a bit of overlap, neither of which is Perpetual Motion, neither of which ever was about Perpetual Motion. At ground level where we humans live Gravity is a straight line force. A "Gravity Wheel" is an Energy Conversion device. It takes linear energy and converts it into circular energy that can drive a simple electrical generator to power homes and apartments all over the world.
Before 300 years <> before 2012.
The Mechanical Engine
Good suggestion Peter. I had thought about doing that myself, but being new to the board I didn't want to upset everybody's apple cart by plunging in like the Know-It-All-from-Planet-X, perhaps causing fellow posters to think me a rabble rouser stirring up trouble. I was trying to exercise a level of sensitivity... to prevent ruffling feathers and making enemies.
Can't say right yet when I'll do that... but I won't be a long time.
CloudSeeder, this year, 2009, smoking the starting blocks
New Thread
CloudSeeder,
Thank you for your posts, so far. Since your ideas are not based on Bessler's or my article about The Mechanical Engine, perhaps you might enjoy sharing more of your ideas in a new thread that you start. This could be dedicated to the ideas of how such a machine should work according to your designs and theoretical models.
Peter
All Points on a Wheel are starting points, an engine with no ending...
Every point on a wheel is a starting point. It isn't necessary to have one single force turn the wheel one complete revolution; it only has to move it to the next starting point.
Any number of successive/repetitive bumps will keep the wheel moving. They do not have to be great grandiose bumps, but correctly timed bumps.
Any time an Action can accomplish two bumps, then you have passed the next point on the wheel, perhaps even a lot of points.
It works for a Gravity Wheel and works for other circular engines as well AS LONG AS the weight of the wheel is kept balanced...
Any time the balls go airborne there's no negative forces on the wheel, so if the ball has several positives and in the middle it is rather airborne, you have a nearly frictionless system. As long as the total positives outnumbers the total of the negatives, you have "effective" frictionless energy, an Effective Frictionless Engine.
It isn't rocket science; it's a pinball machine. I know it's scary opening the door but, somebody has to do it. The previous gameplan is out of breath, wasted and waiting for the ambulance, time for a fresh man.
Ice Storms and Lost Power Maine and now Kentucky
Maine a few weeks ago, without power from snow & ice. Now Kentucky, where they have so much ice the telephone poles are snapping like old brush. I've noticed the weather shifting east then west in the last some months. Looks like another summer of floods on the Mississippi.
Having a device IN THE HOME generating electricity would be a nice thing to have about now. In a flood zone a couple Gravity Wheel-powered sump pumps could keep pumping water back on the other side of the sand bags... and run a small Home-Size water purification system.
Peter Lindemann's Projections What it will do for Mankind is correct
Imagine every home and apartment having a 3-4 foot diameter spinning device off in a closet near the electrical box, its outer rim turning a generator. Sure isn't rocket science because the larger rim ratio (low rpm) to the generator axle is many times enough to turn the generator a higher rpm and crank out plenty enough electric current to run the entire household 24 hours a day.
Wrap your head around this => the finished device
is a spinning pinball machine.
CloudSeeder, Bringing the Spring rain
MrBreau, I've read every post you have made in here and I'm very impressed with your dogged tenacity. You've added many new parts so you must be very gifted at visualization and hands-on.
But every time you add another 40 parts you increase the inertia of the entire mechanism, requiring a direct increase in the energy to move the whole thing. If the Wright Brothers had added too many parts they'd never gotten off the ground.
I fear you are fighting a losing battle. We all know that one evidence of efficiency is fewer parts, not more. If the science is right it will run.
CloudSeeder
Laying a Trail of False Breadcrumbs
Bessler wasn't just covering his tracks => he was laying a trail of false breadcrumbs to take people further away til such time in the future he would decide to tell people his secret (after he got paid). To make a circular engine using gravity there has to be an inherent out-of-balance condition that never has a chance of achieving a balanced condition.
It has to keep trying, to keep "falling forward" hoping this last jump will be its last.
But another flaw -and the real reason that design can never work- has to do with it being a passive design. Passive isn't enough to lift all those balls on the left side merely by swinging.
However, my congratulations for #1 a well-ordered document and #2 a really good drawing.
New Poster Alert, Time to Rain
I've read this paper => http://www.free-energy.ws/pdf/mechanical_engine.pdf and it contains some flawed logic. For starters I would NEVER assume everything out of the mouth of a man who flips letters to hide his real name to be Absolute Truth. I WOULD expect a lie to be used somewhere.
Bessler's Big Lie was saying the balls had to be an Even Number.
He said that to throw all you guys off.
And that was exactly what he did, to the tune of 300 years so far.
Everybody knows that the ONE BIG RULE of inventors is YOU ALWAYS HOLD SOMETHIN' BACK.
CloudSeederLast edited by CloudSeeder; 02-28-2009, 10:49 PM.
Thanks Again!
Vortex,Originally posted by Vortex View PostI just noticed it was doing that.
When I posted I was LOGGED IN .. and I never SAW the pop-up box when I was posting ..
I wasn't thinking ..
Also
Sorry it took so long for me to get back here to fix it.
The user/password I have posted is available freely at the web site
on a web page .. I've not posted something that is secret .. I guess
they wanted to keep the spiders/search engines out.
I modified my other post. Thanks for taking care of this.
Peter
Also
they wanted to keep the spiders/search engines out.Last edited by Vortex; 03-01-2009, 03:29 PM.
Vortex: Thanks!!!!
Vortex,
Thanks for fixing the links in your previous post and getting rid of the log-in pop-up box that was plaguing this thread!
Your cooperation is greatly appreciated.
PeterLast edited by Peter Lindemann; 02-27-2009, 11:18 PM.
This all seems very, very interesting. Your work and dedication is much appreciated by all here. Are you saying you have a working continuous wheel now ?
Fliekraft Generator
living energy machine
Ref Links:
Google's GERMAN to English language translator linkwuerth-ag.com found on web.archive.org here
I was unable to access some of these pages until I removed
domains.googlesyndication.com from my hosts file allowing access .
It didn't matter much, Dec 2006 onward are without content.
The Jan 14, 2006 archive seems to be complete.
You have to LOGIN to gain access to the following (at least I had to)
In order to reach this page you need the following access data:
user: wuerth
passwd: wuerth
naturtechnik.de /wuerth
You have to MANUALLY add "/wuerth" to the link above.
Using the full link here ends up asking EVERYONE viewing this fourm page for a user/password. to naturtechnik.de web page.
Document downloads & Patents:
naturtechnik.de /wuerth/download/download.htm
