This is a good idea.
I will probably learn what impedance means and implies by doing this.
Please make one more thing clear in your idea.
This primary is a center tapped wire which takes in the voltage from the center tap and proceeds to move it out the toroid (important) in opposite directions.
To my mind, this is what makes it different from other bifilar arrangements.
This was recently brought home at ou by some of those special people who believe they know everything. We were told that I was wrong and it was a series bifilar. He was wrong, and I like that center tap part to be up front in the beginning.
A few weeks ago, I charted the inductances of 4 toroids with 1-9 turns on them.
After I open open office for the first time I can post a chart with that info.
I do not know (or have a clue) how to work that L= n^2 A /2 p r equation into anything so I will let you help with this chart.
@all,
I am almost finished with my new light bulb.= a self contained light bulb with a joule thief and switch (and rheostat
).This is bright, but not fully bright.
However, if I use a 2.4v battery pair it does get fully bright.
I think a lithium battery =1.6v might do the trick. I'll be back with that and a pic.
still no package of toroids...jeanna
edit
Here are 2 pix.
I set it up so you could compare the brightness / sharpness of the shadow cast of the battery but it is very easy to see the difference when looking at the alcohol bottle.
However, they are both bright and the single lithium AAA is experienced as very bright.
j
I might make another boxed light using a "D" cell battery for the increased amp draw. A good heat sink for the transistor will be needed also. Jeanna--let me know if you get another source going for the big toroid core. I can get the smaller 2" ones but they sing pretty loud and don't work as well.
