Gray Tube Replication
  • Aaron
    comments
    Ghst,
    What you have done is 100% identical in concept to what I have showed over and over. Congratulations but it appears nobody is able to recognize this fact and you never responded to me in this thread in my responses to you in the past about what you were trying to do.
    I gave the parameters required for the effect and you are sticking to it even if you have your cap charged through the LV rod. It doesn't matter.
    To get what you showed, you don't even need the tube and you don't need the grids, you only need 3 simple points spaced as you described, which is what I have also described multiple times. With the tube, it may or may not be stronger but is certainly not required to do it.
    If you want to see what your cap is really doing, you must scope the discharge time. That will tell you everything you need to know.
    You may think you need magnetizing "current" to charge those coils but keep in mind, there is more than one type of current that can charge a coil with a magnetic field. One is hot and one is cold. One is "electron" current and one is a pure magnetic current.
    If you look at a scope shot, you'll know what you have.
  • Aaron
    green color
    Originally posted by antena View Post
    Hallo
    I tryed my tube and I got red event. Aaron had green event, Ghst white and I got red. It is possible ? I used about 6,5kV, then my capacitors destoryed including diodes )) I have to buy some good new one...
    Have fun
    Antena
    If you download Ghst's vid and do a frame by frame in a good program, you'll see the blast has the green color.
  • Jbignes5
    Last statement.
    Ghst I applaude your effort but this is exactly what you told us "Please remember that I have "NOT" claimed to have reproduced Greys Power Conversion Tube. I am only conducting experiments to try to replicate, what Grey did and how he did it."
    Unfortunately you cannot try to replicate Grays proceedure without actually using the tube he used under the cicuit he used. That would be like trying to replicate making a nuclear bomb by only looking at pictures of said bomb. Don't get me wrong I think you have gone in the right direction But maybe took a left when you should have stayed with it. when you loose components because they don't make sense to you or the effect isn't apparent then you loose the capability to replicate the end result.
    You were the one who got mad I just won't try to help you get back on track if you say things like "Bigness5, Thats great! I guess I should stop where I'm at and wait till someone shows me what to do next." And then act like I'm the one mad. Like I said good luck in your Gray tube like device but it is not the gray tube at all and that is plainly true. Why post in the Gray tube replication post if you are not trying to replicate the tube? By the way what do you think an lcr cicuit like you have is for? This isn't a guess from me it is a resonant cicuit plain and simple. How does one resonate the circuit maybe you should do some research and find out how. I'll point you in the right direction frequency has a lot to do with it.
    I won't bother posting here again since you obviosly are not trying to replicate the tube, only on looks. Yes your tube looks simular but thats where the simularities stop.
    Why are you posting in this forum if you are not trying to get input from others then? Why not just you tube the videos and just do what you are doing? Why involve others.
    I have a post about the whole system Gray was using and explains about resonance and that system.
    There is a link to RE and OU theory and also about the rotoverter. In the begining of the pdf is a good bit about Gray and his ema motor and what the theory is behind all that. It might help you to understand what I have been trying to tell you. Then again maybe you won't but I throw it up there in any case.
  • Ghst
    Rave154, Here is a descriptive picture of "the Jar" I hope this helps.
  • Ghst
    Originally posted by Jbignes5 View Post
    hey you know what I'll stop then because you don't seem to take any advice without thinking that someone is telling you to not do what you are doing. Thats ok I'll go else where and help other people then. Good luck....
    Oh don't go away mad. I can take advise very well. But you have to know from proven experience before it is advise, Other wise it is just speculation. And I have done a lot of speculation myself, No way to prove ones own thoughts until they are tried and either fail or proven fact. When proven fact then one can advise. I stated earlier that I have used the carbon, as Grey did. I am still using carbon as the LV rod. I haven't, in my test. seen carbon to be a influencing factor in the discharge or have it to create the electron cascade that the tube is susposed to produce. I have noticed in my own tests the addition of the carbon on the LV electrode allows you the ablity to increase the discharge time and to decrease it.(to a extent) As for resonance, these are only tests and it will be difficult to setup a resonance circuit what with the single coil setup as my demonstration. Heck I can't let the system top off the cap because it isn't self aligning. These are single shot firings and the cap is being charged from 0 V in each of the vids. (I carefully discharge the remaining voltage after each firing, before attempting to reset the coils.) If you can resonate the circuit then by all means go for it. I just ain't there yet.
  • Jbignes5
    Don't stop...
  • Electrotek
    Venetian Blind Grids
    Originally posted by Ghst View Post
    Hey Tek, where you been? I thought I'd also mention that the brightness of the discharge doesn't change when launching the coils. All earlier attempts to pop a coil caused the discharge within the tube to diminish considerable. But now it's as if there is no real power loss energizing the coils. The discharge still looks the same as without the coils. I gotta get a scope!
    Hi Buddy. Sorry I haven't been posting lately, but I've been tied up with my mechanical project. And I have been watching the forum every day.
    Glad to see all the great progress you've been making! Looks like you're getting close. If your discharge isn't diminishing that means you should be able to transfer the energy to another cap. Sort of like Gray said he was doing, bouncing the energy from one cap to another.
    Here's a picture I've been thinking about for some time:
    Yfrog - croppedgray027bhu0.jpg - Uploaded by Inertiatek
    As short as each CSET is, the length must be related to the pulse duration. So, for more energy the grids would need to be thicker, or more of them, rather than longer. With this in mind, I took a Tube I made back in '02 and cut it down, thinking I'll use the shorter piece:
    Yfrog - phot094.jpg - Uploaded by Inertiatek
    The other thing I was thinking is that Gray's Tube looks like it's set up for a multi gap discharge on the end, since the grids are close together and there's dielectric at key places. After working with my Gradient Plate this is the first thing I thought of when I saw his picture.
    The grids in my Tube aren't so close together so I'll try putting chunks of Gradient Plates where he has the dielectric. With my Plate, I also found out that rather than have one electrode on each end, I can put both electrodes on the same end and the Puff Spark will be pulled along the surface of the Plate, as long as the capacitor is connected to another electrode on the far end, with this wire connected - through a resister - to one of the main arc electrodes at the starting end.
    So I'll put the spark gap just outside the end of the grids. The cap will connect to the outer grid and also to a chunk of carbon or a piece of nichrome wire going to the electrode farthest from the grids. Then, if the Puff Spark goes out along the end of the grids, the grids may act like a Venetian Blind plasma energy extractor.
    Like I said, I'm pretty much tied up right now, so it may be a few days before I can do a test. But that's what I'm working towards.
  • Ghst
    Hallo
    Have fun
    Antena
    Antena, glad you got a discharge! Building the devices by your self and actually having it to discharge or produce any event at all is very encouraging and satisfying isn't it? Once you experience this, its hard to stop. Have fun, above all be safe!
  • Ghst
  • Marcoz
    Please remember that I have "NOT" claimed to have reproduced Greys Power Conversion Tube. I am only conducting experiments to try to replicate, what Grey did and how he did it. That said, would you believe that its hard to replicate a capacitor discharge motor without charging a capacitor? I could have spent countless hours trying to repel two coils from each other without the capacitor, but, well after all it is a capacitor discharge motor. You should try, hooking the ignition coil straight to the capacitor. I,ll tell you what will happen. Most likely you will puncture the cap, and if you connect two coils to the cap and try to discharge, the HV will just course through the cap and through the coils, most likely burning the coils if they are not prepared well. Might I say, that it takes a large amount of power to launch a coil as I did. But, the coils themselves do not consume much, if any of the energy, that instantly surges through the coils, magnitizing them, causing the repulsion. Most of the discharge energy will go to the tube creating a bright flash of plasma. You have to agree, that it takes magnetizing the coils to produce the repelling force as I have demonstrated. Now, its well known that the collapsing field in the coils will produce a Back Spike, if you will, that is equal to the energy that created the original field. So now I have most or all the energy used to repel the coils going into the tube, plus a large spike from the collapsing field of the coils. I'm still a long way from Grey's system, but I think I'm gaining in knowledge on how his system worked.
    All is fine, i just posted what i believe is happening.
    As you might know any type of back flow is unwanted it the tube itself.
    This is because it will produce oscillation, which in turns leaks energy by capacitive means, to the grid, not good.
    Simply said, this transferres hot electricity to the grids, something you dont want bacuse a 5000 volt discharge can hurt a lot, if it not proves to be deadly.
    So the blast has to be in one direction only, but you are correct the inductive kickback is routed into another cap or battery for overall system performance and effeciency.
    I still do not understand your side electrode and the visible sparks.
    Ignition coils are not good at the production of high voltage DC.
    Possibly you have high voltage on all electrodes due to the capacitive effect i just mentioned above.
    I am also working on my tube and i am planning to do a high voltage noise test.
    This is to see if there will be any sparks from the center anode to the grid when fed serious power.
    If so it means the electrodes are too close to each other and i have to space them some more.
    Anyway here's a pic:
    Marcoz
  • antena
    red event
    Hallo
    Have fun
    Antena
  • Jbignes5
    maybe...
    Ghst You have done excellent for a start. But at some time you have to start going in the direction of Gray and find out why his tube worked the way it did. You have a tube cap and coils just like Gray did. The only thing you don't have is the frequency he used and the carbon<-device Gray used. The reason it probably didn't work is that Gray knew something about resonance and it triggering an event that gave much more out then in. The R is very important and as we all know when you add it in that it would change the way the tube operated both in frequency and spacing.
    Once you have a system that can resonate it should be very easy to command it to produce the event at will much like Gray did. How many times a second would you need a cap to charge then discharge to run a motor? even with a cap on every coil set you would still need to charge, discharge way to many times per second with your setup. Gray was definetly using another form of electricity to safely carge discharge a large cap in less time without blowing it up. You have a close simulation but it isn't quite there. Don't let my comments disuade you from experimenting but it wont get you anywhere unless you try to reproduce the effect, witch I think has more to do with resonance of the whole circuit and not just one piece of the circuit. having all the pieces and tunning your circuit to operate with resonance should get you to where you want to be and even with smaller coils I bet you could launch them thru your ceiling without even trying to do that.
  • Ghst
    Originally posted by Marcoz View Post
    Well Ghst, i don't know but it seems that you are just discharging the capacitor into the coils, making them jump.
    That has got nothing to do with the Gray tube.
    I'm sure it will do that without the tube too.
    M.
  • Marcoz
    M.
  • rave154
    Ghst, Thanks
    Ghst, thanks a lot for the clear & precise schema, lovely job,
    could you do a lil list of parts specs', you know, what stuff is actually "made" of/from , ie, steel, alu, etc etc..so we can all get more or less on the same page and try and get the replications as close as possible(which i think would help a lot when measurements start being taken )
    Thanks again
    David D
