Gray Tube Replication
  • bmentink
    Originally posted by Spokane1 View Post
    Dear Bernie,
    If you look at the Hendershot and Bedini devices you will see included capacitance as the center stage of the apparatus. In the Bedini device (and I assume the Hendershot device) The capacitor is suddenly charged during maximum magnetic field at right angles. If this is to be accomplished in a reproduction Hackenberger transformer then the converter has to be operating as a Fly-Back/Blocking converter like the Bedini motor, but in some kind of push pull configuration, which is rare for this kind of layout.
    Mark McKay
    Hi Mark,
    I think the Gray tube grids can be concidered both a capacitor AND an inductor. As an inductor secondary ( The primary is the central rod) it picks up the magnetic field from the rod. It also is a capacitor and picks up the radient energy from the central rod, so I would suggest that the grid is a parallel resonant circuit that should be brought into resonance by the impulse frequency of the spark OR as a delay line so that the spark pulse on time matches or is slightly less than the inductive delay of the grids.
    What is not clear, is what the connection is to the grids. The patent clearly shows two wires to the grids though everyone connects the grids together. I think grids one and three should be brought out and treated as a capacitor, not as a single connection, or the grids are internally connected as a 3 turn inductor and again two wires brought out .. what do you think?
    Bernie
  • Spokane1
    Gray Technology Focus (at the moment)
    Originally posted by bmentink View Post
    Hi Mark,
    What aspect of the Gray design are you chasing down Mark?
    Bernie
    Dear Bernie,
    Right now my focus is on the converter transformer and its mode of operation. My historical assessment and experimentation has brought me to this device as being the foundation of the non-classical conversion. The rest of the hardware is important, but I'm thinking this is where it starts. There is something very novel about this transformer that makes it special.
    I've spent years with other aspects of this technology attempting to get a handle on its physics. Fortunately small clues have been dribbling in over the years. Each time this happens I have to change my cherished theories (yet again) or concept of the history. We now have so much more than what we had in 2000, but still a long way to go.
    For example, I have been researching resonant converter topologies for the past few weeks, but I have also been wondering about what the added primary inductor or capacitor is for (six primary taps). Right now I have this third component as a third primary and its performance sucks. So, I'm thinking it has to be a capacitor to reduce the operating frequency of the transformer. Back in 1971 they didn't have fast diodes, so the frequency was probably limited by these components. Therefore they had to have had a slow operation of around 8 kHz. So, if the third leg of the primary probably is a capacitor then what is it doing being wrapped around the primary? A external commercial capacitor would have been a lot cheaper. Therefore this integral capacitor must have been important.
    A Resonant converter (according to one paper) doesn't require a snubber circuit. The "Blue Engine" has a substantial bilateral snubber. Also, its controller board design focuses on fast shutoff speeds with a healthy negative base bias supply. None of this would be needed for a continuous resonant topology. So, now I have to figure out where the output sine wave was coming from and why they wanted to eliminate the negative swing with a battery.
    And so it goes and it has been going for years now. Until I can reliably reproduce the proposed effects of "Cold Electricity" my ideas are no better than yours and I could be easily chasing yet another dead end.
    So, forge on with your inspirations. It is unimportant who among us cracks this nut as long as it happens in my life time. The potential benefit to mankind is almost limitless.
    Mark McKay
  • bmentink
    Dear Bernie,
    Sounds like a solid plan to me. Are you going to look for the alleged "Cold Electricity" or search for straight OU? (perhaps both)
    Hi Mark,
    Cold electricity is my focus, but I suspect OU will come with it ..
    Could you give us a hint as to what kind of components your "custom driver" is composed? Solid State or Vacuum Tubes? Perhaps a solid state pulsed trigger coil?
    Mark McKay
    It is a solid state design on paper at the moment (and simulated), when I have it working on the tube I will release a detailed schematic ..
    Bernie
  • Spokane1
    Solid Plan
    Hi Mark,
    I am aiming for a 100ns pulse time with 3ns pulse edges .. repeated at the fastest rate I can do .. as you say will be limited by the thyratron relaxation time. However, these tubes can switch > 100khz, I am hoping for just 5khz
    Yes, I am going to provide a heater supply, it will be a regulated 6.3v from one of the 12v batteries. Since these are hot cathode thryratrons the cathode is tied to one side of the heater, which is at +12v, the other side of the heater will go via a regulator to -12v.
    I have designed a custom grid driver for the thyratron that will give me the required switching times ..
    Yes all the capacitor energy will go through the thryatron and battery, I don't see a problem if the average energy is kept down, it is the short peak power we need.
    Still waiting on tubes at the moment, they are coming from russia (of course)
    By the way, my convertor will not be used to drive a motor initially. I will run the power into an air core transformer back to 240v for testing on vaious loads
    Bernie
    Dear Bernie,
    Mark McKay
  • bmentink
    Originally posted by Wicaksono View Post
    OK and good luck with it, BTW are your capacitors polypropylene type such as used by tesla coilers ?
    Wicaksono
    Yes polypropylene caps ..
  • bmentink
    Dear Bernie,
    That is going to be some blazing switching times. I was wondering about the other needed support components you plan to use to make things work. As you know in Gray's 1986 patent he showed no provisions for a heater connection. Some say he was running the Thyratron cold and using it as an arc tube. (If they knew that much about the circuit operation I would have liked to have talk to them at length just to determine how they come to know that) I really doubt that it was running cold, but who knows? Assuming you are considering using the heater I was wondering what you are going to use for the huge high current, low voltage, high isolation value transformer. The few surplus units I have picked up are big and heavy (say 3 lbs. or so). Perhaps you plan to use a dedicated battery with a dropping resistor or a Transistor regulator. There are several options and I was wondering which route you planed to go.
    Also, how are you going to drive the "Grid"? The 1986 patent shows a mechanical grounded grid approach, which will probably work but I don't see how you would get the switching time you are looking for using that method. Thus, I assumed you are probably going to use something more active? Perhaps some kind of vacuum tube driver circuit. These days you could probably get by with a HV IGBT driver - but I don't know. Again many options.
    Then there is the issue of re-ionization time. I understand that Thyratrons need a certain amount of relaxation time before they can fire again. This limits their frequency response. But then again I suppose you are looking for proof of principle at the moment and not an actual motor/engine drive that operates near 200 pps.
    Are you going to have all of the storage capacitor energy go through your CEST and Thyratron? I have wondered how that would work for a long duration and what kind of impact that would have on the backend battery.
    We know that the Gray team had problems with exploding batteries and that would be a possible reason as to why.
    Anyway, I would certainly enjoy continue reading about your advancements. I don't recall anyone else using a thyratron in driving a CSET - at least not within the last few years.
    Mark McKay
    Hi Mark,
    Bernie
  • Wicaksono
    good luck with the current probe
    Hi Wicaksono,
    Havn't had much luck measuring the current yet, I will borrow the new current prope from my work .. hopefully it will have a fast enough response.
    In the meantime I am building up my driver circuit for the Thyratron that should arrive soon ..
    I am hoping to switch in <5ns
    Bernie
    Wicaksono
  • Spokane1
    Linear Current Transducerss
    And this is another series of current sensor from VAC :
    Active Current Sensors for maximum accuracy*-*VACUUMSCHMELZE GmbH & Co. KG
    Wicaksono
    Dear Wicaksono,
    Thanks for the additional data sheet links on these devices
    Mark McKay
    P.S. I have received the copper foil to build my second generation Hackenberger Transformer with an integral capacitor as part of the primary.
  • Spokane1
    Thyratron Support Components
    Hi Wicaksono,
    Bernie
    Dear Bernie,
    Mark McKay
  • Wicaksono
    another linear current sensor
    Dear Wiccaksono,
    That is a new transducer that I was not aware of. At $54 new from Mouser it would fit into my monthly research budget.
    However its response time is 3 uS. That means that the capacitor discharges I look at are over and done with in about 1 uS. So this device probably would not have the time to generate an observable output before the event was over. For near steady state or signals below about 5 kHz. this would be the ticket. But I haven't run across that slow of a signal in the Gray technology, yet. My present replication converter is presently running at 79 kHz. in order to get it into the resonate region.
    Thanks for the information. I'm keeping a copy of the data sheet in my instrument folder. Who knows when I might need something like this.
    Mark McKay
    Wicaksono
  • bmentink
    Yes indeed Mr. McKay, this is my only method - the cheap carbon resistor as current to voltage converter. Frankly this is what made me stuck, since I was expecting to see the capacitor discharge current. Instead I only have random non-periodic current pulse ala "hay field display". I am hoping that Bernie could see something in his LV inductor current, my experiment so far has been a tough luck.
    Wicaksono
    Hi Wicaksono,
    Bernie
  • Wicaksono
    Dear Wiccaksono,
    Mark McKay
    This is another datasheet of linear current sensor for your collection, this time from LEM
    Wicaksono
  • Spokane1
    New Current Sensor
    Dear Mr. McKay, I think I have something to patch the blank area from DC to 3kHz of current probe bandwidth; it is called "linear current sensor". Here is a sample of series of current sensor made by Honeywell :
    Honeywell Sensing and Control Product Search
    These linear current sensor is used in industrial motor drive to control torque of motor, since motor current is linear function of torque. AFAIK their price is not as high as Lecroy probe.
    Wicaksono
    Dear Wiccaksono,
    Mark McKay
  • Wicaksono
    alternative of Lecroy current probe
    Dear Wicaksono,
    You are correct on the DC component issue. But a fast pulse is not really DC. If you look at its frequency spectrum it has everything in it from DC to Daylight. Signals with most of their energy in the AC region can be observed with this kind of device. These transducers also come with a "Droop" rating that describes its low frequency response. If the observed signal doesn't change in a few tenths of a millisecond then the output starts to droop at a certain prescribed rate. Apparently you can use this information to extract some additional data from low frequency signals. I figure that my current probe is useless below 3 kHz.
    The DC component is completely removed from observation. With an AC signal the areas above and below the neutral line are automatically balanced to maintain the relationship that the current in equals the current out over a certain time period. So, only so much information can be evaluated with a wide band current transformer. At least a pretty good evaluation of the time rate of change of the current can be made - if it is within range of the device being used.
    Yes, a new active Hall chip device would be wonderful for this kind of work. But, a LeCroy current probe of that caliber (50 MHz 400 Amp) starts at $1,400 on the eBay market.
    Wicaksono
  • Spokane1
    Important Questions
    Originally posted by Arker View Post
    Dear Spokane1
    - MY FIRST QUESTION :
    How you (you as historian) explain that since Hack, nobody has successful to turn on this power supply ?
    Because it is impossible. A true electronician has many strategies to repair any installation in the 80s.
    We are not among the amateurish ! It is an absolute certainty that a true professional of the eighties's would have restored this montage. (A fortiori in the subsequent years.)
    - MY SECOND QUESTION :
    The group EMA-7 is over-unity. Well. It includes 2 separate entities : a "power supply EMA-7" and a "motor EMA-7". Well. solely one of the two is O-U :
    - either the "power supply EMA-7"
    - either the "motor EMA-7"
    Why do you think (as an expert) that O-U is in this "power supply EMA-7" of 1979 ?
    Respectfully,
    Arker
    Dear Arker,
    Please feel free to ask the same question several times so that we get it right. This is an important area of research.
    QUESTION #1 Response
    The "Blue Engine Power Supply" did not become available for any observation until 2012. It has been held in storage since 1980 in Dodge City, KS. Since 2012 it has been the property of Al Francoeur who has chosen not to disclose its internal construction features pending his hope to patent its operation. As far a I know he has not been able to get the power supply to function. Even though he has three motors, these units were converted to operate on classical electricity in 1980 and no longer have the ability to respond to "Cold Electricity" if it were made available. So, Al has to fix the power supply as well as one of the motors. Last I heard he was unemployed and unable to finance the needed repairs.
    Al claims (and I agree) that this power supply was intentionally disabled some time in its history in at least three or four locations throughout the circuit. I don't know what these changes were. However I do know that the battery connection terminals were introduced in 1980 by Nelson Schlaft "Rocky". These terminals come form the aircraft industry and were unknown to Gray and his team prior to 1980.
    So, when the "Blue Engine Power supply" was received it was disabled and probably modified to some degree. So far these changes have not been corrected. However, what is left of the Power supply can still give us a whole lot more information than what we had before.
    It is not easy to restore a circuit of this nature if one does not know how it is suppose to operate. The Transcript discloses that it is resonant converter (not a forward or fly-back converter), this is important. A modern technician would restore it according to classical electronic principles. This is what "Rocky" did in 1980 and almost completely destroyed the non-classical features in the process.
    QUESTION #2
    The OU is in both the converter and the motor. The converter, by itself, does not produce any OU (or not much). The motor converts this non-classical energy into real world torque, but it will not function with straight classical electricity. So we have to have a working converter and a working motor to actually get measurable OU and apply for the 1 watt $50,000 reward.
    Until then it is a pretty safe bet that we first must generate and attempt to measure some amount of the non-classical energy. Then we can go on and recreate the engine. It is my premise that we can detect the non-classical energy output with the popping coil apparatus. Other methods to do this would be very much appreciated.
    My present approach is to focus on the operation of the converter. From this forum you can see that others are working on other parts of the system, like the CEST or the motor itself.
    Mark McKay
