Imhotep's Radiant Oscillator Video
  • Latest simplified wireless radiant energy transmission circuit
    Here's my non technical explanation of what i guess is going on as i am no engineer or anything. The 450volt cap charges with radiant energy from the pc fan or/and the sphere. This discharges to the negative of the other battery bank via the magnet wire insulation and the insulation of the conversion tube (cylinder within a cylinder). The insulation is the conductor.
    This causes a radiant event to light the CFLS wirelessly.
    I recommend using magnet wire where indicated as i tried other wires and couldnt get it to work. But who knows...what you may discover or rediscover.
    P.S i tried moving the conversion tube around the ignition coil and couldnt get it to work. Perhaps it wasnt radiant enough.
    • Kickstart and Proximity
      In one of my video's taken early last week I show this effect of the 'kickstart' but without touching. When I moved my finger into specific postions below the 2N2222A Base pin (see attached photo) the systems starts. Moving my whole hand around the chip, even upside, does the same but pointed finger only does not start when upside or around chip enclosure even close like 3 mm. It only has effect 45 degrees conical shape down from the pin - as far as 8 cm. When touching it does activate anyway.
      In that video I called it 'Proximity sensor' For me it looked more likely to be magnetic induced and electrostatic - because of the area in which the finger proximity activates the 2222A
      @Aaron - self switching; That trial I did was with similat BD743C transistor. For no other reason than it came from my free boo-boo box and look handy for the job. Since it has been added to my 'artwork' collection of burned parts. That was actually long before I went out and stocked up with bunch of new stuff. I was working hard to get ex-Bedini bi-/tri-/quad coils singing.
      @Aaron - Charged environment; YES! I was not aware of this findings by other like you said. To date I could only read what I found on Internet, plan on buying a few books soon. That was the reason I shut down on Friday!
      I remembered reading about Sweet Floyd's experience and the severe warnings from Tom Bearden on that - though it is not the same kind of circuit/operation - the field around my table kept on expanding!
      Even after I terminated the DRT extreme spiking circuit, the scope and environment took some 20 to 40 minutes to calm down. Me myself had also been negatively affected. Severe headache, extreme tired, felt like a Zombi. For the first time in probably more than a year I went to sleep at 6pm. Wattanah was in shock te see me home so early - and going to bed that time had her seriously concerned.
      @Ren - I am interested in your circuit for a later expansion on this DRT circuit. Please?
      slayer007 - KSP 2N2222A -303 I would suggest to go back to my original circuit and build that one first. Then start cutting out and moving parts. On that circuit you will find everything working very stable, effective and smoothly. Next important thing: It must be 2N2222A transistor, the one with half round black enclosure. For some reasons to date I found the three 2N2222 chips I had which are enclosed in round aluminum cylinder does not work well.
      Of this 2222A the best brand name I found so far is KSP. It is marked "KSP 2222A -303. The other worked too, but this one seems easier to switch and also this one that gave me the crazy spikes.
      Now back to YouTube for me
      • The super simple one
        If I keep shrinking this down pretty soon you will need a magnifing glass to see it. I switched to Tip3055s and soldered it all together.
        YouTube - Super Simple CFL Drive---solid state
        Lidmotor
        • Change transistors
          Lidmotor
          I did that yesterday: Replaced all 2N3055 - (2222 > 2Nxxxx > 2x 2Nxxxxx) with various similar transistors.
          Used: 2N5631, TiP3055, MJE3055, BD743A, BD243, Tip33C
          I swoped the polarity on coil and used MJE2955T.
          ALL worked, but nothing work same when swop 2N2222A - Mostly does not work, with MJE2955T worked but wave form change to standard sine wave and no spikes/HV except on HV from coil.
          Good idea about magnify glass, next week I will go to Bangkok to stock up - will then also buy some surface mount microchips (3mm things) and try them out.
          Now I started uploading to Google Video as xxxx.AVI. Going well so far, but very slow. Will take many hours. Will see if I can edit video's to MPEG4 format and have them smaller files.
          • Viva Lidmotor
            Lidmotor
            LIDMOTOR !!!!!
            YOU HAVE DONE IT!!!!! It has been a point of frustration to me that I can not get at least a capacitor charging up!
            Now, I will make one set tomorrrow to run this opotion. Still working through different options on transistors. Got plenty variety, but have to salvage from my Boo-Boo.
            Please , monitor your supply battery. It is possible the the pulsing of the circuit might also increase the outflow from the battery to the capacitor.
            • editing videos
              Aromaz,
              With the vids on youtube, they each have to be 10 minutes or less and 100mb or smaller. This is if you want to upload them directly to youtube.
              When you see vids on youtube that are longer and bigger than this, that is because they are usually uploaded to google video, which youtube.com now shows.
              This file:
              Is free and converts anything to anything just about. It does way more than just about every program that cost money.
              I make sure the vid is one single file on my desktop or wherever. Not from a disk but a regular file.
              I take my vids and use this program and then convert them to WMV format. Then I use Windows Movie Maker that comes with Windows and then I import that WMV. Then I use that program to clip it down, add titles, etc...
              When saving from Movie Maker, you can select the size of the file in the end...of course smaller less quality. But you can always bust longer clips into 2 sections. Just make sure that each vid you save is a total of 10 minutes or shorter.
              Anyway, this method is virtually guaranteed to work.
              If you just want the vid without any titles, etc..., then you can use that free Super Video program to convert just about anything you have from a single file into mutliple types of divx formats, avi, wmv, etc... and a bunch more I've never seen. Anyway, they do compress quite a few pretty small. If you have files that big and have slow internet from Thailand, it could simply be timing out.
              • Books by Gerry Vassilatos
                Hi all,
                If you go here, I think Borderland Science is reissuing these books?
                Gerry Vassilatos
                tishatang
                • man this is getting weirder by the minute...i am getting purple plasma glow from the insulation from my ground connection now....have no idea where to connect it to.....or how....will have to think about this one
                  • Small vid coming, will make a more detailed one soon. MIL (mother in law) has the camera at the moment and only had 16 megabyte card, so not very long. Full video will explain a few things that I found, it will be easier that way rather than typing it all I think. Here is the schematic I am using. Many thanks to Erf for the original PWM circuit, which can be used for a multitude of things. Did have mosfet in there, light is brighter still, but harder to control amperage. Amp draw can be .5amps up to 5 amps. Sweet spot between 1 and 2 amps depending on frequency. 2 23 watt globes in series. Lights up whole room.
                    Toroidal specs as listed, any questions pm me or fire away in the thread.
                    YouTube - Simple PWM lighting circuit
                    • Originally posted by Aromaz View Post
                      The only time i see the waveform we need is with the 2n2222a
                      • At L A S T
                        Well at last it seems I have hammered a hole through the wall, my scull and YouTube. Now I can continue in my toy room and editing some of the older Video Lab Notes.
                        I first uploaded a short presentation of myself and view of my lab - for those who might wonder and have curiosity in their blood.
                        YouTube - Aromaz Short Personal Introduction.MP4
                        Next - as I want to backtrack and review some of the experiences and findings - a simplified version of our honored Imhotep Radiant Oscillator:
                        Part 1 (of 2): YouTube - Aromaz 001 - Simplified Imhotep Radiant Occillator Part 1 of 2.MP4
                        Part 2 (of 2): YouTube - Aromaz 002 - Simplified Imhotep Radiant Occillator Part 2 of 2.MP4
                        Before Lidmotor, Bodkins and Aaron shoot me, here are some original lab notes: (Remember most of these videos are now few days old, so you have found some of this before I posted the video's today.)
                        Dynamic Resonance Theory: (DRT) Original lab video notes
                        Original discovery Part 1: YouTube - Aromaz 003 - Original discovery Dynamic Resonance Theory.MP4
                        Original discovery Part 2: YouTube - Aromaz 004 - Original discovery Dynamic Resonance Theory.MP4
                        Original discovery Part 3: YouTube - Aromaz 005 - Original discovery Dynamic Resonance Theory.MP4
                        Original discovery Part 4: YouTube - Aromaz 006 - Original discovery Dynamic Resonance Theory.MP4
                        Two more will come in next post.
                        • Continue of uploaded video's
                          - This was where the dragon started waking up.
                          Original discovery Part 5:YouTube - Aromaz 006 - Original discovery Dynamic Resonance Theory.MP4
                          And this was where all went completely off scale, I got shocked all over - my chair, table and everything near system. Camera also stopped dead. I wanted to sort out for clear video when everything started biting me. Thought camera packed up too.
                          Original discovery Part 6: Waiting to activate - this one take them real long.
                          Reviewing all, I just realized there is something I changed shortly before all went bonkers!!! Thus the system was not likely affected by all night run but rather by this tube!
                          Stupid me, must have been more seriously affected by the HV!
                          I changed from CFL tubes to the long 32W Fluorecent tube on the table !!!
                          • Last one for now
                            This was the last video before the papaya was kicked by an elephant.
                            YouTube - Aromaz 008 - Dynamic Resonance Theory showing its face
                            • Help with strange English
                              I am trying to understand this, but it is way above my watered down Asian English. Could somebody please have a look and try translate to common English for us? Might be interesting to understand what this people meant or is doing.
                              Patent Searching and Inventing Resources
                              SELF-RESONANT IGNITION COIL AND SYSTEM
                              United States Patent 3566202
                              • Here is a way to capture the BEMF from the Ignition coil.
                                It will go up to about 97v in my big 44000 mfd capasitor.
                                Once I get it started I hook up the ground that has the 100 ohm resistor on it.
                                If I dont its hard to start.
                                I allso tried grounding the cap. to the earth ground and the light got really bright for a second then it shout down.
