  • Inquorate
    Standardized cap pulse circuit for gmt frequency recording for Aromaz circuit
    @bodkins / all
    Ok, how about a large resistor before earth, another resistor coming off it.. Etc, google voltage divider circuit
    Voltage divider calculator - loaded and open-circuit damping volts potentiometer - sengpielaudio
    so we have 100v left, to a 200uf >100v cap with neon triggering an scr (silicon controlled rectifier).. And possibly a counting circuit, anyone better than me at drawing up a schematic???
  • Inquorate
    william lynne
    I have as PDF thru fileshare a couple of books by william lynne. Apart from his strong overtones of MIB, pentagon ufo's etc which ppl may or may not believe is true, this guy has had a lifetime of synchronous coincidences, and has formed a great picture of solid/fluid aether and theory on how tunneling vortices in aether space contribute inertia to objects, and details ideas on how these vortices impart motion to mass (gravity) based on polarization of electromagnetic field. (down) and how tesla wrote a letter once to someone I can't remember off the top of my head, saying he had built a craft way better than 'aircraft' based on these principles.
    Vortices impart resistance to change of flow of motion, because they don't want to stop spinning how they are.
    I'm off to sleep.
  • Vortex
    Kozyrev: Aether, Time and Torsion
    A big Hello to Everyone,
    as Bodkins put it "Same Page" ..
    Please take the time to read, really good info
    This info will make your HEAD SWIM and YOUR MIND CLOUDY with ideas what to do first in your experiments.
    THE AETHER SCIENCE OF DR N. A. KOZYREV by David Wilcock @ 2006
    only a few Highlights from the article:
    "all changes are caused by some form of movement,
    and without movement there can be no time."
    "In 1913, Dr Eli Cartan was the first to demonstrate clearly that the "fabric"
    (flow) of space and time in Einstein's general theory of relativity not only
    "curves", but it also possesses a spinning or spiralling movement within itself
    known as "torsion"."
    "Kozyrev proved decades ago that these (torsion) fields travel at "superluminal" speeds,
    meaning that they far exceed the speed of light. "
    "It is important to remember that these experiments were conducted under the strictest conditions,
    repeated in hundreds or in many cases thousands of trials
    and were written about in extensive mathematical detail."
    "Kozyrev's work showed that torsion fields can be
    absorbed, shielded or sometimes reflected".
    Tesla of aether : "behaves as a fluid to solid bodies, and as a solid to light and heat".
    "... Tesla's statement that the aether has a fluid-like effect when we are
    dealing with solid objects, as this ties in directly with the work of Dr N. A. Kozyrev."
    "Kozyrev's work forces us to visualise all physical objects of matter in the
    Universe as if they were sponges submerged in water."
    Try using SUGAR in your experiments .. yes Sugar!!!
    and turpentine ...
    Ignore stuff saying Kozyrev was an astronomer, an astronomer he was not, smoke and mirrors there.
    Full Name Nikolay Aleksandrovich Kozyrev
    nexusmagazine seems to have some info about him but it isn't free
    For more data on Kozyrev's experiments, see David Wilcock's complete paper,
    "The Breakthroughs of Dr N. A. Kozyrev", with illustrations and endnotes, on his site.
    On the web page above, be sure to read the items below:
    ANTI-GRAVITY EFFECTS CAUSED BY THE DIRECTION OF ROTATION
    LOCATION, LOCATION, LOCATION
    LATENT FORCES EXISTING AFTER ENERGY STOPS BEING GENERATED
    MASTER LIST OF NON-MECHANICAL DETECTORS
    ETC ETC ETC !! WOW !! STUFF
    Still just a
    Randy
  • Bodkins
    Hi Vortex
    I have always seen it as that. In my old video i say "people say thats my captiacnce but i think its somethin else!" Im a big fan of Sir William crookes!!!!
    Im on the same page as you Vortex ( the same)
  • Vortex
    Originally posted by Bodkins View Post
    @Inquorate good idea easy cap charging can be done with a scr and a neon.
    @stephenafreter with try this
    All@check is out
    Kirlian photography - Wikipedia, the free encyclopedia
    Yes, that's the force coming from your body when you touch a TUBE which
    changes the flow of energy around the tube, allowing energy into the tube where your finger is touching.
    You are not the SOURCE of the energy lighting the tube, you are changing the flow of energy around your finger, allowing it to enter the tube around where you are touching it.
    just
    Randy
  • Bodkins
    All@check is out
    Aerospace Engineering Online: Studying aircraft lightning strikes
  • Jules Tresor
    Replacing earth by water
    Hi everybody,
    Congratulations for your new advances in free electricity !
    I think we are much closer to master it after Aromaz discoveries
    I was wondering if a glass of water with a carbon rod inside could work as ground/earth to increase the energy; like guys discovered in the Dr Stiffler thread a few months back ...
    I wish I was in situation to put my hands on !!!
    Good luck !
    MDG
  • Inquorate
    Flyback ignition coil
    I read up about flyback transformers a while back, they have a one or two turn wire around same core as primary winding, and one wire from this leads to transistor to switch it when the primary loads up..
    I also found a post somewhere that said a couple of turns around the outside of an ignition coil is sufficient to provide pulse to base of transistor, and can then use flyback transformer circuit on to drive ignition coil. However, that was about the time Aromaz started with the self switching 2n2222's, so I didn't try it.
    @all - if we're going to keep records of changes in frequency over time with Aromaz circuit, to maybe get a heads up on a pattern in aether frequency changes, perhaps we could all use greenwich mean time, and that'll make correlation easier. After about a month or so, with us being in different time zones and sometimes in same time zones, we can see if fluctuations are worldwide or local etc...... Bet it would look good on a graph. Can we all donate an hour every couple of days on same setup, checking every 10 minutes? With amp draw in, and maybe we can all use same circuit to dump from a cap, same voltage and farad rating.. See how quick it charges up / how many times a minute - at the frequency system is running at... Maybe I'll draw up a data collection form. any ideas on cap dump circuit that everyone can duplicate easily?
    Big ask, I know, but the information may just prove invaluable in working out aetheric frequency. Moray claimed to know it.
  • Lidmotor
    Flyback Transformer CFL Driver
    I found a flyback transformer and tried it out today. It makes a pretty good CFL driver once you figure out how to wire it up.
    YouTube - Flyback Transformer CFL Driver
    Lidmotor
  • gotoluc
    Hi everyone,
    I have uploaded a new video demonstrating the effects of a higher input voltage at the coil.
    I had to cut the video at the 10 minute mark, so I could not show the temperature reading taken off the bulbs surface. It was 130 degrease Fahrenheit
    Video: YouTube - RESONANCE EFFECTS FOR EVERYONE TO SHARE test 4
    Luc
  • nat1971a
    I thought i should expand on the concept of quarter wave length a little
    i should also mention that 1/4 wave length resonates with the neutral points (nodes)....remember aether is described as being a neutral particle or object or whatever...
    For those who do not know what a neutral point i shall explain a little...neutral point is the void, the bloch wall, the neutral centre (keely), the 5th dimension (shauberger), the aether (tesla), zero point energy....it is known by many names in my book (@allcanadian may remember this from our dealings with ERFINDER)
    as i mentioned earlier hertz in his book of 1893 electric waves mentions quarter wave length as being 1.8metres if i remember correctly
    Then in the research i did on Tesla pierce arrow (if i remember correctly)...i came across two interesting pieces of info. two different pieces of information. One article mentioned the height of the antenna on the pierce arrow as being 1.8 metres high and the other being 3metres high.
    So the height of the wok could be very important. A little experimentation should confirm 3 metres or 1.8metres very quickly. Now if i remember right aromaz mentioned the height as being 3 metres
    In Telsa's wireless article of 1919 (i think) he quite clearly shows us pictures of his antenna with nodal points drawn in. But dont expect him to give all the info away.
  • gotoluc
    Ive been playing around with this sort of circuit too Luc. The tl494 I have been using can also be configured to activate two separate PWM channels. The window motor I built using the full sequential circuit runs on a similar principle, where the DC input is "flip-flopped" or rather the drive coil is driven in a style that is similar to AC power
    Id love to chat more about this, as it could be utilized on a transformer with a center tapped primary for some interesting results I think. Check out this one that uses the tl494 I found. High Voltage Labs - HVLabs.com
    Its for a plasmasonic speaker, but could be utilised for other purposes. Also check out "push-pull" configurations, that are similar again Im working on one that requires no signal gen, cause all I got is DC.
    Maybe we should start a new thread for this one Luc, perhaps Ground loop could join and advise us too
    Hi ren,
    It's good that you thought of the plasma tweeter at this time since Corrie was hearing the beautiful soft whisper wind sounds plasma can make
    I also believe this simple flip flop DC circuit has many applications as this was not what I had in mind to do with it when I had the idea. We can continue if you wish at the OU topic I started RESONANCE EFFECTS FOR EVERYONE TO SHARE, so no need to go off topic here. Also Groundloop should be by there soon.
    I'm now setting up my variac through FWBR and cap bank (filter) so to test higher input voltages. I'll post the results soon.
    Thanks for sharing.
    Luc
  • ren
    Hi everyone,
    I just uploaded a new video to which uses and demonstrates a circuit that was designed by Overunity user: Groundloop.
    Groundloop came up with this circuit design after I asked him to replicate a 12vdc DPDT relay for me but using solid state components. Since I had some IRF640 MOSFET's on hand and some 4013 I asked him to use these components in the circuit if he could. Being a brilliant electronics man that he is ... in no time did he come up with the circuit below to which is now public domain Also please note that I asked Groundloop to make the schematic illustrative (not standard EE), so I and most anyone with basic electronics skill could understand and build it.
    A big thank you to Groundloop for all his help.
    Here is the new video: YouTube - RESONANCE EFFECTS FOR EVERYONE TO SHARE test 3
    What the circuit is doing in the video is using a DC input (12vdc Battery) and reversing (flip flop) its polarity on the output (coil) at the desired frequency I chose using my signal generator to trigger the logic side of the circuit. Please note that none of the power of the signal generator enters the circuit. Also, in this video the power for the logic (switching) is coming from the same battery since it works on 12vdc. However the circuit can take an input of up to 200vdc on the switching side but the logic side needs to be 12vdc at all time, so that is the reason for the separate input feeds.
    Luc
  • gotoluc
    Hi everyone,
    Luc
  • stringguy
    re cycling
    @Inquorate,
    thanks for the helpful advice. i always seem to end up with old computer monitors and scanners, which i pilfer the step motors from. anyway that was a very helpful post of yours for people in situations similar to mine.
    another thought i had, the orange juice containers here are made from waxy cardboard with foil inside, probably perfect for those t/roll tubes you guys are making.
