The Astute Observer...cough...will notice here that this whole contraption thingy is sort of resembling a possible pathway to a home based electrical power station. Thanks to Engineer Xavier Borg we now have the basic concept of how to create a magnetic field generator, one which can be controlled, sending waves of power through it, and now we need to create some home brewed piezoelectric capacitors that will be driven by the waves. That is, they will be warped or flexed by pulsed magnetic waves, and these will then cause the crystalline structures of the capacitors to produce electrical energy.
Now I imagine we want any home power stations to remain on the ground so it's advisable to arrange the capacitors to drive themselves towards the ground, instead of towards outerspace. Mentioning this because it's so easy to forget the important things in excitement: Like enjoy that free energy Martians. Alright, well the idea here is to recall the concept of force multiplication (*this is where military brainwashing pays off) so as to use the compressive forces generated by one piezo plate upon another piezo-capacitor plate.
Now if you haven't already ordered a drawing from Mr. McCandlish then you should, because ya know there's more in those drawings than I myself ever imagined and of course it's the right thing to do if you can spare a few bucks. Maybe someone out there will see something I cannot. Certainly I was completely clueless what the heck I was looking at when I first opened mine up. Now though this illustration is showing me more. So the piezoelectric capacitor plates are layered and stacked in odd configurations. This now shows that the idea here is for force multiplication; using one plate to assist the next plate.
You home energy freaks need to look at these things. I'm tired of these phony energy bills. Get busy out there: Enough with the Don Quixote windmill designs.
So now here' a sketch I slapped up to better illustrate the over-all concepts of how the power is managed in this system. All main power is transmitted and received through wireless technology. What kind of wireless system will work best is something members of this forum would know better than I.
In this concept the disc does not rotate, rather the inner coil rotates and pulls the electrons along on the required orbital path necessary to keep the electrons from bouncing around off the lattice structure of the disc's conductive material.
Also note that I marked out an angle between the magnetic field generator and the piezoelectric capacitors, because there is a relative height of unknown proportions, and these will have to determined by empirical testing.
Because a pair of dissimilar sized torus winding's demonstrate a projection field on ferromagnetic materials, I'm thinking that this is also carrying the vacuum polarized field in the same direction, assuming there is such a field because they appear to be one and the same but might not be exactly the same.
*Note: The reason this is pulling the electrons inwards is because it cannot work in the reverse manner. That is, if one were to try to reverse the procedure by projecting the electrical energy outwards, it would not be compelled to move in a curved or orbital like manner without an exterior magnetic field rotating along the edge of the disc, or without the disc itself being allowed to spin/rotate. Also I'm speculating that there may be a core magnetic rod inside the receiving worm gear like coil. If so it would be a magnetic rod at dead center. That's just a thought right now. In any event the magnetic fields center is dead center along the axis of the disc.
PS: So now we have returned to the beginning of this thread but understand it anew. The rotating inner column, what is it, what is it composed of? This topic is once again a subject for discussion and debate. We now can understand it's purpose and what remains is to discuss what would best serves the purpose? That is, is it a metal winding, or is it an electrically conductive gas, or is it an electrically conductive ferrofluid?
Experiments: Experiment 10
This experimental replication would seem to suggest that either the disc itself must spin, or be allowed to spin as shown in the experiment. Reason says that if we instead induce the electrons to move in an orbital like path through the conductor, then, that orbital path will result in the same state of low resistance and thus increased electromagnetic field production.
Now originally I was thinking to to achieve this microwaves made sense, but I don't actually know anything and so my wiser associates said this was vacuous thinking and that there would be no need for such complexity. In a rare moment of lucidity I decided that maybe I really didn't know what I was doing: I went back to the drawing board. So now I'm thinking what we have here is like a return back to something like my original illustrations with the twisting conductors in tubes.
The idea here is wireless power transmission, and frankly this concept seems to be illustrated in some of the other drawings seen in a couple of McCandlish videos of the interiors of Alien vehicles as reported by abductee's.
In those you can see there appears to be wireless energy transport designs. So in order that this metal disc remain stationary there is an inner winding which rotates in the vertical axis (worm gear style) while the so-called antenna remains stationary along with the disc, and with this concept the energy is then being collected or transmitted, as the case is undetermined right now, and thus the electrons are following this curved path which otherwise would be obtained by the disc itself spinning.
If this concept is correct we have a basic outline for an electromagnetically driven capacitor based vacuum polarization vehicle. As of right now it seems to me that the McCandlish illustration is dead on accurate. At least every part is now explainable along with his later illustrations obtained from descriptions of abuductee's.
All major parts to the Illustration now seem to fit together.
Consult this link for images and explanations of present wireless power transmission. Film based capacitors. Smart Crystals.
The page you are looking for cannot be found. Please make sure that you have entered a valid URL. If the link from another website is incorrect, the page cannot be displayed. The page you are looking for might have been moved or deleted.
All true Ufopolitics except that we don't disagree on aliens existing either. I can make a strong argument either way. The arguments I've presented are the one's the system doesn't want you to think about. I present what I have precisely because doing so put's the system in the hot seat. They can't claim the technology they have is alien technology when I know damn good and well it's not that advanced. It isn't technology from a Type III Civilization. It's far too primitive for that.Originally posted by Ufopolitics View PostHello Guys,
Even though I am not constantly posting here...I come almost everyday to check on all new posts...
Gambeir, our only difference is my belief in Real Aliens exists...versus yours not believing.
Beyond that, I could say I do agree with most you are writing here in a 100%.
And basically, looking at just "simple stuff"...and analyzing it...will get Us all to understand "Our System" as it is now.
I will set a simple example...very simple.
Let's say that "Mr J. Doe" patents a very simple way to build your own flying machine...based on electromagnetism, motors, generators, etc...A BASIC and SIMPLE PROPULSION SYSTEM...But so stable, than EVEN SHUTTING OFF MAIN MOTOR(S)...it will "GENTLY" GLIDE Back to ground, like a feather in the wind...just because its DUAL PROPELLER SYSTEM, will keep running, even after engines are off...and guess what...YES, and still charging the storage batteries bank...
Do any of you believe that Our System would allow something like that to be MARKETED?!
First Department ON TOP of the USPTO and INTERNATIONAL PATENTS COMMONWEALTH (WIPO) "World Intellectual Property Organization"...That would put a BIG SCREAM NOT TO RELEASE SUCH PATENT....would be the DoD (Department of Defense)...Followed by the DoE (Dept. of Energy)...
But looking very simply at J.Doe's patent and his "flying machine"...let's ask some questions:
1- What would happen to all the already build Highways and streets...all over the Planet?...if a very easy to build flying machine comes to the market, so easy that even a solely guy could put it together in his backyard?...And then the Chinese are going to build it in production like they do with all they get to start up making in the Trillions Scale?
2- What would be of Oil and Gas-Diesel Engines Corporations, just in the Aircraft Industry alone?
3- Finally...what do you think would happen to Mr J. Doe and his "brilliant idea"?
What Country in the ENTIRE WORLD would back up his idea and take it to a Massive Production?
And am NOT talking about the design of actual and complex Four Motors/Four Propellers System Drones...BUT SIMPLY JUST TWO...Two Propellers, and Two Motors?
And I am not talking about FREE ENERGY here Guys...but just a simple design, which allows to climb up...then while "Gliding Down", BUT ADVANCING, will keep regenerating Batteries during LONG TRIPS?
A simple and very common way to fly..."Nose Up" then "Nose Down" method...which applies to every single Aircraft we know off...from Commercial Big Jumbo Crafts to small R44 Helicopters...
Above was the simplest form of a new type of Flying Machine...and still, it CONFLICTS with Our ACTUAL System, to the point it would become a "National Security Target"...or Red Flag.
The truth is there probably are alien beings living among us right now, but what we have are stories told to us by a covert Corporate Dictatorship of Billionaire Thugs, and they have a reason that they don't want us to see, know, or to meet real aliens. There's a fear in that. Fear that they and their grip on absolute power might collapse as result of us gaining access to an alien creature or alien technology. The more I can get people to call the propagandist a bunch of liar's, the more likely it is we will all get to the bottom of what the truth is.
The billionaires business has been to pollute our air with chemtrails of carbon waste from coal plants, to pollute our lands with toxic lead from gasoline engines, spread cancers and plague via their vaccines, to polluted our oceans with oil and radioactive waste with intentionally flawed and dangerous designs, which is of no concern to them; why should they care, don't they already know there's tens of thousands of other planets they themselves can move on to, and don't they themselves already possess the means to do that?
Filer’s Files #26 – 2017 Kepler Finds 4,034 Exoplanets
Filer's Files #26 - 2017 Kepler Finds 4,034 Exoplanets - National UFO Center
My point in saying there are no aliens makes us all face the true depths of this criminality and the criminal mind. See, the reason they tell us there's aliens is because this enables them to continue living how they always have lived. They can continue to pretend they don't have this technology: We work and they eat. They can have the stars and you and your kids can have McDonalds for a job with a future as, well, probably dead from unemployment and starvation. Either that or gunned down on the street after botching a robbery trying to buy diapers for the kid at home.
UFO Technology may be alien technology. That's neither here nor there. What is of importance to the rulers (Billionaires) is that this technology will end their position as slave masters. That's why this whole topic is so "Verboten.
They are not going to surrender this knowledge. An example might be the designs from Boeing for electric fan jet motors just proves they have plans to keep civilization in the dark ages. Their idea is leave this planet devoid of life because there's thousands of other worlds untouched out there in the Universe and they have the means to reach the stars.
We can't waste time trying to change the way a pack of criminals reasons, let alone survives off of by denying to all others. Don't ya see here now, that asking for disclosure about aliens is the same thing as asking a rapist to stop raping people, or a criminal to stop thinking like a criminal.
The only way we are gonna get these billionaire criminals to disclose anything is at the end of a gun barrel in a firing squad at a public execution for high crimes, or the hangman's noose, and even those have historically failed to force most criminals to confess their crimes or to provide any relief to the victims of crimes. So there's no help from these people, not now, and not ever, we can choose to believe in aliens but so long as these people hold rulership over the planet we will never know. It's not in their interest for us to know.
They are not stinking rich pigs because they are nice people, because they aren't any more nice than the other actors who we have all read and heard about that seem so nice, but whom also happened to have murdered hundreds of people for kicks, or in their case millions of people for kicks.
The reason there's so much control being exerted on our lives may be that there is a concerted effort to detect and to capture aliens living here with us. Others have forwarded this idea and I think there's good reason to believe this is true. However alien space ships are probably not like the ARV or saucers which we now have a developed historical record of, and so these have to be human made machines, and they have to be in the possession of this rulership class. There is virtually no other logical explanation for these other than them being man/woman made contraptions.Last edited by Gambeir; 02-06-2018, 11:49 PM.
Looking at the "simple stuff"...
Hello Guys,
I imagine you must know the old Chinese saying; "you can flatter a man to jump off a cliff."Originally posted by Sputins View PostThanks for addressing my question. You make many important points in each of your paragraphs. I agree with what you’ve stated and can’t really find fault with any of it.
To answer you directly I look to Ken Wheeler, John Iwaszko, Mahmoud E. Yousif, Eric Dollard, and *Wilbert Smith: The New Science
When it comes to education and understanding the secret to it; what it is, what it was intended to be, where our present global system originated, what's it's purpose and intent, then the authority is John Taylor Gatto.Originally posted by Sputins View PostThere is certainly so much more going on than meets the eye. In every conceivable way the general populous of society is being milked for profit and kept blinkered, to an almost blind state, not to mention all the methods of control, like the establishment of controlled education.
The Ultimate History Lesson: A Weekend with John Taylor Gatto
John Taylor Gatto: The Underground History Of American Education
I've watched his 5 hour video series on Youtube twice. I also read his book, which any public library will have available, and would urge any parent to read as well as watching the video's. I was taking notes on Gatto's video's when this certain Southerner side tracked me along with another Secret Squirrel into this ARV inquiry.
I'm pushing this because I know John Taylor Gatto without ever having been introduced. See, my old man was a teacher, a crusader, and he too found what Gatto did, and he too paid the price as Gatto did. This man is a good man trying to what should be. No kid should be subjected to the world that pretends to be education today: We can change that.
As for the ARV I can't even remember how long ago it was that I began this inquest, but it's been a couple years or more. I was pretty clueless when I started this and I don't feel especially a whole lot brighter for the labor, but I am more convinced than ever that this is some pretty old technology. The illustration Mark McCandlish drew up was a pretty solid image of some 1950's flying saucer. It's a good illustration of a saucer that's at least a half century old. If it's not spot on it's at least has key elements. Again, this all might go back to unseen hands using others good intentions to get information to us in the only way possible, and ya know Mr. McCandlish paid dearly for that illustration.
Yes, great points. I also think the cloaking technology is there right now to hide things in the sky and a there's this fear that these spy drones are going to be accidentally discovered, run in to by some kids with a drone or some other disaster, and God forbid someone with a brain makes off with it and discover something. Next thing ya know we got brats on hoverboards running lose.Originally posted by Sputins View PostBeing an RC collective pitch helicopter and aircraft flyer myself, there has been little regulation in their use, that is up to recently. Introducing powerful light-weight batteries, F.P.V. systems and the “almost flies itself” drones are in common place, of course now they want to regulate them and know who’s and flying them. One reason apart from turning a profit, is because it is one technology available to the common man, which has the capability of live-streaming in HD resolution, IR vision and could be used as a powerful surveillance tool by anyone. This presents a problem, as this is an unacceptable situation and risk (to them). Who knows what secrets someone could discover with the help of a hobby grade, high-tech drone? Thus they want them to be regulated…
Sputin's, in a way this question get's back to education. Throughout this thread I've hammered on the corrupted educational system, but people far more qualified than myself have spoken about the corrupted knowledge.Originally posted by Sputins View PostMy point is though, or my question relates: via the disclosures given by Tompkins and others, is there a some tid-bits of information that can give us direction, a notion or area to study, that we can learn from, (such as the Heim Cosmic Theory), that we can experiment with to help bring an understanding of how some of this hidden secret technology might work and where someone might build a backyard demonstration of “impossible” physics?
"Nothing in the world can take the place of persistence"
Calvin Coolidge
The one thing I learned from being around cops is to never give up, never stop looking, never stop learning, and if you can't live long enough to unravel a mystery then you pass everything you've done off to the next hot dog. Fresh eyes, new life, and new clues can go where others before could not.
Secret Knowledge is in Ken Wheelers book. That's the most revolutionary book in the last 500 years because magnetism is so fundamental to our modern world. There's a reason Ken made the book free: Otherwise it would never have seen the light of day.
Talking with Space Case on the Big Basin Drones he thought that the drones are using some understanding of the magnetic field which can be seen in Ufopolitics video's and Ken Wheeler's book. Spacecase0 tended to think the center was somehow replicating the center of the magnet, that is those round rings and in the middle is the center of the magnetic field. I also sense this is accurate. Call it a hunch but I think this is right. I sense it but can't explain it just yet.
One thing is we are going to have to go back to basics. Science is basically dead. There's not much real science going on in academia. We have to get back to before the overthrow of the traditional scientific method. This requires physical proofs by experimentation. Not by the metaphysics of mathematics that has lead off to the dead end world of make believe sorcery and the witchcraft with make believe science.
Learning is work. It's time consuming, it's draining, it can be frustrating. As the Drill Sargent's I had said; training the body is easy, it's the mind that's hard to train. Combine that with un-learning and you have a personal challenge.
Mahmoud E. Yousif's material needs to be guarded. This is the only solid information I have ever found that has come complete. This is very solid work.
Propulsion
The Base of The New Physics
New_Physics
Go here.
Propulsion
The New Physics, contains background and theoretical papers, these are:
a: Background to the Researches, Introduction to ExMF-PS; UFO Sighting Over Kampala-Uganda; Present Fundamental hysics; The New Fundamental Physics.
b: The Magnetic Interaction, (htm and pdf).
c: Elements Of The Magnetic Lines Of Force, (htm and pdf).
d: The Spinning Magnetic Force, (htm and pdf).
e: The Electromagnetic Radiation Mechanism, (pdf).
f: Electromagnetic Radiation Energy and Planck’ Constant, (pdf).
g: The Photoelectric Effects-Radiation Based With Atomic Model, (pdf).
h: The Compton Effect Re-Visited, (pdf).
i: The Double Slit Experiment Re-Explained, in (pdf).
j: Electron Diffraction Re-Explained (The Intense Magnetic Field Interaction with Crystals) (pdf)
k: The Weak Spinning Magnetic Force (F_W) (The Weak Interaction), in (pdf).
l: The Faraday Effect Explained (pdf)
m: Compton was Greatly Mistaken Using the Quantum (pdf)
In the thread I singled out Mahmoud E. Yousif's paper out on "The Double Slit Experiment Re-Explained" because it has profound implications. This is not a small matter, which is probably why it's not being trumpeted in the Ivy League Towers. It's not just bad enough that it just blew a hole below the water lines of quantum physics, but coming from a Black Man, from Africa: Well at least it's not from an Irishman.
See, there's more involved and this goes back to the corruption of the system. See John Taylor Gatto.
The Double Slit Experiment Re-Explained basically proves that QED (Quantum Electrodynamics is horse SH#@) That's the simple truth.
Now of course this paper isn't going anywhere's. Not without help.
Is Quantum Physic's real science?
David Deutsch is a physicist at the University of Oxford. I read his book, "The Nature of Reality" a long time ago. Wikipedia says this about David; "He pioneered the field of quantum computation by formulating a description for a quantum Turing machine, as well as specifying an algorithm designed to run on a quantum computer."
Yet again, when I read David's book neither he nor anyone else had a clue what was going on in the double slit experiment. Not at least as explained by Mahmoud E. Yousif in a conventional sense. Now, you have to really appreciate this double slit experiment business for what it means. This is about the nature of reality.
Now is reality made up of quantum bits of the unseen, or is quantum science in reality a manipulated understanding of conventional physics and electrical theory put in to a science fiction format?
In other words, we are looking at a potential case where what is being sold as quantum is in reality a dis-information campaign working off of known and discovered phenomena that's been kept secret, and now this information is being purposely retold in a magical like context in order to derail any real understanding.
Mahmoud E. Yousif talks about the spinning magnetic field, about an external rotating magnetic field, and he's doing that using known and testable information. Replace the word quantum with the word magic and in most cases there's no difference in meaning. I wouldn't be forking over 40 grand a year to study quantum anything, let alone with the free information that's available on the internet, which takes us back to the purpose of education.
So right now I would say there's these people and then there's the people they themselves recommend: Ken Wheeler, John Iwaszko, Mahmoud E. Yousif, Eric Dollard, and John Taylor Gatto. *Wilbert Smith: The New Science is like the precursor to all of this. His thoughts and writings are probably fundamental to the real work that has taken place over the last 50 years. I'm re-reading his work "The New Science."
The first four go together, and Gatto is in a class by himself: Sort of a coming to Jesus if you will, in the sense of; "the truth will set you free."
Naudin is of course an excellent source to consult. The Gravity Shielding Experiment from Chris Hardeman for example. Note here that a disc is a 2D representation of a sphere, which is of course a 3D disc. We are clearly being told things. The crop circles were attempts to communicate fundamentals.
Now of course those are being messed with intentionally by so called fakers and probably by a counter campaign using the same technology. These things, these crop circles, these flying beach ball thingy's that have been reported and seen are almost certain to be coming from human technology. These are not the technology of a Kardashev Scale Type III civilization, of a Galactic capable civilization which would be required to reach our planet. If there's a war in space it's with the Russians or Chinese most likely, and again it would be using secret technology. It's either that or we are actually fighting the Martian's.
Originally posted by Gambeir View PostI recognize the name and Richard Dolan and Jeff Rense interviewed him. A big list at the link on Tompkins.
William Tompkins & US Navy Secret Space Program ยป Exopolitics
Secret space programs were built in to the national defense. The SR-71, the F-117 and endless studies and paper projects we know of show this. The real issue is an alternative civilization built with stolen resources and money being extorted on a global scale for an elite over-lord society. The system has abandoned using pretexts like paper projects for it's money laundering schemes to steal resources, and now it's missing trillions from the nations treasury and has no accountability to anyone, nor does it care.
The United States is being operated as a for profit enterprise by corporate bodies and their crony associates. They choose with their combined tax free donations who will be the next up-coming politico, they choose both sides so that they can't lose. The people are being strip mined with unlawful taxation's and no legal remedy exists. Prima facie evidence of this fact is all around us. The criminality of this theft operation has now reached the absurd. As an example the FAA (Federal Aviation Administration) is now requiring toy aeroplanes to pay a registration fee, along with abiding by a mountain of rules and regulations that no one voted on. So this is completely out of control.
Now of course it doesn't take a genius to see who's behind these rules and regulations on one level, but as with the Big Basin Drone images there's more going on than meets the eye, which I promise to get to in a moment, but what it shows is that every part of the government is being turned in to a for profit entity. It is Taxation Without Representation which is tyranny and all corporations are tyrannical dictatorships. The unrestricted warfare on our government by corporations has now officially over-thrown the rule of law. There are no more remediation by legal means if the corporate dictators decide the law is in the way of their plans for becoming absolute rulers.
This administrative ruling concocted by the FAA was challenged and successfully defeated. However the National Defense Authorization Act signed by the President reversed that legal decision. This is corporate america's giant "F you" middle finger given to the people and to the principles of law and the supreme laws of the people contained in our Bills of Rights. What could better serve to illustrate this absolute rulership than to put criminal penalties on a child's toy? To tax that toy, and to threaten all who fail to abide by dictatorial edicts.
Academy of Model Aeronautics - Government Relations
Thus by corporate decisions, instead of by rule of law, we are all now being taxed and regulated for profit and becoming micromanaged with a privately controlled hiring system that has also militarized our police forces as well as placing those illegally under a national control system of authority. Given that kind of context we need to ask how is it that toy airplanes and toy drones warrant the inclusion into the nations defense such that they require this kind of regulation? What kind of paranoia can warrant the regulation of a balsa and tissue model plane in the National Defense Authorization Act of 2018?
Now I know the propaganda carried a rash of stories about drones doing this and that, but how do we know any of those were real? The National Defense Authorization Act of 2013 legalized lying in the media, and Obama created a ministry of truth in 2016. However, maybe we should be grateful because if they hadn't gotten their way by lying and fake news stories then they would have flown a model plane or a drone into the cockpit window of some airliner and murdered a few hundred people so that would have a pretext for getting their way. It's what they did on 9-11 and it's what they do all the time. If the liars on the news can't convince all of us, then by God a few hundred dead in another mass shooting will, or something like that. This is absolute proof that something is controlling and this something has a plan for itself. This is now getting back to the question of a Secret Space Program and so we have to see how this taxation and regulation of toys relates as a potential threat to such a program.
To begin with there can really only be one possible conclusion: There's things in the sky we can't see, and these things are out there watching right now, or there soon will be things in the sky we can't see watching us and ruling over us. We do not now have drone delivery and we are never going to have Amazon delivering crap via a drone. I mean the idea isn't even logical so the whole story of drones delivering manna from the sky will be half true, only it's not likely to be the manna from heaven we would like to eat. So that story is more fake news; it's a cover story. The plan is for something else to be out there, out the front door, or something that's planned to soon be out side the front door. So of course there's been a secret space program. I don't think that's even debatable. What's is debatable is whether or not it's possible to regain control over the people controlling that program and these are of course the global elites.
It's clear that the technology in the hands of multinational billionaires are light years beyond what we here have touched upon in this forum, and these elites don't want us to even talk about half the things we do on this forum, or maybe any of things talked about on this form. Wealth and absolute power is a disease our founding fathers and the pioneering people before them knew about first hand. People better stop worshiping that if they want their kids to live in freedom. What kind of accepted notion is it that we are all even talking in terms of "elite's" like those elite people (if they are people) are better than the rest of us, or that their needs are greater than those of entire nations? That is just off worldly right there all by itself.
So now we have a situation where we have reasonable cause to think that invisible machines might just actually be outside the front door. Certainly the Big Basin Drone images are our clue that this technology is probably real and that if it is real, then it's logical to figure that these are what fit in to the present authoritarian agenda of taxation and regulation of toys airplanes and so-called drones, but there's more in the past to tell us the scent of this trail is the right path. Recall the rash of new propaganda about people supposedly blinding pilots with lasers? Well ya know they can't just say it's illegal to point a laser in to the sky so they have to invent a pretext. These things tell me there's a lot more going on than just what is being gulped down by some.
What we are talking about is the Secret Civilization which Clif High and others have brought forward in to consciousness. It's not just a secret space program, it's an off planet civilization which is in the making, and this other civilization intends to feed off the rest of us here as their slaves. Willingly or not, and they intend to do that with force of superior arms and technology.
That's the message I'm getting out of the path we are on. This technology isn't being kept hidden from us all for no reason. It isn't being kept secret because it would collapse the world financially, because it wouldn't, it would however destroy the plans of a collective of people who want the power to control the lives of everyone else, and who want to be able to do whatever they want, and to whoever they want.
I think if you look at Tompkins and many others they are telling us what they believe. I don't think that they are out there doing these things because they are like nut cases or working as disinformation agents. I think they are doing their level best to bring what they know and what they have concluded to the public eye because they have a gut instinct about what is actually going on.
PS: Thanks for asking Sputin's, I doubt I've answered anything you asked about but this is really the most I can say.
I've been thinking a lot and have watched a few more of John Iwasko's videos. So anyways I've been thinking carefully about what we now know and how to create a powerful enough magnetic field that it could generate a magnetic field with enough force to levitate a model from the ground. Right now I'm focused on materials and how they may interact.
We know that if we pass energy through a conductor it will generate an electromagnetic field perpendicular to the electrical energy. OK fine, so basically we finally discovered that a spinning metal disc would transport the electric field through the ionic lattice of a conductor with out resistance. Essentially this creates a super electromagnet, but without any resistance being generated. In that way it's like a superconductor: No resistance.
Superconductive materials act like powerful diamagnetic materials and push the magnetic field out side of their body. Now copper oxides formed the basis for YBCO Superconductive Material. It's a so called Cuprate. Yttrium, Barium, Copper Oxide.
Now there's another newer version called BSCCO. Bismuth, Strontium, Calcium, Copper Oxide.
So now they are taking this stuff and...get this...crushing it into a silver imbedded tape. Also there's cables which sound a lot like the description of the gold and quartz wires described in the article Flying Triangles And The Black Holes On My Fridge
So now looking at those images of the Big Basin Drones I was thinking that the wires on the top, the long curved ones, are for picking up energy remotely as John Iwasko shows in his video collection 15A/B I think they are. The Drone is basically a large ring, so I figure there's a solid state ring doing basically what the ARV's complete system would be doing. I already proposed using microwaves as the energy source because we need to compensate for the fact that we can't spin a metal disc to high enough rpm's to generate a repulsive magnetic field strong enough. Now obviously neither could the builders of the drones or of the ARV, unless they did it by shear scale, so there's got to be a way to work round the problem.
*Revised this paragraph in hopes of making the gist of the idea a little clearer
What about the disc not spinning and the outer antenna ring is instead sending microwave inwards, and the center is a magnet. This makes a lot more sense because the the microwaves orbit the magnetic field. This is how they pull or guide microwaves in an oven. This would mean that the microwave energy is basically doing what it would be doing if you could spin a disc conductor to high enough rpm's. Make sense? Ok, so now they take this so called high temp superconductive material which is imbedded with silver as the conductor, and this is producing an electromagnetic current while the cuprate is ejecting the resultant electromagnetic field, and because the energy is now cycling (*orbital like) it replaces the spinning previously done by a mechanical rotation of the disc (hence no spinning disc) and so now both the conductor and the cuprate should still act as though it were in a super-cooled state without actually being in a super-cooled state. That's my theory right now.
A basic outline for the Big Basin Drones would be a magnetic ring on the inside of the main hole, with a layering of these tapes making up the majority of the surrounding body part, with an outer guide ring that cycles microwaves through it. The microwaves are pulled through the conductor to the magnetic ring. No spinning involved. Power is supplied remotely.
*Note: I Went to add these link a few moments after the post and got chopped of from the forum last night. Cyberphysics - cyclotron
I recognize the name and Richard Dolan and Jeff Rense interviewed him. A big list at the link on Tompkins.Originally posted by Sputins View PostHi Gambier,
What do you think of William Tompkins accounts of the S.S.P. story and related information?
He died recently, back in Aug 2017, being 94 years of age, shortly after the his address at the (July) 2017 MUFON Conference.
Have you found any nuggets of information within his interviews regarding this thread topic?
PS: Thanks for asking Sputin's, I doubt I've answered anything you asked about but this is really the most I can say.Last edited by Gambeir; 02-02-2018, 06:25 PM.
Bill
Hi Gambier,
Building a better mousetrap.
In the Big Basin sightings one report talks about how close they got walking directly below the drone. These drones were not silent. They had a low pitched hum like one would hear around High Voltage Power Lines. This humming is a clue that High Voltage is nearby. Humming is a property of Magnetosriction, which is then a property of ferromagnetic materials which causes them to change dimensions during magnetization. Wikipedia describes this noise as a product of oscillating AC currents producing a changing magnetic field. Really that's "snot" too helpful quite frankly, but be that as it may, at least you can connect up High Voltage with metalic clicks and humming. Clicks being specifically induced by microwaves.
Now magnetostrictive materials can convert magnetic energy into kinetic energy. This quality makes them able to be made in to transducers. Quartz is our clue here that it's this transducer like quality which peaks our interest. It's the piezolectric potential which is implied by the materials quality.
Here's where it gets more interesting because a link to magnetism has a quality known as hysteresis. "Hysteresis is the dependence of the state of a system on its history. For example, a magnet may have more than one possible magnetic moment in a given magnetic field, depending on how the field changed in the past." This implies a training like formula for the magnetic field influences its' future path. https://en.wikipedia.org/wiki/Hysteresis
Terfenol-D was initially developed in the 1970s by the Naval Ordnance Laboratory. This is a magnetostrictive material. The technology for manufacturing the material was developed in the 1980s at Ames Laboratory under a U.S. Navy funded program.
"Soundbug is a small speaker that can turn a resonant flat surface into a flat panel speaker. Soundbug was developed by FeONIC Technology (formerly Newlands Scientific), a commercial research and development company specialising in magnetostrictive audio products-"
Feonic Surface Speaker creates music, audio effects and clear voice communication from resonant surfaces. Fit without fuss in minutes.
The Vibration Speaker. Massively Powerful Surface Speakers
Review on Piezoelectric Materials as Thin Films with their Applications
by Ajay Palshikar & N. N. Sharma *Note here this review includes a chart on the Piezoelectric Properties of Rochelle Salt.
Introduction Piezoelectric materials have been largely used in transducers since the last century . Moreover, many piezoelectric materials have been synthesized by blending two compounds in appropriate proportions to tailor the properties of the so formed materials to suit the application . After the discovery of naturally occurring piezoelectric materials, perovskite structured piezo-ceramics have been synthesized
Home made diamonds, or Q-carbon was the next evolutionary step from converting graphite to diamonds. Amazing yes, but maybe more importantly; "Q-carbon has some unusual characteristics. For one thing, it is ferromagnetic – which other solid forms of carbon are not." "In addition, Q-carbon is harder than diamond, and glows when exposed to even low levels of energy." https://phys.org/news/2015-11-phase-...mperature.html
Piezomagnetism is a phenomenon observed in some antiferromagnetic crystals. Piezomagnetism was observed 1960 in the fluorides of cobalt and manganese. https://en.wikipedia.org/wiki/Piezomagnetism
Now the rest of this here implies a solid state modeling for generating effects pioneered by machines like the ARV. Yes, if you review these you see it's all about disc drives and thin flilms, but reading here between the lines the implication is that by stacking or layering a controllable magnetic field generating a magnetic field dissymmetry could be engineered.
Giant magnetoresistance
"Colossal_magnetoresistance was discovered in mixed-valence perovskite manganites in the 1950s by G. H. Jonker and J. H. van Santen."
"Colossal magnetoresistance (CMR) is a property of some materials, mostly manganese-based perovskite oxides, that enables them to dramatically change their electrical resistance in the presence of a magnetic field. The magnetoresistance of conventional materials enables changes in resistance of up to 5%, but materials featuring CMR may demonstrate resistance changes by orders of magnitude."
I'm surprised no one has commented on the Big Basin Drone images. I know many people have dismissed this incident and that it has faded in to memory.
As a result I'm posting this link where a superior analysis was done on the supposed linguistics of these drone. I think this is very convincing evidence, but still doesn't refute the images themselves or the people who reported them.
Aerial Drone Mystery Report
FYI. Supposedly this was all a marketing ploy for Dell Computers Alien Ware. Nevertheless, I would be cautious of leaping to the conclusion that this was a prank by a corporation as a marketing scheme as sold here and elsewhere. Older people will recall the stir these made at the time coming with a supposed story about alien vehicles, secret research labs, and stolen papers that made their way out in to the net under the name of project C.A.R.E.T.
The "CARET" Program - Explanation for Drone UFO Sightings in California
This has clearly turned out to be a black op cover story. Obviously prepared beforehand. The writing on the vehicles themselves would be the most logical pre-planned course to take so that the cover story could be used if any were photographed or brought down by someone. Finally the final finishigng nail in the cover story being the breaking of the lettering on the supposed photographs. Thus convincingly proving it was all a hoax done as a marketing scheme.
However, I don't see where Dell Computer ever owned up to having pulled this stunt, which even if they did wouldn't mean a whole lot.
Real Drones this advanced (over ten years ago now) would never be let out without some pre-arranged cover to explain away photographs or evidence.
Put it all together, all the information you've heard, read, and have seen, and the truth is these are real. They are outside our homes most likely, probably watching specific people or locations, and what's illusion is a story about a marketing ploy. You got a reason to be paranoid now.Last edited by Gambeir; 01-28-2018, 09:55 AM.
Thanks Spacecase0, well I noticed some of what you're talking about as well. Going to have think more about these now that we are no longer clueless. One thing you can bet on though, if these are ours, and they are obviously, then these drones are invisible and very likely not half as uncommon as we imagine. There is some discussion of cloaking at the SpaceWarp Dynamics site. Considering what is known about cloaking it's assured that these would be cloaked normally.Originally posted by spacecase0 View Postthank you for the reminder of the other methods this is done, and there appears to be a common element to it
it sure looks like a magnetic field pointed up, and spinning in a horizontal circle is how this is done.
the ARV uses a standard magnetic field and cuts it up and spins it with an electric field and has integrated electrogravics for steering
the drone thing appears to do the same thing, only it uses open wires on top, and external electrogravics for steering
the holographic antenna of the spacewarp people makes the magnetic and electric field all wrapped up together in complex shapes, and I don't think I can model that in my head
by looking at the pictures of the drone thing, on the inside of it you can see either insulators or coils between the base of the verticalish rods.
and you don't put external components with clearance somewhere when they are not high voltage, they look like 6 to 8 inches, so that should tell about the voltages involved. and that seems close to the reported in the ARV. also reminds me of what I have seen of voltage required to entirely strip the electrons from the outside of an element
sure I may have got this wrong, but at least it it gives some sort of starting point.
suppose I should use wilbert smith's rotating magnets to get some idea of how fast the fields need to be spun, that should tell if it can be done with physical switches (like a car distributor), or if it must be done with electrical switching to be fast enough
Again, I'm not buying this Alien Technology stuff. Something else is going to have to prove that to me and this isn't it. Could also be that these antenna are receiving microwaves for power remotely, but interesting how they were photographed lurking about the power lines like there was a reason. I think it's pretty clear that these are very likely secret surveillance drones.Last edited by Gambeir; 01-27-2018, 10:07 AM.
