Electro Magnetic Gravitic Propulsion and Zero Point Energy or Dark Energy
This is an explanation of what gravity actually is and a representation of how to apply this knowledge to create Electromagnetic Propulsion https://www.youtube.com/watch?v=vzY06MRzwPE
DAvid Alzofon gravity control
Hey guys did somebody heard about David Alzofon technology? This guy s father found a way to control gravity and he made his informations public...emediapress selling some conference with this guy Gravity Control with Present Technology by David Alzofon but also I found an you tube channel presenting his writings and theories ;I understand his theories was experimented successfully in labs some years ago... maybe his teachings will help us to understand a little more about gravity control technology ...
got it.Originally posted by Ufopolitics View PostHi Space,
I have not finalize the experiments...but I have been writing about it ...remember the "particle accelerator"?
It is a combination of HV Electric Fields where magnetism is just used to Drive E Fields to spin...in the Alexey case is a difference because each opposite E field are counter rotating, which obviously alters gravity or mass weight in our space time.
We get a singular spin and we get Free Energy at any surrounding coil or coils...
For Mass it should enter the resonance of ultrasound with the rest...but not sure
that makes sense with what I have seen
my testing has been messed up a bit
used an online calculator for a conversion. it converted wrong.
all my magnetic field strengths are 1/10 what they should be.
caught the error today
will take me a while to rebuild the test setup
the previous failure got me to give up on the idea,
but finding out I did it wrong on the same day you tell me how to do it as I tried before...
I have to try it again
Hi Space,Originally posted by spacecase0 View Postwilbert smith talks of the same thing, but dose not call it counterspace,
he tells of a field that would otherwise be matter being more or less than half in or out of our reality, less than half and you just can't see it here. more than half and it is in our reality.
unfortunately the chapter on how to alter that value was never written by him.
do you know of any way to alter that value ?
wilbert smith talks of the same thing, but dose not call it counterspace,Originally posted by Ufopolitics View PostGambeir,
The second this thing taps into Counterspace...we will never see it again, it will just "vanish" away within same Dimensional Space location it "used" to occupy on our Space.
Counterspace (from our dimensional Space point of view) is a void, a sink...
According to Wheeler, magnetism, dielectricity, gravity are just disturbances of the Aether in our Space/Time...and Aether is Counterspace...it lives there.
IMO Alexey Device could "perturb" Counterspace in a way that generates a counter reaction or effect which "voids" our gravitational field in our Space/Time.
Mass could be also "perturbed" by known means...as well as others we have no idea off...
For example, mass under certain frequencies and vibrations could make the strongest metal to become flexible...or even "penetrated" easily without much effort...even with our fingers...without rising one single degree of temperature.
Bugfly,
one more thing,
you show the source of power an AC sine wave
if you are looking for the effect that tesla was first playing with,
you are going to need DC, and it will be more of a triangle wave with a very sharp leading edge and the current never going backward.
tesla got the DC power by first using AC power through a transformer to up the voltage to something like 50KV, then put it through a rotary switch run by a synchronous AC motor. The result was 50KV DC at very high power levels.
this step of converting to DC before the spark gap is what modern people get wrong when trying to reproduce what tesla was doing.
Mmoved from the topic to this thread.https://drive.google.com/open?id=1Dq...KaOIhinEKtkiQA
I understand that sounds doubtful. Running electric field, etc. Here you can see some analogies, of course, these are not motors, but some analogue of a running electric field is can be seen there. I'm talking about Electric Field Mills.
Electric Field Mill
I hope I did not create such a situation that all this must be done necessarily, I just suggested it. And I hope you like the idea.
Oops I was mistaken. The wire from center goes to the sparking electrode ofcouse...Originally posted by spacecase0 View Postyes
just as you pictured
That is the right one:
Ok, now then we figured it out, let's take a closer look at the patent:
We have a midpoint in the primary windings there:
And the whole device is arranged this way:
It is really have two sections of winding! Two sections of primary winding is mirrors relative to each other, they are symmetrical.
The date of patent is Nov. 2, 1897.
Before this patent we have Tesla coil: https://patents.google.com/patent/US...en?oq=us512340
The date of patent is Jan. 9, 1894.
Thus, Tesla said in advance which coil is better.
But he didn't show it anywhere else.
Now redraw the image from the patent on the transmission of energy over the wire in a modern way:
And now replace the coils. Since we exactly pointed out where is the middle point.
So one device will look like this:
And this is a very interesting device. I did not see Tesla devices doing this way...Last edited by Bugfly; 10-19-2018, 08:41 PM.
yesOriginally posted by Bugfly View Postspacecase0, So you trying to say that Tesla has patented a new secondary winding?
So In the patent Tesla shows the comparison of secondary windings:
And inside the device they look like this:
ok, here is a short history of the tesla coil that might clear things up
long ago high power switches at the power companies would occasionally kill someone when they turned on the switch, never hurt anyone turning off the switches, and there was plenty of insulation to stop the voltage that was involved.
the power companies just changed to using relays so no one was near when the switches got turned on
so Tesla being who he was wanted to find out what was going on.
so he set up a switch that just turned on thousands of times a second, he used a spark gap for that. And he had to put the power somewhere, so he put into a large one to two turns of a coil.
this is what we now know as the primary side of the tesla coil.
the effects he got were odd,
for one, it hurt him physically if it was pointed at him
so he tried to shield from it, and he found out that standard shielding did not work well at all.
so we know already that this is not a standard electromagnetic field that he was making.
he said it could be reflected by shiny surfaces, did not matter if it was painted cardboard or polished copper sheets.
it would charge insulators at a distance
so he then made something to collect this energy and convert it back to electricity
this is what we know as the secondary of the Tesla coil
the flat coil recovered more energy from this field than a solenoid coil same with the conical coil.
the flat coil is the one depicted in the previous linked patent.
and the one pictured is wired the way it is to increase the internal capacitance,
he was trying to make the coil itself hold more energy without external components.
for why he wanted it to hold more energy, see this handy PDF that clearly is telling of a tesla coil in what is called the first type.
and if you look at what this new field can do, you see why they wanted to make it more powerful than possible with a tesla coil.
make sense ?Last edited by spacecase0; 10-19-2018, 03:29 AM.
your first link did not work for meOriginally posted by Bugfly View PostSo You mean that the Tesla coil is designed to trap the magnetic field that generated by Tesla transformers secondary winding?
By Tesla transformer which has primary and secondary windings I mean device like this: https://archive.org/details/electric...8gern/page/398
"CONSTRUCTING A 1/4 K.W. HIGH FREQUENCY OUDIN COIL."
And by Tesla coil I mean this: https://patents.google.com/patent/US...en?oq=us512340
can you try again with that one ?
So You mean that the Tesla coil is designed to trap the magnetic field that generated by Tesla transformers secondary winding?Originally posted by spacecase0 View Posta Solenoid is made to interact with a a magnetic field
the thing is that we are not trying to interact with a regular magnetic field
the field that a Tesla coil primary is making is not a regular magnetic field, it is a motional magnetic field (you could also call it a time field). Tesla did build volumetric spirals to catch this energy, and he also built flat spirals. and it looks like either catches this energy well
I am also convinced that it is standard field force interactions,Originally posted by Gambeir View PostI'm just wondering if we aren't making the Alexey and ARV out to be more than they really are? Both of them have so many similar features actually. If you took the Alexey's disks and slotted them they would look about like the ARV's base plates. I was thinking you could probably just slot the AC alone, but it's probably better to slot the DC plate as well.
If you look at the Alexey it's almost like the most basic drawing of how to generate an electrical current; a magnet moving over a conductor, instead of a conductor moving through a magnetic field, but it's the same thing just reversed. I just wonder if you slotted the HV plate in to pies and ran the thing if it wouldn't perhaps work better.
Am I wrong or don't you have basically two electromagnets working at right angles? One's DC and one is AC. The two fields interact because the magnets in the DC are acting as a kind of differential to put the circuit at 90 degrees to the AC and making the design compact.
I'm beginning to think this is all standard electrical field force dynamics going on. We just have not been seeing it because of the dynamic movements of the spinning DC plate.
Any thoughts on that?
the thing we have been missing before is that there are two separate things that we measure as voltage. and that confusion has cost us the understanding of gravity
a Solenoid is made to interact with a a magnetic fieldOriginally posted by Bugfly View PostHi, spacecase0! Interesting guess. I think it is only half true. Solenoid pulls the field out of the ring very well. But it's not actually a ring, it's a tube.
Of course, if the solenoid consists of more than one ring winding. On the contrary flat coil covers the plane very well. If we continue the reasoning in the same direction then we need to make a volumetric spiral. We either make concentric solenoids one inside the other and thus fill the volume with them, or we make many flat coils one above the other. The problem is that there is no magnetic field between the turns. May be we need alternate right and left turns inside this design. Or maybe Tesla just figured out how to do it for a flat coil. But these three connectors, where to connect them ...
