Oscillating Reed Switch Pulse Motor.
  • #91
    Current direction of collapsing field.
    @Mopozco Great, thanks for sharing results. The collapsing field of a coil wants to keep current flowing in same direction, coil behaves like battery in series with your 1.5V battery ~(-)batt(+)~~~(-)coil(+)~. Please confirm direction of LED on your drawing. Is LED cathode connected to coil so that when current from collapsing field at higher voltage (bemf) exceeds LED Vf it flashes it? This would keep the current flowing in the same direction not in opposite direction as shown on your drawing.
    The question here in the "Reed Oscillator" is: Can current flow in both directions through the oscillating Reed switch simultaneously? The answer is Yes!
    This means the current from the collapsing coil field can circle directly around to act as a power pulse without returning to the power source!
    • #92
      Collapsing back spike.
      The coil acts as a second battery in series with the first. The current from the collapsing back spike travels in the same direction as the input current, but the voltage is reversed and leading the current, at a higher voltage then the 12 volts of input power. So the input goes through the top of the coil and out the bottem, along with the back spike. The back spike passes around the surface of the battery and back into the top of the coil before any input from the battery can reach the coil.
      I theorize that the back spike beats the input power back to the power coil because the battery acts as a conductor for the higher voltage BEMF. Additionally, the increased flux from the hyper-accelerating spinner, adds more power to the collapsing field then the input can supply to the coil.
      My analog milli-amp input gauge needle rested solidly on the peg while the self acceleration raced up at super velocity. I believe it's the recycling BEMF that causes this OU anomaly!
      • #93
        I was asked to post this by MileHigh. I had to temporarily remove Allen from my ignore list to do this, but he will go back on that list after I get done posting this.
        Quote
        Zero credit. @Matthew Jones,
        This won't be the first time I was robbed of any credit; Tinselkoala and Milehigh pulled the same stunt on my Overunity "Self Accelerating Reed Switch" thread where I played a key role in the early development of the "MHOP", and was cheated out of any credit due! Try to keep me on your phony "Ignore List" bub!
        Gentlemen,
        This is the second time that "Allen Burgess" a.k.a. "Synchro1" has accused myself and TK of not giving him credit for participating in the MHOP project in his posts on the Energetic Forum. I think he posted this on the "Your Basic Coil" and "Oscillating Reed Switch Pulse Motor" threads.
        Allen Burgess/Synchro1 had absolutely nothing at all to do with the MHOP project. He was merely a bystander for the whole affair. He was not "cheated" out of anything and he made no contribution to the project whatsoever.
        For the MHOP project, I was the "architect" and TK did the actual schematic and the build and the testing. He also designed and built the LED strobe circuit which I had nothing to do with. That's the way it really went down.
        Myself and TK don't have access to the Energetic Forum. Feel free to post my comments on EF if you want to.
        MileHigh
        Allen, you are burning all your bridges. Where are you going to go when no one on any forum will work with you? I believe you want to be a serious researcher but you keep chasing people away with your attitude and lies. Please grow up and concentrate on your projects and leave the personal insults and attacks off the forums.
        • #94
          Oh what I plan on doing will be in no way theft. Allen's little motor has a very small event that can be exploited and tuned, into a larger effect that is truely novel compared to anything else, even his motor. This is a complete build of not only a motor but circuit that does not employ the Reed switch in anyway.
          This is the typical behavior that I intend to block on a regular basis. People who Spam and cause problems for people trying to build and share.
          Had Allen just dropped the chip on his shoulder I would have more than welcomed any input and discussion to forward a project. Even to the point of sharing a working device. But he cannot control himself and his derogative behavior just ruins everything for everyone.
          Plus I hope if it works well I can give it away, so definitely no theft involved. Just the inevitable evolution of a good thing.
          • #95
            "I had to temporarily remove Allen from my ignore list"
            Does that sound like "Bullcrap" or what? More "Snitch work" from Carroll.
            Our Price: $173.49
            1/4" I.D. This one's a real beauty!
            . Item: FR188-2RS Ball Bearing
            . Type: Sealed Full Ceramic Flanged Ball Bearing
            . Cage: PTFE
            . Closures: PTFE Covers (white)
            . Balls: ZrO2 Ceramic (zirconia)
            • #96
              Reed switch.
              Aything Mr. Jones does to improve on the "Reed Switch Oscillator" can only result in inferior performance just like Milehigh's substitution of the Op Amp I.C. for his piece of crap MHOP.
              • #97
                Frictionless bearing.
                Two ceramic bearings and a horizontally mounted axle results in downward pressure friction on the bearings. A steel ball magnetic suspension bearing like "Cobra killer2000's", uses the pressure of gravity to reduce friction. One flanged precision ceramic bearing at the base of a vertically suspended axle should eliminate all the downward pressure friction on the bearing, and help to stabilize and secure the spinner following an overhead separation event.
                This combination should result in less friction then a neo tube riding on a ball bearing over glass, and deliver stationary stability too.
                • #98
                  Steel bearings.
                  Two steel ball bearings will adhere directly to each end of a diametric tube magnet with no axle or disk magnet in the way. How would the tube magnet and steel bearings behave if we simply stood the combination upright inside a plastic ring with attractive metal discs, or disc magnets on top and bottem?
                  This looks like an elegant and blindingly simple solution to the bearing problem!
                  • #99
                    Theft of credit.
                    Quote from Matthew Jones:
                    "Allen's little motor has a very small event that can be exploited and tuned, into a larger effect that is truely novel compared to anything else, even his motor".
                    Matthew's describing just how TK and MH pirated my discovery off my "Self accelerating Reed switch thread" on the Overunity forum. Anyone can view it and see what really went on!
                    • Originally posted by Allen Burgess View Post
                      Of course you are hoping they don't really view that thread. If they do they will see you contributed nothing worthwhile to that effort. If you really contributed anything useful to that thread show us what it was. Otherwise you are just whining over nothing.
                      • Credit.
                        @SisMika,
                        Conradelectro explained why free energy would cause more wars on the OU forum. Citfta's with TK and MH and Conradelectro; They're all part of a counter free energy sub culture. Citfta's violating the Energetic Forum ban on those Trolls while he has me moderated by Stephan for frivolous reasons. The "Reed Switch Oscillator" exhibits OU behavior; This is why I am persecuted by that pack of Jackals.
                        • Self shortening pulse width.
                          Why is the "Reed Switch Oscillator" Overunity? Answer: The pulse width is self shortening. What would it take to get an electronic circuit to mimic that effect? Think about this!
                          I believe it's possible that an (Oscillating Magnetic Plasma Field) forms inside the "Reed Switch" vacuum chamber at the higher speed ranges. There's no way a solid state electronic circuit can compete with this kind of quantum activity.
                          Matthew Jones has grossly undergauged this awesome effect by describing it as a "Very small effect". All Mr. Jones will accomplish in the end is delivering another piece of clumsy crap like TK and MH's MHOP!
                          • Ossie.
                            I got a comment from Ossie of the "Ossie Motor" back when I first unveiled the "Oscillator". He pitched the same line of malarkey Matthew Jones just threw at me; "How insignificant my discovery was compared the idea he got from it". All four of those copy cats , MH & TK included, tried to seperate the pulse cutting effect of the "Oscillating Reed switch". Ossie did it with a second Reed switch. I built his motor and it nearly dropped dead on me.
                            Gotoluc has a pulse width control circuit he copied from Verpies and Itsu over on the OU forum; Just another overworked piece of crap compared to the "Oscillator" that recycles it's own "backspike" spontaneously.
                            I bet Matthew Jones tries to spring a Hall effect "Ossie Motor" on us, if he ever gets it to work. How boring!
                            The "top secret" configuration again below:
                            A quick review: The "South" diametric neo spinner permanent magnet field closes the normally open Reed switch contacts and charges the electromagnetic coil as it passes the switch. A "South" electromagnetic pole then appears at the end of the coil and opens the attached Reed switch's contacts before the spring action of the metal can seperate them, breaking the circuit sooner. The faster the neo tube spins, the faster the Reed switch contacts close and open, resulting in a steadily diminishing pulse duration as the rotor accelerates. The forced oscillation allows the Reed switch to operate way over it's factory rated speed limit! Harmonic speed bursts result that are truely astonishing!
                              What is really boring is watching a supposed to be grownup whining like a 1 year old that has lost his pacifier. It would be funny if it wasn't so sad. I think I need to add you to my ignore list you don't think is real. Maybe you should check your user profile and then you could learn how to ignore posters you don't want to waste your time reading.
                              • Whining.
                                @SisMika of a "walloping 32 posts",
                                Drop dead!
