Motor Generators
  • The generator phase frequency is an indicator of the rate of change of the magnetic flux (magnetic induction). At a higher frequency, a lower Magnetic Induction (for example) can be used. Roughly speaking, the power output of an electric generator is based on two formulas: electromotive force e = BLV and amperage for a complete circuit I = e/R+r.
    Here is an explanation why this technology of the simplest machine from Germany (1945) in the USA and Russia is used only for military purposes.
    • Thanks Rak........... great post of information. I was thinking RMS shows that the peak to peak would be higher at a higher frequency and the RMS. I am seeing 7X times the handling capacity from 60hz to 400hz. Can you explain why 1000hz is the same or less power than ac is produces at 60Hz or how can we explain? Some say 1500hz the size of a basket ball would need a 60hz generator the size of a shopping cart.
      But how to look at it all, I need help explaining how much power. Like a pass transformer in a switch-mode supply the Toroid runs on 3000hz -16k and is the size of a golf ball@ 500watts.
      RMS for 1.5khz is higher peak to peak so when rectified to dc is more power? Or would you say 60hz is more power?
      • Why did you decide that a higher frequency will have a worse induction result?
        It all depends on the design decisions. It's just that at high frequencies, the reactance arising in the conductor is greater. Also, the current carrying capacity of the copper conductor is lower at higher frequencies. This is very important for AC induction. If you make single-cycle pulse systems, it is quite possible to solve this problem. For reference: DC transmission lines are gaining popularity in the power industry. Converters for them are designed up to 300 kHz. The alternating current is simply constructive, but limited in frequency. Nikola Tesla became disillusioned with alternating current in the late 19th century.
        • 2nd
          Nikola Tesla became disillusioned with alternating current .
          Yes please, solve.
          That is a very interesting statement. Yes these motor generators ARE high frequency converters operating at 1000hz up to 1500hz." 2nd generation laminate coating magnet wire is better for skin effect". IS there another way to collect more EMI?? Some say this acts like an antenna? I need to think about this.
          • I am engaged in various systems, one-cycle systems, in my opinion, are the most promising. In Russian textbooks of academic physics, it is clearly stated that the amplification of the current in the vein can occur due to the additional strength of the electric field. it is obvious that this is an external electric field, must have a vortex structure, since the EMF itself is a vortex electric field
              Well that is what I need, your opinion. But I need an example to get me on board. Not many, just a single example. Otherwise I am unsure of your specific ideals.
                Nikola Tesla became disillusioned .
                Pulsed DC transmission lines.
                  Tesla took away Edison's Job.
                  Can you imagine telling those early inventors we are going to put an IGBT converter of every POLE? We can't keep one working for long now.
                  • Adams motor and the conference
                    • Will have to chat with him this year. Have a bit of info he might want to hear. Specific one is the gen coils. I need a low rpm type of coil for 18v
                      Mikey for a bit, thought this was you and was looking forward to a meet and greet. Another time perhaps
                      • Originally posted by thaelin View Post
                        No not me, but yes someday we will.
                        • 100% HHO
                          The Gasoline has been shut off, and the generator continues to run for about an hour
                          In this video I demonstrate my 4400 watt generator running on HHO Hydrogen only. The Gasoline has been shut off, and the generator continues to run for about an hour. Please keep in mind that the generator was already running for about 35 mins prior with the gas off, but my phone battery died while i was taping so i switched cameras so this is the second camera video. I show a drill running as well while as a load. The power consumption is about 500 Watts to run the 4400 watt generator. The battery you see on the floor is for the electric start, and as you can see part way though the video it decided to unhook itself and the generator was rolling away a bit. I believe the generator shut off due to the over heating of the circulation pump, as it was extremely hot to the touch. More tests to come, and I will remove the gas tank for future experiments. Looks good so far
                          • Declassified FBI Document States That Nikola Tesla Was An Alien From Venus
                            FBI report: Nikola Tesla, inventor of wireless technology, an alien from Venus
                            https://epochtimes.today/fbi-report-...en-from-venus/
                            https://mysteriousuniverse.org/2020/...en-from-venus/
                            A declassified FBI document called “Interplanetary Sessions Newsletter” was written on June 14, 1957 and contained some unbelievable claims that Tesla was originally from the planet Venus. It read in part, “The Space People have visited the Tesla engineers many times, and have told us that Tesla was a Venusian, brought to this planet as a baby, in 1856, and left with Mr. and Mrs. Tesla in a remote mountain province in what is now Yugoslavia.”
                            ...... from Germany (1945) in the USA and Russia is used only for military purposes.
                            https://www.flynnresearch.net/milita...%20Defense.htm
                            • Comment
                              • Last edited by BroMikey; 07-02-2021, 11:57 PM.
