Originally posted by tvka
In the vid here I started monitoring the amp's going from the ground through the captor to the load. Thus after the supposed magic'.
The amp's build up while input through the inverter stays the same.
Despite the fact the voltage drops to aprox 130 volt through the ground while having 9 rods, where 1 is input other 9 are output.
Meaning that the sin/cos comparasion is off so its little difficult to tell if there is OU or not. Nevertheless if I reduce the return rods, voltage drops more.
Therefore I assume, more like hoping, that more grounding fixes the voltage drop (as clarence mentioned before).
The beeping is due battery is empty had to recharge it.
Please, ask me more and if you think its hoaxed I make more, and better, video's
Here is the link, feel free to comment and be critic.
Pics of layout, also wound a test coil around perm magnets each holding 10KG. But instead if direct working on circuit it kills the main fuse so I had to put an lamp load behind it ?
Ah well need to know as I going to wind a 500M wire coil for uber highpulsed DC sparking voltage
