Oh really -- try a dose of this!
these attachments are from the Fernando Demonstration in Brazil!
it is in response to Fernandos questions for infomation about their
DEVICE as you call it!
The attachment shows their response both in English and their native language.
so much for hot wind!
Originally posted by level
I wasn't suggesting to remove earth grounding from the mains neutral if it is earth grounded, I was just pointing out that if the mains neutral is earth grounded, like it is in many countries, then you shouldn't use the mains to test a Barbosa and Leal device. I have explained this many times already in this thread. The best way to test this sort of device is using a 12 volt deep cycle battery and an inverter. This way you will elimate all problems associated with mains grounds loops. However, I wouldn't suggest going out and buying a deep cycle battery and inverter for this project unless you have lots of extra money to burn, as based on the little information Clarence has provided so far about the performance of his particular setup, his device does not appear to be doing anything out of the ordinary.
It would be different if Clarence had been willing to do some proper testing and report the results back here, and then people could assess whether or not it is worth spending a bunch of money on this or not to do tests. I have done some testing with both a Barbosa and Leal single transformer and a two transformer arrangement now, and I haven't been able to see anything out of the ordinary in my tests, but then again I am not afraid to do proper testing and proper measurements to understand how the setup is really working.
This is because I am interested in getting to the actual facts regardless of what the facts are. I should point out however that I don't have an extensive earth ground like Barbosa and Leal have supposedly called for, but my earth ground is still pretty decent and I did not see any unusual effects.
You should also be aware that Clarence's device arrangment is different than what Barbosa and Leal showed in their patent application docs. Clarence added another earth ground connection to the transformer input neutral wire. This allows the phase hot current to pass through the load to earth ground, and then return to the other earth ground at the transformer input via the ground, completing the circuit. It appears Clarence added this separate earth ground because you won't be able to power a load at all from an inverter if you don't add the second earth ground at the input of the transformer to complete the circuit via a ground path, but such an arrangement has diverged from Barbosa and Leal's patent, and although it allows you to power a load with an inverter, it doesn't seem to deliver any extra power to a load other than what the inverter is supplying.
Two very basic tests that should be a given that anyone testing this sort of circuit arrangement should do are:
1) properly measure and compare battery power draw to load power consumption.
2) Compare the device performance with the ground wire wrapped around the secondary wire, and with the ground wire not wrapped around the secondary wire. Is there any noticeable difference at all?
The Barbosa and Leal devices are supposed to deliver many kilowatts out to a load with only a small power input from the battery and inverter. So if the device is working properly you should be able to power loads of several kilowatts easily with just a small inverter of just a few hundred watts at most. Ask yourself why it is that Clarence needs a 3000W inverter to power only smaller loads. He should be able to power loads of several kilowatts with only an inverter of one hundred watts or so, based on Barbosa and Leal's claims. If the device can't power large KW loads with a small inverter of a few hundred watts at most, then it would appear that the device is not working.
People make all sorts of claims about free energy devices all over the internet, but before spending too much money to try to replicate such claims, in my opinion it is very advisable to do some investigation first and see if the claims being made make any sense at all and can stand up to basic examination. This is all just my point of view on the matter, and you are free to do whatever you like of course.
I think it is important to be aware of all these things before anyone spends too much money however.
This is because I am interested in getting to the actual facts regardless of what the facts are. I should point out however that I don't have an extensive earth ground like Barbosa and Leal have supposedly called for, but my earth ground is still pretty decent and I did not see any unusual effects. You should also be aware that Clarence's device arrangment is different than what Barbosa and Leal showed in their patent application docs. Clarence added another earth ground connection to the transformer input neutral wire. This allows the phase hot current to pass through the load to earth ground, and then return to the other earth ground at the transformer input via the ground, completing the circuit. It appears Clarence added this separate earth ground because you won't be able to power a load at all from an inverter if you don't add the second earth ground at the input of the transformer to complete the circuit via a ground path, but such an arrangement has diverged from Barbosa and Leal's patent, and although it allows you to power a load with an inverter, it doesn't seem to deliver any extra power to a load other than what the inverter is supplying.
Now this is good English
