Can you explain what you mean by Magamp. I am asking because I see a lot of confusion on this forum about what a magamp really is and what it really does. I worked as an industrial maintenance electronic tech for over 25 years and worked on several magamps. A magamp (magnetic amplifier) as used in industry is a special transformer that allows you to control a large current by using a very small current to control the saturation of the transformer. They will put out exactly the same kind of signal you put into one. They do not produce a sine wave unless the control current is a sine wave. And they do not produce any extra power. They are just like a water faucet that controls the flow of water. You have to supply the large current but it can be controlled by a small current.
I agree with you that there seems to be some confusion about how much power it takes to make this thing work. But a simple way to test this first would be to just use a transformer so that the connection to ground is isolated from the mains power. Then the biggest expense will be for all the ground rods and heavy wiring you need for the loop circuit. Then if it seems this system works you could always buy an inverter and battery. Or as someone has suggested if it doesn't take a lot of power a UPS might eliminate some of the extra expense and parts.
Carroll
Originally posted by kenssurplus
could be.
. Even paying all the taxes and insurance cost too much.
