Fast turn off
Hey Farmhand
Good run down on coil energy storing and inductance figures.
As you know I have been running coils in this location but no diode. Why didn't I think of that?
My coils are made of nickle chromium wire used in heating elements on clothes dryers. No real inductance, yet inductance should be part of this operation.
Glad you keep pointing these things out plus showing how this looks.
I am an oscilloscope quadriplegic. I can't show myself what's up yet. I have hooked a 1X probe across the collector and emitter on the MOSFET and I can get all kinds of things.
I can get the sawtooth dump.
I can dial it in to see nS and uS pulsing.
I will get better but in mean time YOU are there with the shots, good man.
I am thinking
that my inductance coil is going to have to be 12awg wire and about 500 feet. Ball park. "Probably"? I should put taps along the coil to change input speeds or whatever you call that.
Yeah I am thinking a big coil now for sure
Diode too.
Then this "CSR" current sensing resistor or some say "Load resistor or shunt resistor" I think this should be a coil also? If a coil is used a higher wattage low resistance value can be reached cheaply and energy is not wasted but stored.
Farmhand wrote:
This shot shows the circuit working at 400 Hz and pulsing the battery with 10 Amp rectangles of current for 260 uS, it's 400 Hz 10% duty, That really pumped up the battery.
Now you have my attention. I will be back to comment on this portion of your ability to pulse a battery with the drivers you show in the photograph.
I am getting excited now more than ever as I build my driver board.
It is so simple to make a board but knowing how to use these boards with diodes hooked to CSR and coil inductance's is way beyond.
I will have to repeat these ideas many times to the group as I remember them for myself.
You are leading the way Farmhand, great work.
Mike
I am thinking
that my inductance coil is going to have to be 12awg wire and about 500 feet. Ball park. "Probably"? I should put taps along the coil to change input speeds or whatever you call that.Yeah I am thinking a big coil now for sure
.Diode too.
Mike
