Is the Magnetic Field around a Wire Harvestable Free Energy?
  • My attempt at a schematic
    Still trying stuff,
    I wound 4 of the stitch" windings, added the collector brushes.
    Drawing a 3 volt load off the collectors , doesn't kill the supply.
    The supply goes down the same amount as without the load?
    • test runs
      Hi All, I did some runs, the load seems to actually reduce the draw on supply, or atleast stay the same?
      looking at a bunch more test's
      How can the light work ,and not draw anymore juice off the battery?
      The brushes are too wide, their causing shorts at the wrong times.
      I need some more motors so I can make some new , brush assemblies.
      In a normally wound motor , the coils are constantly shorting to the next segment?
      But you can draw a small load for free.
      shylo
      • Originally posted by shylo View Post
        shylo
        Can you get some video of the motor running with an amp meter and a volt meter across the supply battery and have you connect and disconnect the load? I would like to see that in action. If you can draw a sizable load for free, well, this won't be the first electric motor I've seen accomplish the task, but the first one with revolving magnetic fields.
        • Tests'
          Hi CMM, I've ran over 30 runs , the small load doesn't affect the supply voltage, ...It drops the same amount , with or without load,..that is the motor running ....draws power for a certain run .
          Add the light .... It doesn't draw anymore .
          The numbers are the same.
          I've ran with and without loads, with the light attached you get about 5-10 second longer run.
          AS for the video ,..well
          Art
          • My mistake
            During testing I realized that my winding wasn't correct. So I rewound it, tested it , it's giving better output . The other was about 3 volt load, this one is between 5-6 volts and run time is longer.
            Still drains the supply though ,just not as fast.
            • Shylo, I'm reading your posts, looking at your photos and can't help thinking about UFO's motors. I've built a few 3 and 5 pole setups. I'm inclined to go back to UFO's model and wind some new motors with series-wound bifilar coils. The output should be much higher at the genny side. Am I correct in seeing the similarities in what you're doing with UFO's motors?
              Bob
              • UFO's motors'
                Hi Bob , I 've been following the thread , but it is beyond me ,for now . I have only just started winding ,Matts' was my first try, then Peters'.
                Also I run mine using just single batteries and Daves' (Turion) system.
                In my run on Sunday I was pulling lots of watts for over three hours, the voltage did drop but nowhere near what it should have ,only 3 tenths of a volt ,that was running 2 headlights, Matts motor ,cordless screw driver ,and the lights were full brightness
                The funny thing is my motor would not run, the loads were just off the collector brushes.
                I don't like the way on the commutator ,the brush is in contact with 2 segments at almost all times.
                shylo
                • Thanks Shylo,
                  Sounds very interesting.
                  All the best.
                  Bob
                  • Energy from Fields
                    Hi All,
                    I like the topic for this thread.I mostly post on Donald Smith and Bedini devices but this thread attracted me.
                    I did and experiment an example of which is seen in this video.
                    Free Energy " One of a Kind Device " - YouTube
                    Free Energy Device ( the 3rd generation ) - YouTube
                    What was left for me to do was to make measurements.
                    An eyeopening pdf:
                    Donald Smith and others have spoken about energy been generated from fields from power lines.He said that if the power company claims you are taking power from them ,they are merely exposing their ignorance.Maybe the best thing they can they is that you are trespassing.Google fences or metallic objects in parallel to power lines should give you some good links.They say even oil pipes in parallel to power lines build up a charge and so they have to provide some form of earthing.Does that mean that the power company is losing money? I don't think so.
                    Sometimes my Tv use to pick up free cable from EM leaks from a nearby cable.Its free to me eh? Are they going to arrest me for that? Its the cable companies responsibility to keep their stray signals to themselves.
                    I do not think the power company misses any power because device.Its just that they got suspicious that someone had electricity ,was near their power lines and no genset was seen or heard.So they found a reason to get in and arrest users of such devices.A highly efficient resonant transformer should have not effect on the power lines at all.
                    • @Gedfire
                      Don't worry too much about the power companies and their archaic "everyone must pay" mentality. They will grow old and die and be remembered as the prehistoric dinosaurs they are. A new age will come of free decentralized energy for all and the stupidity they call reality will long be forgotten.
                      As Tesla once said ... "The present is theirs, the future, for which I really worked, is mine."
                      Disregard the power mongering buffoons we see today, they and their ways are not the future. Look forward, where do need to go, how do we get there, the present may be their's but the future is our's.
                      AC
                      • Power Capture Devices
                        Originally posted by Allcanadian View Post
                        @Gedfire
                        AC
                        lol! Nuff said!
                        • To that end
                          @Gedfire
                          AC
                          To that end we must work and not wait. We need to come up with a device that can be made by someone with an IQ of 80 and the awareness to say "that's not fair" when they see their power bill. Here is something I thought of yesterday when I thought of the M.E.G. and the bi-toroidal transformer at the same time. If someone with materials on hand would see if this could work that would be great if it does work and can be standardized with easy to get existing parts that would be excellent. The idea is that the control coil is the collector so you plug it in and it rebounds the power put in harder on the way out. Then just start finding people pissed off at the power company and start passing out plans and offers to teach and help then get them to pay it forward.
                          • PS
                            I realize that coil design would probably run like a 4 cylinder missing 2 spark plugs unless you bend it into a circle having the 2 free ends touch so half the driving load won't be drifting into an unused path. The driving load being one of the magnets on each half cycle. BUT I said simplest not best.
