  • Ufopolitics
  • Ufopolitics
    Originally posted by Listener192 View Post
    Hi UFO,
    My efforts so far are just to verify that the balanced sine current waveforms cancel flux linking, leaving only the flux cutting component.
    I have doubts that this will be the case but in deference to the project I thought I would give it the benefit of the doubt.
    L192
    But you could've check that by making Two Air Gaps between Three Separate Cores, separated by whatever thin insulation...no more " flux linking" there...right?
    It would still Induce friend...it's called "Spatial Induction"...
  • Ufopolitics
    Hi UFO,
    With your new waveform is this applied to two exciter coils N-N in antiphase, or just to a single exciter coil?
    You mention recovery to a capacitor, could you show a schematic of your setup?
    L192
  • Listener192
    New Signal
    Hi UFO,
    L192
  • Ufopolitics
    Coil to Cap Discharge Momentum...
    Hello to All,
    Below is a better view of the way brushes are positioned related to Slip Arc Segments, as I am showing BOTH Discharge Times in One Cycle from Coil to Cap
    And...
    Note that supply brushes are Off from supply arc, by the time Coil Brush is discharging to AC Cap on both positions...
  • Ufopolitics
    The Rise of Output Amperage...above Source.
    Hello Listener192 and All,
    The Figuera's Signal, which was actually assumed, based on the Interactions from the Patent Images, based on its graphics with commutator and Resistors...does NOT offers a Strong Induction on Secondaries which could render a Higher Amperage which would be ABOVE Input Amperage.
    Remember Figuera cited this Diagram with Comm and Resistors as an EXAMPLE for the Patenting purposes. And it DOES Generates an Induction on Secondaries...but...
    ...ONLY with an ABRUPT and RADICAL, Constant Magnetic Field Spiral Reversals, EFFECTED from Exciter to Secondaries Coils, will definitively "PUMP" a MUCH Higher Amperage than what we are Inputting through our Source.
    You can or can not believe me, or you could keep trying with the Original Assumed Signal...it is up to you...however, time will tell the final answer...
    Regards to All
  • Listener192
    D class Amplifier with PWM sine input
    Attached are some scope shots, showing the results of a resistive load and an inductive load.
    As you can the sine current is pretty good in both cases however there is a 10A offset in coil current. I need to think on this problem.
    Experimenting with a UPS filter took out one of my MOSFET's, my mistake as it effectively shorted the 31KHz pulses. I may have got away with this but I only had a temporary heatsink attached to the MOSFET mount rail, so I think they just cooked.
    So now need to get replacements.
    L192
  • Ufopolitics
    Hi UFO,
    As you are now generating AC, a simpler option may be to use a trailing edge dimmer, see attached.
    If you try to generate a square current waveform, now you are using AC on the coil, complete magnetic reset and reversal will mean that the full inductance of the coil will be seen, unlike the DC method. Your current wave shape will be closer to a sawtooth.
    With a trailing edge dimmer, the leading edge will be a sine and your 135/45 degree waveform could be easily set. A variable tap transformer or variac could be used with the dimmer to control current amplitude.
    The only reason for using PWM, would be if you wanted to control the current amplitude while generating the square waveform from +& - DC rails.
    L192
    Thanks Listener192,
    I have seen, and own some Three Phase BLDC Motor Controllers...which I know work based on an "H Bridge", however this is a Basic Single Phase Signal (so far).
    You are right I have now an AC Signal, BUT, remember it is generated by DC, and so please note the Flat Line On Times
  • Listener192
    Trailing edge dimmer
    Hi UFO,
    L192
  • Listener192
    New Switching Waveform
    but it reduced its output whenever I added another positive switching to a second primary with a common ground (typical Figuera way)...And these testing results made me move into this new form of switching.
    The question to all Electronic developers here, like El Cheapo or Listener192...
    Hi UFO,
    Yes you could generate this waveform with an H bridge, just like a sine inverter with a + & - rail, except in this case you delay before switching the polarity via the second set of transistors in the bridge.
    L192
  • Listener192
    D class amplifier
    It took a little time but I have one D class amp built. Its based on the NCP5106 Dual MOSFET driver, which allows the use on N channel devices.
    It also provides the shoot through prevention. I am using 2 x 600V 53A MOSFET's. This driver is one I gave up on several years ago as MOSFET failure takes the driver out every time. In this case the application is fairly benign.
    This one takes its PWM from the arduino, after TTL to CMOS 15V signal conversion.
    I did some testing with square waves (no PWM) and it seems to drive a coil OK at 20A Pk-Pk.
    Once have a PWM sine feeding it I will see what the sine current distortion is like.
    Of course it could be driven with a PWM square wave, that would just control the amplitude of the square wave.
    L192
  • Ufopolitics
    The Switch Contacts and Rotating Brushes...
    Hello to All,
    In order to have a more solid, real idea...
    This is the Mechanical Way, I am achieving the previous Signal...:
    I have TWO CENTER OFFSET ROTATING BRUSHES shown, which are NOT Connected to absolutely nothingexact deal as we get in a Symmetrical Brushed Motor...where BEMF is controlling by Current being back-forward directed alternatively.
  • Ufopolitics
  • Listener192
    PWM Class D single rail amplifier
    I think that the attached Class D amplifier arrangement may provide the solution to a symmetrical sine. A commercial single rail D class amplifier could be used, just leave out the output capacitor that normally provides the DC isolation.
    Perhaps a cheap medium power amplifier with upgraded MOSFETs or even paralleled MOSFETs.
    One you would be feed with a zero degree sine and the other a 10 degree sine.
    Phase corrections could be easily applied to the sines to achieve perfect cancellation.
    L192
  • Listener192
    Load I & V single and twin primaries
    Hi UFO,
    Attached are scope shots of Load current (yellow) and voltage (blue)
    Single primary and twin primaries.
    Probe is a differential type on x 50. Scaling setting to read actual volts.
    L192
