  • Originally posted by Michael C View Post
    Well, My association goes to pieces coming together, 'jackpot' if you like. I'd say that it indicates confirmation of some sort, you have come to a conclusion which you are being confirmed about in it's correctness. The slot machine and your dislike of gamble indicates that your thought that is confirmed is a new way of seeing things that you have discovered and have been working with for some time, a new door that has opened and you are told to trust your intuition although the new thought might contradict some of your present beliefs.
    Would be interesting to know if this makes sense or if I'm just mirroring parts of my own thoughts at the moment
    came to the same conclusion ..... you hit it right on the nail
    about the gambling:
    Nature loves courage ( see etymology of Sura ) . You make the commitment and nature will respond to that commitment by removing impossible obstacles. Dream the impossible dream and the world will not grind you under, it will lift you up . This is the trick. This is what all these teachers and philosophers who really counted, who really touched the alchemical gold, this is what they understood. This is the shamanic dance in the waterfall. This is how magic is done. By hurling yourself into the abyss and discovering its a feather bed.
    Terence McKenna
    The 3,6,9 advice resonates strongly with me. I'd say that the little training I did as a kid was and is very helpful in coming closer to those insights.
    3 6 9 .... manifestation of 369 in a way
    Huey Lewis - Feeling Alright - YouTube
    the Training you had in your youth .... rewired your brain in a way ..... and until today you got the fruits of the hard work you put in
    I am by Nature a Dreamer ( know thyself ) ..... my brain as a kid has had quite a bit of training .... could spend hours staring at the ceiling when in all truth .... I was living the Adventure .... ( think Abed and Troy from the tv series Community ) ... my point is ... we had taken different path but the end result is through training your Right Brain has also been trained .... for our own growth
    • Huey Lewis and the News - Hip to be Square - YouTube
      The Emerald Tablets of Thoth Tablet 9
      Long, long ago, I cast off my body.
      Wandered I free
      through the vastness of ether,
      circled the angles
      that hold man in bondage
      Know ye, O man, ye are only a spirit.
      The body is nothing.
      The Soul is ALL.
      Let not your body be a fetter.
      Cast off the darkness and travel in Light.
      Cast off your body, O man, and be free,
      truly a Light that is ONE with the Light.
        Michael C , thank you , had you not posted .... the flow would not have taken me to Terence Mckenna's Quote ..... now it make sense
        .......... also called ANISOTROPY
        • a repost : http://www.energeticforum.com/psychi...tml#post212676
          related to anisotropy OutKast - Hey Ya! - YouTube
          Earth's magnetosphere behaves like a sieve
          These swirls were found at low, equatorial latitudes, where the magnetic fields were most closely aligned.
          These giant vortices are driven by a process known as the Kelvin–Helmholtz (KH) effect, which can occur anywhere in nature when two adjacent flows slip past each other at different speeds.
          Let's Delve Deeper Into the Kelvin–Helmholtz (KH) effect
          three key words to remember :
          asymmetry , Fractal and Chirality
          Kelvin–Helmholtz instability - Wikipedia, the free encyclopedia
          The Kelvin–Helmholtz instability (after Lord Kelvin and Hermann von Helmholtz) can occur when there is velocity shear in a single continuous fluid, or where there is a velocity difference across the interface between two fluids. An example is wind blowing over water: The instability manifests in waves on the water surface. More generally, clouds, the ocean, Saturn's bands, Jupiter's Red Spot, and the sun's corona show this instability.[1]
          The theory predicts the onset of instability and transition to turbulent flow in fluids of different densities moving at various speeds. Helmholtz studied the dynamics of two fluids of different densities when a small disturbance, such as a wave, was introduced at the boundary connecting the fluids .
          All is Analogy
          These vortices are driven by a process known as the Kelvin–Helmholtz (KH) effect, which can occur anywhere in nature when two adjacent flows slip past each other at different speeds ( ie Yin and Yang ) .
          one more info : the same principle ( the Kelvin–Helmholtz (KH) effect ) is Encountered in : Rodin Coil
          from: The Rodin Coil and some description of what its about
          The Yin-Yang symbol presents some of the most fundamental concepts in Daoist and Tantric logic, philosophy, and spirituality. The most prominent concept is polarization: the division and union of two halves. Each half can in turn be polarized, giving some insight into recursion and forming the base for synthesis. The Yin-Yang is not a symbol of dualism but a statement of transcendence into monism, a snapshot of change.
          Scorpions Still Loving You with lyrics! - YouTube
          • Scorpions Still Loving You with lyrics! - YouTube
            History of surfing - Wikipedia, the free encyclopedia
            The riding of waves has likely existed since humans began swimming in the ocean. In this sense, bodysurfing is the oldest type of wave-catching. Standing up on what is now called a surfboard is a relatively recent innovation developed by the Polynesians. The influences for modern surfing can be directly traced to the surfers of pre-contact Hawaii.[citation needed]
            Ancient Hawaii
            The Ancient Hawaiian people did not consider surfing a mere recreational activity, hobby, extreme sport, or career as it is viewed today. Rather, the Hawaiian people integrated surfing into their culture and made surfing more of an art than anything else.[citation needed] They referred to this art as heʻe nalu which translates into English as “wave sliding.” The art began before entering the mysterious ocean ( YOURSELF ) as the Hawaiians prayed to the gods for protection and strength to undertake the powerful mystifying ocean
            Pablo Cruise | Zero to Sixty in Five - YouTube
            • I am by Nature a Dreamer ( know thyself )
              For as long as I can remember, I've been playing a 'movie' in my mind, an alternative reality if you like, or a virtual world just like a computer game where I write and control the story board. A 'Wayne's world' story but where 'Wayne' knows and decides what will happen next. When I was 7 I projected that me and my friends had cars and drove around in them.
              Today I still do this, which is a way of getting most out of one of my special technical interests or hobbies.
              I realize that in this reality, I have done much training in the #3 and #6 advice,
              3. Become acquainted with every art.
              6. Develop intuitive judgement and understanding for everything.
              and have been able to move this knowledge into the physical reality. Since some time, I've been thinking about starting an own business in my profession instead of being employed, but there's the thing about money, and hesitating to take the step into the abyss... However, while thinking about this I have discovered that I can 'predict the future', my business ideas will be 'just in time' within one year and other people will pick some of them up and realize them within two years, as novelties and have great success. I use the same technique to visualize these business opportunities as the alternative reality is created.
              Then I realize that the same method is behind my success as an employee, it has taken me all the way through my career, which is entirely based on good results, although I'm in a place today where my formal qualifications never would have taken me. Actually, I'm not even formally qualified to do even the simplest task at my employer today. But one of my duties is to train others how to do their work.
              And then I realize that my last lesson to learn completely, not just intellectually, is the 9:
              9. Do nothing which is of no use
              The ability to create another reality is a gift, and everyone can do it. The real key is to understand that it is as real as our physical world, and that they can be joined together, with attention to what parts that can interact and not based on what we really want and not. The real challenge, at least for me so far, is to eliminate the 'fantasy' judgement and start creating things that relate more directly to the physical reality I wish to experience, not things that will be isolated behind the veil of fantasy. Even the 'impossible' will try to break through, yesterday a friend described a vision he had in his professional work that was directly relating to my ongoing 'impossible fantasy project', it would be a manifestation of what I'm working with myself, in another dimension. The only difference was that he was in charge, I just had the idea before him. It is in my control to put myself in charge instead, and that is lesson #9: Do nothing which is of no use. Use that dimension to manifest things of use.
              I'm working on it
              “Nature loves courage ( see etymology of Sura ) . You make the commitment and nature will respond to that commitment by removing impossible obstacles. Dream the impossible dream and the world will not grind you under, it will lift you up . This is the trick. This is what all these teachers and philosophers who really counted, who really touched the alchemical gold, this is what they understood. This is the shamanic dance in the waterfall. This is how magic is done. By hurling yourself into the abyss and discovering its a feather bed.”
              ― Terence McKenna
              • from: http://www.energeticforum.com/psychi...ntenna-63.html
                The Rolling Stones: You Can't Always Get What You Want - YouTube
                I saw her today at the reception
                A glass of wine in her hand
                I knew she was gonna meet her connection
                At her feet was a footloose man
                You can't always get what you want
                But if you try sometimes well you might find
                You get what you need
                And I went down to the demonstration
                To get my fair share of abuse
                Singing, "We're gonna vent our frustration
                If we don't we're gonna blow a 50-amp fuse"
                But if you try sometimes well you just might find
                I went down to the Chelsea drugstore
                To get your prescription filled
                I was standing in line with Mr. Jimmy
                And man, did he look pretty ill
                We decided that we would have a soda
                My favorite flavor, cherry red
                I sung my song to Mr. Jimmy
                Yeah, and he said one word to me, and that was "dead"
                I said to him
                But if you try sometimes you just might find
                You get what you need--yeah, oh baby
                In her glass was a bleeding man
                She was practiced at the art of deception
                Well I could tell by her blood-stained hands
                You just might find
                You just might find
                • Comment
                  • History of surfing - Wikipedia, the free encyclopedia
                    What verse in the bible says this:? - Yahoo! Answers
                    Matthew 7:7: Ask, and it will be given you; seek, and you will find; knock, and it will be opened to you. For every one who asks receives, and he who seeks finds, and to him who knocks it will be opened. Or what man of you, if his son asks him for bread, will give him a stone? Or if he asks for a fish, will give him a serpent? If you then, who are evil, know how to give good gifts to your children, how much more will your Father who is in heaven give good things to those who ask him!
                    you know ... until the age of 17 , I used to go bodyboarding almost everyday .... I can tell you taht when you are riding a wave .... the sensation is almost like making love ..... almost mystifying ..... learning how to read the wave .... when is going to be the next series of wave .... being one with the Ocean ..... As Without so Within
                    now .... with Fukushima / BP oil spill and all .... unless you want to experiment with the oceans water to make a battery ........i am not too thrilled about it
                    Soul Surfer - Wikipedia, the free encyclopedia
                    Soul Surfer is a term coined in the 1960s, used to describe a surfer who surfs for the sheer pleasure of surfing. Although they may still enter in competitions, winning is not the soul surfer's main motive, since they scorn the commercialization of surfing.[1] The term denotes a spirituality of surfing. As Brad Melekian put it in a 2005 article in Surfer magazine:
                    “...to pursue surfing not just as an athletic endeavor or as a sunny day diversion, but to try to glean whatever lessons you can from the practice. It means being aware of your surroundings, and respectful of the people and places that you interact with. It means being patient, mindful, kind, compassionate, understanding, active, thoughtful, faithful, hopeful, gracious, disciplined and…good.” [2]
                    Sun Angel Creations - Law of Attraction Secrets - NumberQuest Numerology - NQ-Multi Numerology Calculator - Calculate Pythagorean, Chaldean, Kabbalah and Gematria Numerology Numbers! :: 123 Free Numerology Reports! :: Unlimited Free Numerology Name,
                    • Earth's magnetosphere behaves like a sieve
                      Large sunspot producing solar flares, brings chance of geomagnetic storms - National Environmental News | Examiner.com
                      A large sunspot on our sun, AR1618 continues to produce M-class flares and has recently sent a pair of coronal mass ejections that are headed toward Earth and expected to impact the planet's magnetic field into this weekend. AR1618 is very large and continues to grow, estimated at about ten times wider than Earth and facing the planet.
                      NOAA forecasters give this sunspot a 70% chance of producing additional M-class flares in the next two days and a 30% chance of an X-class flare.
                      View slideshow: Sunspot AR1618
                      The latest eruptions are expected to produce geomagnetic storms in polar latitudes this weekend and sky-watchers should be alert for auroras. It is not known at this time if any auroras would make it into the mid-latitudes.
                      Solar flares online — November 24, 2012
                      Solar flares today
                      Today, 1 solar flare was observed:
                      Active region Begin, UT Max, UT End, UT
                      Flare of class C3.3 1618 13:33:00 13:40:00 13:44:00
                      The Clapping Song Mash-Up Video - YouTube
                      love this vid ..... it has vintage "Babes" in it
                      now i get it .... why i resonate strongly to vintage women / inventor / artist / Art Deco etc ... the precursor of Rock and Roll .... The Feminine Energy ( see Louis Rota )
                      and I think it is being reborn so to speak .... what you saw MichaelC .... " Shin with 4 Branches"
                      If there are any Female reader ..... how was your Mood Cycle lately .... since June 6 2012 or just more recently .... this week ....
                      • FULCANELLI-The Cyclic Cross of Hendaye « eye of the cyclone
                        On the transverse arm of the cross-a Greek cross-is found the following inscription, consisting of two strange parallel lines of raised letters, forming words almost running into each other, in the same order as I give here:
                        OCRUXAVES
                        PESUNICA
                        • The name Saraswati comes from saras (meaning "flow") and wati (meaning "she who has flow").
                          • If you are up to it ... and don't mind practicing what you have learned ( mostly the method )
                            2 links to help you .... find 13
                            http://en.wikipedia.org/wiki/Saturn_(mythology)
                            In ancient Roman religion and myth, Saturn (Latin: Saturnus) was a god of agriculture, liberation, and time. His reign was depicted as a Golden Age of abundance and peace. He was thus a god of wealth, and the Temple of Saturn in the Roman Forum housed the state treasury. In December, he was celebrated at what is perhaps the most famous of the Roman festivals, the Saturnalia, a time of feasting, role reversals, free speech, gift-giving and revelry. Saturn the planet and Saturday are both named after the god.
                            hint: one of them is a geographical spot
                            Saturn is the sixth planet from the Sun and the second largest planet in the Solar System, after Jupiter. Named after the Roman god Saturn, its astronomical symbol (♄) represents the god's sickle ( 13 ).
                            http://en.wikipedia.org/wiki/Dragon_Storm_(astronomy)
                            Dragon Storm (dubbed so in September 2004 because of its unusual shape) is a large, bright and complex convective storm in Saturn's southern hemisphere. The Saturnian storm appears to be long-lived and periodically flares up to produce dramatic white plumes which then subside. The storm is a strong source of radio emissions
                            SATURN = SATUR NOS
                            satur - Wiktionary
                            Verb
                            satur
                            to jump
                            [edit]
                            Latin
                            [edit]
                            Adjective
                            satur m (feminine satura, neuter saturum); first/second declension
                            full, sated
                            well-fed, replete
                            saturated
                            NOS : AARK ROOTS
                            • sometimes ATS posts some interesting comments .... .... which seem to reflect a trend ( awave if you prefer ) , i noticed evolving for the past few years ' say a couple ) ... from my perspective ....
                              in a dual world ..... the poles tend to separate overtime ( see walter russell work ) ...
                              Yeah, sure, I'd like a girlfriend. Just like i'd like a Lamborghini., page 1
                              How come women always wanna take it slow with YOU, the "nice guy", but always end up cheating on the nice guy with some jerk. They always whine and moan about these jerks and wonder where the nice guys are, but the thing is, they've destroyed the nice guys because we've all become jerks because that's what they want. Oh, and they always sleep with these jerks, usually on first dates. But they wanna take it slow with you, right? And I'm the bad guy because I want to get laid, after you went and wound me up telling me about how much you want to sleep with me, right?
                              from experience .... I've seen many take the short cut ... and usually end up regretting it .... for both sides
                              ps: it is very likely that the female of the above story is not quite satisfied with her vagina ( see designer Vagina ) ..... applicable also to Male Poles ..... pun intended ..... Pole Designer exist too
                              New study finds clients want real love from sex workers
                              While it is commonly believed that men who pay for sex are attempting to avoid emotional commitment, a new study finds that men who become regular clients of sex workers often develop feelings of romance and love. This study is published in a recent edition of Men and Masculinities.
                              makes sense
                              • Ohh... this revealed a lot of information, although I'm not sure what it means.
                                The obvious:
                                Then Saturn, Chronos, 13. But our chronometers only goes to 12.
                                Then I remembered a fact about Ley lines, they carry both polarities but shift dominant polarity every 57 minutes circa, according to some sources. So 57 minutes or there about would be the "correct" length of 1 hour, if 1 hour had anything to do with nature. 1440 (HM9) is the number of minutes in one full calendar day, and divided by 25 we get 57,6 minutes per hour. The hourly cycles in one day is 25. We could pull down the length of seconds too but it is not necessary, 57,6 is one earth hour (right now) and keeping it so makes us correctly timed.
                                I'm not sure where this will lead, I just recieved these thoughts.
