  • Study shows training improves recognition of quickly presented objects
    So far it has seemed an irreparable limitation of human perception that we strain to perceive things in the very rapid succession of, say, less than half a second. Psychologists call this deficit "attentional blink." We'll notice that first car spinning out in our path, but maybe not register the one immediately beyond it. It turns out, we can learn to do better after all. In a new study researchers now based at Brown University overcame the blink with just a little bit of training that was never been tried before.
    "Attention is a very important component of visual perception," said Takeo Watanabe, a professor in Brown's Department of Cognitive, Linguistic and Psychological Sciences. "One of the best ways to enhance our visual ability is to improve our attentional function."
    Watanabe and his team were at Boston University when they performed experiments described in a paper published the week of July 9 in the Proceedings of the National Academy of Sciences. The bottom line of the research is that making the second target object a distinct color is enough to train people to switch their attention more quickly than they could before. After that, they can perceive a second target object presented as quickly as a fifth of a second later, even when it isn't distinctly colored.
    Signs and symbols -Confucius.
    • continuing our exploration :
      Before It's News
      The ‪Secret Life of Plants‬: Scientific Proof Plants are Telepathic and Have Emotions
      Here is an absolutely amazing discover that somehow has been over looked in society, a botanist named Cleve Baxter started doing testing on plants and other microorganisms using a polygraph (a lie detector for those who don't know), and discovered that plants actually have feelings.
      Here is a super old video I found in which Leonard Nimoy hosts a documentary from the late 60's or early 70's about Baxter doing these experiments.
      Here is another interesting fact, at one part soviet scientists have people walk into a room with two plants, one connected to a polygraph the other is not. One of them is instructed to destroy one of the plans and when they do the plant hooked to the machine starts to produce large "thought activity." Then slowly each person walks into the room and when the one who ruined the plant walks in, the plant connected to the polygraph recognizes the person and starts to produce activity.
      more in the link provided
      what do you see
      and
      to my eyes they are one and the same
      Water has Memory - YouTube
      • Shaking all over: Map of every major earthquake since 1898 reveals stunning image of planet's danger zones | Mail Online
        If you are looking for somewhere safe from an earthquake, this might help.
        For this map shows the where every major quake has struck since 1898, and as you can see, the edge of the Pacific Ocean appears particularly dangerous. In total there are a staggering 203,186 of them, dotted all over the world.
        originally found : Before It's News
        • info update :
          Physics team proposes a way to create an actual space-time crystal
          (Phys.org) -- Earlier this year, theoretical physicists Frank Wilczek, of MIT put forth an idea that intrigued the research community. He suggested that it should be possible to construct a so called space-time crystal by adding a fourth dimension, movement in time, to the structure of a crystal, causing it to become an infinitely running clock of sorts. At the time, Wilczek acknowledged that his ideas on how to do so were inelegant, to say the least. Now another international team led by Tongcang Li has proposed a way to achieve what Wilczek proposed using a far more elegant process. They have posted a paper on the preprint server arXiv describing what they believe is a real-world process for creating an actual space-time crystal that could conceivably be carried out in just the next few years.
          Wilczek thought that it should be possible to construct a space-time crystal because crystals naturally align themselves at low temperatures and because superconductors also operate at very low temperatures; it seemed reasonable to assume that the atoms in such a crystal could conceivably move or rotate and then return to their natural state naturally, continually, as crystals are wont to do as they seek a lowest energy state. He envisioned a rotation with a ring of ions that flowed separately rather than as a stream, likening it to a mouse running around inside of a snake laying as a circle.
          They believe that if ions could be forced using such a trap, into a ring at very low temperatures, as a superconductor, all that would be needed would be a little nudge from a tiny bit of a magnetic field to cause the ions to begin rotating as a single ring. Because there would be no resistance, and because of their natural mutual repulsion, the ring should then continue rotating indefinitely with no additional injection of energy, resulting in the space-time crystal that Wilczek imagined.
          Scientists create 'MRI' of the Sun's interior plasma motions
          A team of scientists has created an "MRI" of the Sun's interior plasma motions, shedding light on how it transfers heat from its deep interior to its surface. The result, which appears in the journal the Proceedings of the National Academy of Sciences, upends our understanding of how heat is transported outwards by the Sun and challenges existing explanations of the formation of sunspots and magnetic field generation.
          add to them the following pattern :
          Pier Ighina's Cosmic Energy Inventions - The Tesla / Reich / Keely of Italy - English Subtitles - YouTube
          • Originally posted by llynch View Post
            After consuming the majority of McClain's work, it appears to that there are 3main processes that are occuring, Multiplication, Transition, Reduction. That also occur in 3 octaves each using a different scale that allows one to 'see' the operations via ratios. Really cool stuff. Well worth the read.
            Depending on your perspective these can also be viewed as
            Multiplication = Expanded = North Pole
            Transition = Neutral
            Reduction = South Pole
            painting by Walter Russell
            the same can be said of the sacred books:
            for instance the Koran has :
            Medinan sura - Wikipedia, the free encyclopedia
            The Medinan suras or Medinan chapters of the Qur'an are those later suras which, according to Islamic tradition, were revealed at Medina, after Muhammad's hijra from Mecca. These suras appeared when the Muslims were in larger numbers, rather than being an oppressed minority as in Mecca.[1]
            Meccan sura - Wikipedia, the free encyclopedia
            The Meccan suras are the chronologically earlier suras of the Qur'an that were, according to Islamic tradition, revealed anytime before the Hijrah (pilgrimage of the Prophet Muhammed from Makkah to Medina). The other type of sura is the Madinan sura.
            Meccan suras are typically shorter, with relatively short ayat, and mostly come near the end of the Qur'an. Most of the suras containing Muqatta'at are Makki. A detail characteristics of Makki and Madani Sura can be found here.[1]
            The division of surahs into 'Meccan surahs' and 'Medinan surahs' is primarily a consequence of stylistic and thematic considerations. Classification of the surahs into these periods is based upon factors such as the length of the verse and the presence or absence of certain key concepts or word (e.g. al-Rahman as name of God).[2]
            ----------- Ernest McClain - Musical Adventures in Ancient Mythology
            March 2010
            The author's third book, MEDITATIONS ON THE QURAN, published in 1981, is scanned here for easy downloading by interested students but the copyright restriction is still affirmed for publication. Notice, however, that a new Appendix II titled "Abraham's Children" makes very important corrections to errors made thirty years ago regarding YHWH as the "One" God of monotheism (on pp. 131, 134, and 137), and of the "chief cornerstone" on pp. 147-8, and also of the meaning of "first-born sons" (p. 151). More recent translations and publications of cuneiform mathematics now make clear that I misunderstood the greater "Marduk-Baal" matrix for "Noah's flood" as YHWH's own, and overlooked the cornerstone "unit" as eventual "Savior," and misunderstood Jacob's twelve sons as "male, odd integers" less than his death at age 147. The entire problem of ancient Egyptian and Mesopotamian mathematics is now undergoing serious reconsideration within the mathematical community, and all speculation like mine must be considered tentative perhaps for further generations. [PDF]
            • cho ku rei + Healing Symbol of Mary
              Meditate on it ....
              still needs to be perfected .....
              made a drawing mixing / mashing up two powerful designs ... the result is quite inspiring ....
              can't show you as it is drawn by hand .... but the two designs are as follow :
              at its center : drawn inside
              would really like someone extra sensitive to reproduce it and give us a feedback on it .... i sense it is powerful but not as well as someone more experienced ....
              ps: Mary's fig is 1.4.10
              Sydera .... if you are reading this .... you up for it
              • An interesting Discover .... fits right in our discussion :
                L-Field - Wikipedia, the free encyclopedia
                The L-field is a name proposed by the Yale Professor of Anatomy Harold Saxton Burr[1] for the electromagnetic field of any organism. Burr held that the study of this field offered great promise for medicine since it exhibited measurable qualities that might be used in prognosis of disease, mood and viability. The voltage measurements he used are not in doubt, but his conclusions are at odds with mainstream biology, and have not generally been accepted by the scientific community.
                Those having produced notable research along the same lines include Becker, Marino and Selden,[2] Lund[3] and Athenstaedt.[4] Progress has also been made in the use of electromagnets to aid the healing of broken bones.[5]
                Details
                Beginning in the 1930s H.S. Burr's seminal work at Yale aimed at a gradual accumulation of hard data to support the hypothesis of the bio-electric field as having emergent, unexplained qualities and acting as a causal agent in development, healing, mood and health. Burr set up a series of experiments, later repeated by other researchers, which demonstrated some properties of these EM fields which he called Life-fields (L-fields).
                He showed that changes in the electrical potential of the L-field were associated with changes in the health of the organism. By leaving some trees hooked up to his L-field detectors for decades he found correlations between such things as the phases of the moon, sunspot activity, thunderstorms and readings from the trees.[6] He found that the axis of EM polarity in a frog's egg could predict the spinal axis of foetal development, which he interpreted as suggesting that the L-field was the organizing matrix for the body. His insistence that the L-field has primacy over the physical aspects of the organism eventually resulted in Burr being accused[by whom?] of "wishful vitalism".
                In his work with humans, he wrote papers detailing his successes in charting and predicting the ovulation cycles of women, locating internal scar tissue, and diagnosing potential physical ailments through the reading of the individual's L-field. As there was little interest in Burr's work, few other scientists even attempted to duplicate Burr's results.
                Student and colleague Leonard Ravitz carried Burr's work forward. Ravitz focused on the human dimension, beginning with an investigation of the effects of the lunar cycle on the human L-field. He concluded that the human L-field reaches a peak of activity at the full moon. Through work with hypnosis he became convinced that changes in the L-field directly relate to changes in a person's mental and emotional states. "Both emotional activity and stimuli of any sort involve mobilization of electrical energy, as indicated on the galvanometer, hence, both emotions and stimuli evoke the same energy. Emotions can be equated with energy." Most intriguingly, Ravitz showed that the L-field as a whole disappears before physical death.[7]
                Fractal Antenna
                • as you explore new doors in the mind open
                  The Electrical Patterns of Life; The Work of Dr. Harold S. Burr : World Research Foundation
                  The Universe in which we find ourselves and from which we can not be separated is a place of Law and Order. It is not an accident, nor chaos. It is organized and maintained by an Electro-dynamic field capable of determining the position and movement of all charged particles. For nearly half a century, the logical consequences of this theory have been subjected to rigorously controlled conditions and met with no contradictions Dr. Harold S. Burr
                  Electro-dynamic fields are invisible and intangible; and it is hard to visualize themAnd if the filings are thrown away and fresh ones scattered on the card, the new filings will assume the same pattern as the old. Something like this happens in the human body. Its molecules and cells are constantly being torn apart and rebuilt with fresh material from the food we eat. But, thanks to the controlling L-fields, the new molecules and cells are rebuilt as before and arrange themselves in the same pattern as the old ones.
                  If you let your Monkey play a bit ..... ask yourself te following .... what if one achieves control over that L field ... he / she can have the new filings assume any Pattern they wish
                  for instance :
                  Tszyan KAN'CHZHEN: Microwave Transfer of Biological Information
                  Tszyan Kanchgen has lead a series of experiments, which have shown an opportunity of direct transfer of the information from one biological object to another by radio waves [45]. Tszyan Kanchgen has created installation [46], including hollow correct of polyhedron and hollow cones located on its sides. The biological object which is carrying out influence is located in a cavity of polyhedron, its the radiations amplify and are transferred to other alive object by microwaves.
                  In experiments with cereal cultures Tszyan Kanchgen placed in the installation green weight of wheat and influenced by radio waves on germinate sabadillas of corn. The "processed" corn had set of lateral stalks. On the place of panicle the original ears with grains similar and on corn, and on wheaten (fig. 26) were formed. The acquired new qualities were steadily transferred to the subsequent generations.
                  more on this:
                  Tszyan Kanchzhen
                  • The biological object which is carrying out influence is located in a cavity of polyhedron, its the radiations amplify and are transferred to other alive object by microwaves.
                    see also http://www.energeticforum.com/200373-post2501.html
                    SVP Universal Cosmology - Part 3 of 17 - Polarity Manifests as Rotating Vortex
                    3.4 - Power Accumulation - Each of the lines represents a center line or line of attraction around which will aggregate the particles. The lines centralize together meaning proportional increase of attraction as they approximate each other. Which results in greater attraction in the center and less attraction at the periphery.
                    Up-down = Longitudinal Waves
                    East-West = Rayleigh Waves
                    North-South = Transverse Waves
                    Figure 3.8 - Celestial Seeks and Condenses at Center
                    let's see how they resonate together
                    we won't go over granite / quartz / mica etc ....
                    • just reposting two old info :
                      from: http://www.energeticforum.com/renewa...llector-3.html
                      Trees talk in w-waves
                      Trees Talk In W-waves
                      "Grants Pass, Ore. (AP) - Physicist Ed Wagner says he has found evidence that trees talk to each other in a language he calls W-waves.
                      "If you chop into a tree, you can see that adjacent trees put out an electrical pulse," said Wagner. "This indicates that they communicated directly."
                      "Explaining the phenomenon, Wagner pointed to a blip on a strip chart recording of the electrical pulse.
                      "It put out a tremendous cry of alarm," he said. "The adjacent trees put out smaller ones." .....
                      "People have known there was communication between trees for several years, but they've explained it by the chemicals trees produce," Wagner said.
                      "But I think the real communication is much quicker and more dramatic than that," he said. "These trees know within a few seconds what is happening. This is an automatic response."
                      "Wagner has measured the speed of W-waves at about 3 feet per second through the air.
                      "They travel much too slowly for electrical waves," he said. "They seem to be an altogether different entity. That's what makes them so intriguing. They don't seem to be electromagnetic waves at all."....
                      Comment. In addition to the above discovery, Wagner, who holds a PhD in physics from the University of Tennessee, has detected electrical standing waves in trees. The voltage measured by electrodes implanted in trees goes up and down as one goes higher and higher up the trees. Wagner's work has been published in Northwest Science, but we have not yet seen it. Incidentally, electricity does seem to affect plant growth, as described in our handbook: Incredible Life.
                      Seeing the forest through the trees
                      Imagine you are walking through a forest ( http://www.energeticforum.com/genera...n-society.html ). All around you are trees of different species, age, size and height. It looks pretty random, right? Wrong.
                      In research funded by the National Science Foundation, Brian Enquist of the department of ecology and evolutionary biology at the University of Arizona and his team have discovered a secret in the trees: Hidden among and within the architecture of the branches are fundamental rules that link the size, shape, age and in fact everything about a single tree to all the trees in a forest.
                      and if plants react to us at a distance it means that we too talk in a version of w-waves http://www.energeticforum.com/201009-post2556.html
                      • Healing Symbols
                        Meditate on it ....
                        I will give it a go MrM.
                        I have drawn them and recorded my initial responses to the shapes, will keep exploring and let you know...
                        • Originally posted by SYDERA View Post
                          Thank you Sydera ... much appreciated ......
                          • found the following article quite intriguing and interesting
                            Before It's News
                            THE SOLAR CLEANSE PROPHECY
                            except:
                            The sun is going to behave increasingly in a manner that is both unpredictable and unprecedented. We are going to see an increase in sunspot activity and consequential ejection of solar flares unlike we have experienced in known human memory. These flares shall impact our planet with such intensity that it will be impossible to ignore. They will light up the night. There will be a wide range of consequences, some of them being:
                            1. On aphysical level this will cause much discomfort and inconvenience to humanities assumption that it is in control. Our technology will be severely impacted. Our power grids will shut down, often for days, weeks or months. They may never be used again. Our near earth orbiting satellites will be damaged, or have to be shut down to prevent damage. There will be no way to communicate with them afterward. Communication systems like cell phones and the internet will experience complete disruption. The weather will also become increasingly and fiercely unpredictable.
                            Yes, these physical consequences are obvious to most of us. However, as we go deeper into the experience, they become less so.
                            2. On a mental level this solar activity causes confusion within our thought processes. It will become harder to "think straight", to communicate with each other clearly, and even to understand concepts that once appeared straight-forward. Linear-thinking will appear to fail us and logic to miss the mark. We will also experience drastic interference in our memory faculties (short and long term). Mentally, we will hallucinate.
                            4. On a vibrational level we may feel increasingly spiritually disconnected and polarized, or increasingly aware and connected, depending where our point of focus is anchored.
                            . some problems can be instinctively solved but logically unprovable
                            what caught my I ( or eye )
                            Before It's News
                            we are invited to embrace an even deeper awareness;
                            ps: the article is in 6 parts ... and remember always .... All Truth is Half Truth
                            • out of curiosity ... some of you already know this ... I don't
                              10 signs of soon labor - June 2012 Birth Club - BabyCenter
                              Signs of labor
                              As the day of birth approaches, you may notice some signs, which indicate that labor will happen soon.
                              1. Breathing becomes easier
                              As a result of baby downward movement, pressure on diaphragm and stomach is reduced. Breathing becomes easier. Heartburn may dissapear. Pressure on the lower abdomen increases. Sitting and walking become a little harder. After baby�s displacement down, a woman may have difficulty with sleeping, at this time it is difficult to find a comfortable position for sleep.
                              2. Changes in appetite
                              Before childbirth, your appetite may change. More often, appetite decreases. It is good, if a woman at that time has more trust in her instincts when choosing products. Do not eat �for two�.
                              3. Reduced body weight
                              Before childbirth a woman may lose some weight. Body weight of pregnant women can be reduced by about 1-2 kg. So the body is preparing for childbirth naturally. Before birth the body has to be flexible and ductile.
                              4. Belly descent
                              A woman may notice that her stomach moved down. Abdomen descent occurrs at the expense of lowering and insertion of fetal presenting part in pelvic entrance and discard of uterine bottom forward, due to a reduction in tone of abdominal press. A child begins to sink deeper in pelvic region. During first childbirth this sign is observed 2-4 weeks before delivery. During other labors - on the eve of birth.
                              5. Sudden change of mood
                              A woman looks forward to �her hour�. She can not wait to give birth. Her mood can suddenly change. Change of mood is largely linked to neuroendocrine processes in the organism of pregnant women before childbirth. Explosions of energy are also possible. A state of fatigue and inertia may be unexpectedly replaced by turbulent activity. There is a �nest� instinct. A woman is preparing to welcome a baby: she sews, cleans, washes, tidies. Please, just do not overdo.
                              6. Frequent urination and defecation
                              Urination becomes more frequent, as pressure on bladder increases. Hormones affect female intestine, causing so-called pre-clearance. Some women may experience slight cramps in the abdomen and diarrhea. Like before exams.
                              7. Pain at the bottom of back
                              After displacement of child down, a woman may experience uncomfortable sensations in back. These sensations are caused not only by pressure from a child, but also an increase of sacroiliac connective tissue tensile.
                              8. Changes in fetal motor activity
                              A kid can calm down slightly, then start moving actively. He is like choosing the rhythm and selecting the most appropriate time for his birthday.
                              9. Irregular uterine contractions
                              After the 30th week of pregnancy a woman may feel false labor. Tangible, but occasional uterine contractions in this preparational (preliminary) period are mistakenly taken for labor. A woman may feel some contractions a few weeks before childbirth. If a regular and continuous rhythm is not established, if spacing between labors is not reduced, they usually do not mean the beginning of childbirth.
                              10. There are three main signs of birth:
                              - Appearance of regular contractions in uterine muscle - contractions mean beginning of delivery. Since then, a woman is referred to as giving birth. Rhythmic contractions are felt like pressure on abdominal cavity. Uterus becomes heavy, pressure can be felt throughout abdomen. The importance of the trait is not in the fact of contraction, but in its rhythm. These labor pains must be repeated every 15-20 minutes (other frequency is also possible). Gradually, intervals are reduced: contractions repeat every 3-4 minutes. Between labors abdomen is relaxed. When abdomen is relaxed, you should try to relax.
                              - Vaginal cervical mucus - mucus plug. Mucous plug can move away 2 weeks before delivery, and perhaps - 3-4 days. This usually occurs after the beginning of uterine contractions for enlargement of cervical canal - thus mucous plug is moving away. Mucus plug keeps the channel closed during pregnancy. Loss of mucous plug - a certain sign of birth. One can notice colorless, yellowish or light red discharge.
                              - Release of water. Fetal bladder can leak, then waters flow slowly. It can break suddenly, then waters will �gush�. From time to time this happens before rhythmic uterine contractions begin. More often it occurs during second delivery. When fetal bladder is broken, one does not feel pain. When waters retreated immediately, before the onset of rhythmic labors - one should urgently go to maternity house!
                              All is Analogy
                              • Nikola Tesla - Wikiquote
                                by Nikola Tesla
                                When a child is born its sense-organs are brought in contact with the outer world. The waves of sound, heat, and light beat upon its feeble body, its sensitive nerve-fibres quiver, the muscles contract and relax in obedience: a gasp, a breath, and in this act a marvelous little engine, of inconceivable delicacy and complexity of construction, unlike any on earth, is hitched to the wheel-work of the Universe
                                Inspired to this task he searches, discovers and invents, designs and constructs, and covers with monuments of beauty, grandeur and awe, the star of his birth. He descends into the bowels of the globe to bring forth its hidden treasures and to unlock its immense imprisoned energies for his use. He invades the dark depths of the ocean and the azure regions of the sky. He peers in the innermost nooks and recesses of molecular structure and lays bare to his gaze worlds infinitely remote. He subdues and puts to his service the fierce, devastating spark of Prometheus, the titanic forces of the waterfall, the wind and the tide. He tames the thundering bolt of Jove and annihilates time and space. He makes the great Sun itself his obedient toiling slave. Such is his power and might that the heavens reverberate and the whole earth trembles by the mere sound of his voice.
                                To create and to annihilate material substance, cause it to aggregate in forms according to his desire, would be the supreme manifestation of the power of Man's mind, his most complete triumph over the physical world...
                                What has the future in store for this strange being, born of a breath, of perishable tissue, yet Immortal, with his powers fearful and Divine? What magic will be wrought by him in the end? What is to be his greatest deed, his crowning achievement?
                                Long ago he recognized that all perceptible matter comes from a primary substance, or a tenuity beyond conception, filling all space, the Akasha or luminiferous ether, which is acted upon by the life-giving Prana or Creative Force, calling into existence, in never ending cycles, all things and phenomena. The primary substance, thrown into infinitesimal whirls of prodigious velocity, becomes gross matter; the force subsiding, the motion ceases and matter disappears, reverting to the primary substance.
                                Can man control this grandest, most awe-inspiring of all processes in nature? Can he harness her inexhaustible energies to perform all their functions at his bidding? more still cause them to operate simply by the force of his will?
                                If he could do this, he would have powers almost unlimited and supernatural. At his command, with but a slight effort on his part, old worlds would disappear and new ones of his planning would spring into being. He could fix, solidify and preserve the ethereal shapes of his imagining, the fleeting visions of his dreams. He could express all the creations of his mind on any scale, in forms concrete and imperishable. He could alter the size of this planet, control its seasons, guide it along any path he might choose through the depths of the Universe. He could cause planets to collide and produce his suns and stars, his heat and light. He could originate and develop life in all its infinite forms.
                                To create and to annihilate material substance, cause it to aggregate in forms according to his desire, would be the supreme manifestation of the power of Man's mind, his most complete triumph over the physical world, his crowning achievement, which would place him beside his Creator, make him fulfill his Ultimate Destiny.
