Originally posted by dllabarre
Originally posted by dllabarre View Post"Tesla matched the total weight of the primary and secondary windings so the two would be in a state of resonance."
So if I take it one step further and factor in 1/4 wave length I have:
6 awg 79.65 lbs/1000 feet
12 awg 19.8 lbs/1000 feet
If I use 12 awg for secondary at 4 times length of primary = 19.8 x 4 = 79.2 lbs
The total weight is the same and I create a 1/4 wave length effect.
All in resonance.
Comments anyone?
So the reversed coils (primary and secondary) can be exactly calculated for resonance and input and output(wire thickness,voltage,amps) needs?
Best Regards
Diodes
@ Cognito
What happens when diodes are used to charge the caps on double frequency?
Well these diodes should be there anyway (in flybacks they are fixed), but i forgot to draw them in, sorry about that.
I have corrected the drawings
But as we need pulsed DC, we need them, but it will not make any difference here.
Regards Itsu
I'm wondering if anyone can recommend the actual diode types we want for the NST output/s and for the HV FWBR ?
I'm thinking these microwave diodes for the NST output.
4pcs HVM12 Microwave Oven High Voltage Diode Rectifier | eBay
And something like these for the HV FWBR 100ns 10 Kv 1 Amp
1A 10kV High Voltage Diode HV Rectifier, Tesla coil Ham | eBay
Seems to be truckloads of cheap HV diodes to buy. Or boat loads maybe.
Originally posted by zilanonow we lower frequency
if we desire frequency 120 cps(60 up and 60 down)
then R =T/C
=120/.008
=15000 ohms
=15 Kohm(15 kilo ohm) wattage to be calculated by finding voltage and amperes. Since P=VxI
Originally posted by Farmhand View PostI'm wondering if anyone can recommend the actual diode types we want for the NST output/s and for the HV FWBR ?
Some microwave diodes are good to 15kv but will only handle .75 amp which might be fine depending on what your using them for. Look at some of the Vishay diodes for a fast recovery time and high amperage/voltage as well. I think the 5408's are good for a couple Mhz where some of the Vishay's will run much higher frequencies if needed.
I set them up inside a PVC tube, easy to drill wire and solder and it makes them fairly compact.Last edited by dragon; 09-22-2011, 01:31 AM.
Thanks Dragon very good tip. I'm out of almost all 3 amp diodes. I'll get some.
Anyway here is my crazy idea to replace a neon sign transformer, this way everything is repairable and replaceable, this is only a rough sketch the circuitry involved will need to be a bit more complex of course. I think to have the ignition coils do half frequency each wired in parallel. With voltage pulse width and frequency variable to them to manipulate the input voltage and current to the main primary circuit.
Uploaded with ImageShack.us
I think if each coil can throughput 1 amp it is still only low input power though maybe too low. Dunno.
I'm thinking about doing this.
Originally posted by zilano@ all
Fantastic high voltage meter or probe to solve complicated repair problems
Using High Voltage Meter or Probe
RF measurements
http://www.lessemf.com/rf.html
Interesting RF meters you posted!
I see those meters have a minimum frequency range starting at 10MHz and up to GHz.
Will you give a hint what the frequency is of your coils?
Don always said that we need to start at the required output power needed. It depends on the storage capacitor value and we calculate the frequency needed to maintain the wattage. Calculations are from output to input stage.
Best Regards
Originally posted by Farmhand View PostThanks Dragon very good tip. I'm out of almost all 3 amp diodes. I'll get some.
If you set it up like tesla's patent 609,250 with the cap and coil it will use less input energy also. His simple ignition circuit reveals a considerable amount of knowledge....Last edited by dragon; 09-22-2011, 02:55 PM.
@ all,
Has someone a better picture quality of this system made by Don?
Best RegardsAttached Files
RF measurements
When will you be selling your design plans and specifications for the 10kw home unit?
Cheers Mike
Originally posted by zilanoDrak!
make dc and filter ie hvdc and pulse with Hvdc in series with spark gap to a coil and cap having frequency 60 hz(aircoil) and feed the two terminals of the coil to ur ironcore trafo.
How high of DC voltage are we talking? 120v or 1000v or 10000v? Well, it would at least have to be over 350 volts or it won't spark, I'll try 1,200 that way I can test with a basic 10:1 transformer I have lying around here.Last edited by drak; 09-22-2011, 10:02 PM.
