Motor Generators
  • BroMikey, good analysis of events.
    https://figueragenerator.wordpress.com/history/
    Missed one part of Figer and his mechanic made a working model. Just a patent, without a working prayer, no one will buy it. In the material I am trying to show the essence of the invention, and the option of repetition in the USA.
    https://overunity.com/19069/holcomb-...186872/image//
    In the scheme of the patent "Fieger's Generator" - "y" denotes a phase or secondary winding. But nowhere is its design disclosed. In the variant of mutual induction, the coil wound on the core cannot work with the result of overunity.
    There are other applications, but not implemented.
    https://patentimages.storage.googlea...A2357550A1.pdf
    What is the difference between the secondary winding of the transformer and the phase of the generator? Why was the outer winding of the Gramme generator replaced with a generator winding in the stator slot? These are questions that have answers, and solutions used in these designs.
      https://figueragenerator.wordpress.c...iving-signals/
      https://figueragenerator.wordpress.c...267-year-1908/
      https://figueragenerator.files.wordpress.com/2016/01/patent-clemente-figuera-44267.pdf
      • Here's the link, I gave a detailed answer:
        https://overunity.com/19069/holcomb-...674/#msg566674
        https://overunity.com/19069/holcomb-...658/#msg566658
        This is so obvious that there is no need to prove it. The method needs to be sorted out. I'm trying to make a simple design.
        Well, the evolution of the formation of a delusion for public opinion about the design features of the Figuera generator.
        • Nice book. Do you have any detailed data showing your results? Or is the book all theory?
          Did you get it to work, is my question. There are many a essay of higher learning all around the web. I need more than words to understand. Who should I believe?
          All I see is a pretty picture.
          • Alum battery construction, Mikey strikes again
              The book is not finished yet, it is like a chronicle of my research from idea to design. I started it in 2019, I hope to finish it this year. The goal is not only a book, but an algorithm for calculating the design. Just when you invent something yourself, you begin to understand other inventions, including the designs of Clemente Figuera, and many others.
              Attached is the secret of the Figuera generator. On the example of a generator with four rotor poles.
              Everything lies in the correct calculation of the design. Like Figuera's first device, it could be connected to an external AC source, or a resistive controller.
                Great news on the book. Everything must be calculated and this picture looks like an induction motor on the market today. So far you haven't said anything that makes us see the difference. Algorithm is always used in math.
                We need a bench top lesson, not an idea that might be or might not work out to be correct after testing. On the book, how much do they generally run?
                Books are fun adventures of someone's opinion.
                • Just my hints to the fellow forum seeker. He is very close to solving the problem. I'm glad that he realized that the generator is a very bad motor, and the motor is a bad generator.
                  https://overunity.com/19069/holcomb-...719/#msg566719
                  Another seeker is developing a solid-state design. Everyone has problems precisely in the approach of calculating the generator, the generator circuit.
                  https://www.youtube.com/watch?v=i4qOE5XBbbk&t=31s
                    Just my hints
                    Calculations are nice for a working principle. I will ask you again because like all of the other seekers and yourself you avoid the question. Point us to a single video showing an extra 1000w output.
                    Math is fine and I am glad you can make the numbers crunch but where is a video proof?
                    No one has a single proof but you all continue to build the secret mystery painting.
                    Just 1 short video that is more than just wires pulsing coils
                    Surely someone can show OU, right? I guess not, no reply, ignore, avoid and sidestep.
                    This behavior of avoiding is cause for the bulzhit button to be pushed.
                    My time is valuable to me and a non response is wasteful. If I can't see one working then I won't be able to get it to work either. Show me
                    • Here is an example of an engineer who calculates AND shows you the result of what otherwise would only be considered speculation. Anything less is of little consequence.
                        I was asked a question in a PM on a friendly forum, I think my answer and comparison will be very interesting. Reasons for the success of solid state construction on the surface. And so let's start with the reason for the possibility of such a device.
                        Holcomb has a patent for a solid state electromagnetic rotor for power generation.
                        https://patentimages.storage.googlea...90238011A1.pdf
                        Listening to tales of spinning electrons is for media losers.
                        Take a conventional synchronous mechanical generator with electromagnetic excitation.
                        Consider only the input excitation power and also the output power of a generator phase, such as a car. The maximum costs for excitation of the rotor electromagnet are: 5 Amperes * 12 Volts = 60 watts. Maximum phase power 1.5 kW. It remains only to solve the problem of a solid-state electromagnet that simulates the rotation of the field from the electromagnet. Let's say all this will take us 200 watts of power. The result of the COP will be 1.5/0.2=7.5. What is the conversion ratio without taking into account the mechanical force in a traditional generator, you can calculate yourself.
                        I hope I explained clearly. What is the magnetic permeability of electrical steel, and how it enhances the magnetic field, I gave an example in one of my posts in this thread.
                        https://overunity.com/19069/holcomb-...511/#msg566511
                        The magnetic circuit, it is in its correct calculation that the secret of the entire project lies.
                        In my design, there is a similar principle and condition for using magnetic field amplification in electrical steel.
                        Sincerely yours, Rakarsky
                        • Okay I get it now, no video proof. Thank you for your kind reply that completely ignores my request plz plz plz reconsider my request
                          Thx for repeating what everybody knows. I'll wait for your book price to be posted.
                          • Hey BroMikey, it’s been a long time
                            Your alum battery videos got me thinking. I have half a dozen little used AGM 12v 5ah batteries from UPS boxes. These are in fair shape but won’t hold a full charge so I’m thinking about converting to alum like you did and maybe build a bigger battery out of a couple of them.
                            Could you tell me how to go about charging them? I’m not at all clear on the charge discharge cycles that need to be done to end up with a good battery.
                            I sure would appreciate your advice.
                            Cadman
                            • Originally posted by Cadman View Post
                              Could you tell me how to go about charging them?.......to end up with a good battery.
                              Cadman
                              Hello Cadman, been some time now and you don't know how I miss intelligent questions on batteries.
                              Broken cells keep the battery from a full charge. I have 10.5v batteries and 11v batteries then 9v batteries open and the red plates are trashed. Take out all of the cell packs and throw away the broken plates and what will be left are all negative plates. 4 junk batteries could make one good one but it ain't easy getting them out without damage. The pos side swells up and binds.
                              I saw one guy cutting plastic panels off the outside to retrieve plates unscathed. Charge and discharge at will, nothing to it. Once every cell can be replaced by all good plates you are in business. You will have 12v the first 2 hours.
                              It takes all day so have fun getting them all out and learn to clean lead surfaces adding more old plate boarder lead to rejoin. Just to say you can do it. Then next time you buy a lawnmower battery brand new dump out the acid and switch to alum but bring it in during the winter.
                              Alum batteries will last 10-20 years.
                              • Thanks BroMikey,
                                It’s refreshing to get a simple straight answer about something.
                                These batteries are almost new. The company I work for uses these cheap-a- - UPS backups that won’t keep the battery charged so every other time there’s a power outage, which is several times a year, the batteries discharge below 11v and the inverters quit. Their solution is to replace the batteries and now they are happy for me to ‘dispose’ of them properly.
                                Anyway my band saw will make quick work of cutting them open and I can build new cases if need be. If it’s as easy as it looks I have a few old car batteries that might be worth converting too.
                                Thanks again for the advice. (and the videos)
                                Respectfully,
                                Cadman
