Report bugs here
This is a sticky topic.
  • #16
    Hello Aaron,
    like You said, the search function now works for me whether I am logged-in or logged-out. (Thank YOU !!! :-) )
    I just found another "bug" , I wrote a post, so far so good, that worked, but I used smileys. They showed up while I was writing the post, but as soon as I send the post
    the smileys that I chose no longer showed up in the text for everybody to see.(only "artifacts" were visible where before the smileys were).
    (so I deleted the smileys again by editing my post)
    Best Regards,
    sparky53
    • #17
      Please post the direct link that you are talking about.
      There is an issue with the original forum links being compatible with the new forum. Not sure if it is possible to resolve it but I'll take a look.
      Problem solved
      Cause and Effect
      • #18
        Originally posted by OrionLightShip View Post
        Thanks, its 7:40 EST and it still doesn't show. Here is the direct link
        http://www.energeticforum.com/forum/...e18#post495837
        I can see all other threads (I think) except for this one above..... Motor Generators
        It isn't in my subcriptions list or todays posts or anywhere to be found except by the link above.
        If you go here: http://www.energeticforum.com/forum/...newable-energy
        Scroll down, do yousee the Motors Generators thread? For me right now, it's the first one after the sticky threads.
        • #19
          Originally posted by Sawt2 View Post
          When I try to sign in over at energy science forum, it says “this website is unsecured”, and I get a warning passwords may be visible
          Neither forum are are SSL - https rather than http. There's not really any secure information being used in the forums like credit card numbers, etc. so never bothered with it but I may do SSL soon for all the main sites including both forums.
          • #20
            Thanks, I reported that to vb.
            • #21
              Problem solved
              Cause and Effect
              ok thanks.
              • #22
                Smilies should be working now.
                • #23
                  New registrations don't work and if you log out, the login form might not come up. Not sure how this suddenly happened, but it is an issue. Message is sent to vbulletin to get resolved asap.
                  • #24
                    Hello Aaron,
                    Right, things a little better today but my problem may have been that it was my first attempt to access the new format.
                    Continued to get the following:
                    Invalid Page URL. If this is an error and the page should exist, please contact the system administrator and tell them how you got this message.
                    I was using an old Bookmark from Firefox and that was the response received.
                    Thank You for your attention.
                    Will get back to you if I have any further problems.
                    Smokey
                    • #25
                      New registrations work now. Looking to streamline approval process.
                      Energetic Forum Administrator
                      • #26
                        Originally posted by David G Dawson View Post
                        Hello Aaron,
                        Smokey
                        Yes, the plugin for the old forum was not compatible with the new forum and the forum had to be upgraded because there were to many problems because it is dated.
                        Good news is that everything in this forum was preserved.
                        Bad news is that external links to the old forum will goto the invalid URL page. I'm looking into some kind of redirect, or making the link go into a search automatically, etc. It isn't looking promising but at least I won't be held hostage to 3rd party plugins for that kind of thing anymore.
                        • #27
                          Hello Aaron,
                          Smokey
                          Here is a temporary work around to find where the old links are supposed to go - links will go to an error page and I put these instructions on there:
                          YES, YOU CAN STILL FIND THIS DISCUSSION IN ENERGETIC FORUM!
                          For example, if the URL that isn't coming up is: http://www.energeticforum.com/renewa...ecrets-33.html
                          Click this: http://energeticforum.com/search
                          1. In the search KEYWORDS field, enter: electric motor secrets
                          2. Check the box for TITLE ONLY (at the end of the KEYWORDS field)
                          3. Click the button SEARCH NOW
                          We apologize for this "Invalid Page URL" error, but the above will let you find what you are looking for.
                          • #28
                            Hello Aaron,
                            I found a bug :
                            If a user writes a post and puts a picture inside his/her message, then later on this picture can only be seen by members that are logged in, while they are reading the post /looking at the post.
                            Guest, that look at the post will only see the filename of the picture, - and clicking (left mouse) on this filename of the picture gets them nowhere.
                            I think the intent of the people writing a post here with pictures is to make the pictures available to see -not only for members of the forum- but also for guests of the forum
                            --> so there is a bug
                            Keep up the good work Aaron, you are doing a amazing Job !!!
                            Best regards,
                            sparky53
                            • #29
                              People, I found that you cannot use strict cookie settings and I also disabled Https only. Go to your brower and check your settings.
                              • #30
                                I put all my stored private messages in one folder but I keep getting this message and can't send any private messages. Shouldn't one folder holding all the saved messages solve this problem. I'll sign out and back in and see if it solves this issue but right now it's still saying I have 200 private message topics saved.
                                "You have reached your stored private message quota of 200 topics. You have 200 topics saved combined in your private message folders. Please delete some of your existing topics."
                                Nope, still say's the same thing. I can't send any messages. I don't mind deleting the messages but how? Where is the download link. I don't see anything like that. I'm bamboozled~
